[PATCH 2/6] score: Add and use _TOD_Get_with_nanoseconds()
Sebastian Huber
Fri Nov 16 15:31:07 UTC 2012
Delete _TOD_Get_as_timestamp().
cpukit/score/Makefile.am | 2 +-
cpukit/score/include/rtems/score/tod.h | 29 +++++++++++-----
cpukit/score/inline/rtems/score/tod.inl | 17 +++-------
cpukit/score/src/coretodget.c | 22 +++++-------
cpukit/score/src/coretodgetuptime.c | 54 -------------------------------
5 files changed, 35 insertions(+), 89 deletions(-)
delete mode 100644 cpukit/score/src/coretodgetuptime.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index b1e1365..99fbecd 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -308,7 +308,7 @@ libscore_a_SOURCES += src/ts64addto.c src/ts64dividebyinteger.c \
## TOD_C_FILES
libscore_a_SOURCES += src/coretod.c src/coretodset.c src/coretodget.c \
- src/coretodgetuptime.c src/coretodgetuptimetimespec.c src/coretodtickle.c \
+ src/coretodgetuptimetimespec.c src/coretodtickle.c \
src/coretodmsecstoticks.c src/coretodtickspersec.c src/coretodusectoticks.c
## WATCHDOG_C_FILES
diff --git a/cpukit/score/include/rtems/score/tod.h b/cpukit/score/include/rtems/score/tod.h
index 797f4bb..1f21fdb 100644
--- a/cpukit/score/include/rtems/score/tod.h
+++ b/cpukit/score/include/rtems/score/tod.h
@@ -197,22 +197,30 @@ static inline void _TOD_Set(
- * @brief Returns the time of day in @a tod_as_timestamp.
+ * @brief Returns a snapshot of a clock.
- * The @a tod_as_timestamp timestamp represents the time since UNIX epoch.
+ * This function invokes the nanoseconds extension.
+ * @param[out] snapshot The snapshot.
+ * @param[in] source The clock.
+ * @return The snapshot.
-void _TOD_Get_as_timestamp(
- Timestamp_Control *tod_as_timestamp
+Timestamp_Control *_TOD_Get_with_nanoseconds(
+ Timestamp_Control *snapshot,
+ const Timestamp_Control *clock
static inline void _TOD_Get(
struct timespec *tod_as_timespec
- Timestamp_Control tod_as_timestamp;
+ Timestamp_Control tod_as_timestamp;
+ Timestamp_Control *tod_as_timestamp_ptr;
- _TOD_Get_as_timestamp( &tod_as_timestamp );
- _Timestamp_To_timespec( &tod_as_timestamp, tod_as_timespec );
+ tod_as_timestamp_ptr =
+ _TOD_Get_with_nanoseconds( &tod_as_timestamp, &_TOD.now );
+ _Timestamp_To_timespec( tod_as_timestamp_ptr, tod_as_timespec );
@@ -223,9 +231,12 @@ static inline void _TOD_Get(
* @param[in] time is a pointer to the uptime to be returned
-void _TOD_Get_uptime(
+static inline void _TOD_Get_uptime(
Timestamp_Control *time
+ _TOD_Get_with_nanoseconds( time, &_TOD.uptime );
* @brief _TOD_Get_uptime_as_timespec
diff --git a/cpukit/score/inline/rtems/score/tod.inl b/cpukit/score/inline/rtems/score/tod.inl
index 14c7b6f..d8a8bb7 100644
--- a/cpukit/score/inline/rtems/score/tod.inl
+++ b/cpukit/score/inline/rtems/score/tod.inl
@@ -56,19 +56,12 @@ RTEMS_INLINE_ROUTINE void _TOD_Get_timeval(
struct timeval *time
- ISR_Level level;
- struct timespec now;
- suseconds_t useconds;
+ Timestamp_Control snapshot_as_timestamp;
+ Timestamp_Control *snapshot_as_timestamp_ptr;
- _ISR_Disable(level);
- _TOD_Get( &now );
- _ISR_Enable(level);
- useconds = (suseconds_t)now.tv_nsec;
- useconds /= (suseconds_t)TOD_NANOSECONDS_PER_MICROSECOND;
- time->tv_sec = now.tv_sec;
- time->tv_usec = useconds;
+ snapshot_as_timestamp_ptr =
+ _TOD_Get_with_nanoseconds( &snapshot_as_timestamp, &_TOD.now );
+ _Timestamp_To_timeval( snapshot_as_timestamp_ptr, time );
diff --git a/cpukit/score/src/coretodget.c b/cpukit/score/src/coretodget.c
index 94517e5..448bc7b 100644
--- a/cpukit/score/src/coretodget.c
+++ b/cpukit/score/src/coretodget.c
@@ -10,35 +10,31 @@
#if HAVE_CONFIG_H
-#include "config.h"
+ #include "config.h"
#endif
-#include <rtems/system.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/timespec.h>
-#include <rtems/score/timestamp.h>
#include <rtems/score/tod.h>
ISR_Level level;
Timestamp_Control offset;
Timestamp_Control now;
- long nanoseconds;
+ uint32_t nanoseconds;
- /* assume time checked for NULL by caller */
- /* _TOD.now is the native current time */
_ISR_Disable( level );
- now = _TOD.now;
nanoseconds = (*_Watchdog_Nanoseconds_since_tick_handler)();
+ now = *clock;
_ISR_Enable( level );
_Timestamp_Set( &offset, 0, nanoseconds );
_Timestamp_Add_to( &now, &offset );
- *tod = now;
+ *snapshot = now;
+ return snapshot;
diff --git a/cpukit/score/src/coretodgetuptime.c b/cpukit/score/src/coretodgetuptime.c
deleted file mode 100644
index c3c05ae..0000000
--- a/cpukit/score/src/coretodgetuptime.c
+++ /dev/null
@@ -1,54 +0,0 @@
- * Time of Day (TOD) Handler - get uptime
-/* COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/tod.h>
-#include <rtems/score/watchdog.h>
- * _TOD_Get_uptime
- * This routine is used to obtain the system uptime
- * Input parameters:
- * time - pointer to the timestamp structure
- * Output parameters: NONE
- Timestamp_Control *uptime
- ISR_Level level;
- Timestamp_Control offset;
- Timestamp_Control up;
- long nanoseconds;
- /* _TOD.uptime is in native timestamp format */
- _ISR_Disable( level );
- up = _TOD.uptime;
- nanoseconds = (*_Watchdog_Nanoseconds_since_tick_handler)();
- _ISR_Enable( level );
- _Timestamp_Set( &offset, 0, nanoseconds );
- _Timestamp_Add_to( &up, &offset );
- *uptime = up;
1.7.7
