[PATCH 1/6] score: Add _Timestamp_To_timeval()
Sebastian Huber
Fri Nov 16 15:31:06 UTC 2012
cpukit/score/Makefile.am | 2 +-
cpukit/score/include/rtems/score/timestamp.h | 19 +++++++++++++++
cpukit/score/include/rtems/score/timestamp64.h | 27 ++++++++++++++++++++++
cpukit/score/src/ts64totimeval.c | 29 ++++++++++++++++++++++++
4 files changed, 76 insertions(+), 1 deletions(-)
create mode 100644 cpukit/score/src/ts64totimeval.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index ce1251a..b1e1365 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -304,7 +304,7 @@ libscore_a_SOURCES += src/ts64addto.c src/ts64dividebyinteger.c \
src/ts64getnanoseconds.c src/ts64getseconds.c \
src/ts64lessthan.c \
src/ts64set.c src/ts64settozero.c src/ts64subtract.c \
- src/ts64toticks.c src/ts64totimespec.c
+ src/ts64toticks.c src/ts64totimespec.c src/ts64totimeval.c
## TOD_C_FILES
libscore_a_SOURCES += src/coretod.c src/coretodset.c src/coretodget.c \
diff --git a/cpukit/score/include/rtems/score/timestamp.h b/cpukit/score/include/rtems/score/timestamp.h
index 83948b4..385a9be 100644
--- a/cpukit/score/include/rtems/score/timestamp.h
+++ b/cpukit/score/include/rtems/score/timestamp.h
@@ -38,6 +38,8 @@
+#include <sys/time.h>
#include <rtems/score/cpu.h>
#include <rtems/score/timespec.h>
@@ -342,6 +344,23 @@ extern "C" {
_Timestamp64_To_timespec( _timestamp, _timespec )
#endif
+ * @brief Convert Timestamp to struct timeval
+ * @param[in] _timestamp points to the timestamp
+ * @param[in] _timeval points to the timeval
+#if CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE
+ #define _Timestamp_To_timeval( _timestamp, _timeval ) \
+ do { \
+ _timeval->tv_sec = _timestamp->tv_sec; \
+ _timeval->tv_usec = _timestamp->tv_nsec / 1000; \
+ } while (0)
+#else
+ _Timestamp64_To_timeval( _timestamp, _timeval )
+#endif
#ifdef __cplusplus
#endif
diff --git a/cpukit/score/include/rtems/score/timestamp64.h b/cpukit/score/include/rtems/score/timestamp64.h
index 1c1ea2c..41735fa 100644
--- a/cpukit/score/include/rtems/score/timestamp64.h
+++ b/cpukit/score/include/rtems/score/timestamp64.h
@@ -393,6 +393,33 @@ static inline void _Timestamp64_implementation_To_timespec(
#endif
+static inline void _Timestamp64_implementation_To_timeval(
+ const Timestamp64_Control *_timestamp,
+ struct timeval *_timeval
+ _timeval->tv_sec = (time_t) (*_timestamp / 1000000000U);
+ _timeval->tv_usec = (suseconds_t) ((*_timestamp % 1000000000U) / 1000U);
+ * This method returns the seconds portion of the specified timestamp
+ * @param[out] _timeval points to the timeval
+#if CPU_TIMESTAMP_USE_INT64_INLINE == TRUE
+ #define _Timestamp64_To_timeval( _timestamp, _timeval ) \
+ _Timestamp64_implementation_To_timeval( _timestamp, _timeval )
+#else
+ void _Timestamp64_To_timeval(
+#endif
#ifdef __cplusplus
#endif
diff --git a/cpukit/score/src/ts64totimeval.c b/cpukit/score/src/ts64totimeval.c
new file mode 100644
index 0000000..29bbb78
--- /dev/null
+++ b/cpukit/score/src/ts64totimeval.c
@@ -0,0 +1,29 @@
+ * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/timestamp.h>
+#if CPU_TIMESTAMP_USE_INT64 == TRUE
+void _Timestamp64_To_timeval(
+ _Timestamp64_implementation_To_timeval( _timestamp, _timeval );
+#endif
1.7.7
