[PATCH 01/15] PR 2048 - Removed use of PPC440 macro from asm.h and moved affected macros to registers.h
Ric Claus
claus at slac.stanford.edu
Tue Nov 27 03:26:39 UTC 2012
cpukit/score/cpu/powerpc/rtems/asm.h | 80 +---
cpukit/score/cpu/powerpc/rtems/powerpc/registers.h | 572 ++++++++++++--------
2 files changed, 339 insertions(+), 313 deletions(-)
diff --git a/cpukit/score/cpu/powerpc/rtems/asm.h b/cpukit/score/cpu/powerpc/rtems/asm.h
index b1a8870..594e323 100644
--- a/cpukit/score/cpu/powerpc/rtems/asm.h
+++ b/cpukit/score/cpu/powerpc/rtems/asm.h
@@ -176,11 +176,11 @@
#define usprg0 256
#define dar 0x013 /* Data Address Register */
-#define dec 0x016 /* Decrementer Register */
+#define dec 0x016 /* Decrementer Register */
#if defined(ppc403) || defined(ppc405)
/* the following SPR/DCR registers exist only in IBM 400 series */
-#define dear 0x3d5
+#define dear 0x3d5
#define evpr 0x3d6 /* SPR: exception vector prefix register */
#define iccr 0x3fb /* SPR: instruction cache control reg. */
#define dccr 0x3fa /* SPR: data cache control reg. */
@@ -203,82 +203,6 @@
#define br6 0x086 /* DCR: memory bank register 6 */
#define br7 0x087 /* DCR: memory bank register 7 */
-#elif defined(ppc440)
-#define xer 0x001 /* SPR: Integer Exception Register */
-#define lr 0x008 /* SPR: Link Register */
-#define ctr 0x009 /* SPR: Count Register */
-#define pid 0x030 /* SPR: Process ID */
-#define decar 0x036 /* SPR: Decrementer Auto-Reload */
-#define dear 0x03d /* SPR: Data Exception Address Register */
-#define esr 0x03e /* SPR: Exception Syndrome Register */
-#define ivpr 0x03f /* SPR: Interrupt Vector Prefix Register */
-#define sprg4_w 0x104 /* SPR: Special Purpose Register General 4 (WO) */
-#define sprg5_w 0x105 /* SPR: Special Purpose Register General 5 (WO) */
-#define sprg6_w 0x107 /* SPR: Special Purpose Register General 6 (WO) */
-#define sprg7_w 0x108 /* SPR: Special Purpose Register General 7 (WO) */
-#define tbl 0x10c /* SPR: Time Base Lower */
-#define tbu 0x10d /* SPR: Time Base Upper */
-#define pir 0x11e /* SPR: Processor ID Register */
-#define pvr 0x11f /* SPR: Processor Version Register */
-#define dbsr 0x130 /* SPR: Debug Status Register */
-#define dbcr0 0x134 /* SPR: Debug Control Register 0 */
-#define dbcr1 0x135 /* SPR: Debug Control Register 1 */
-#define dbcr2 0x136 /* SPR: Debug Control Register 2 */
-#define iac1 0x138 /* SPR: Instruction Address Compare 1 */
-#define iac2 0x139 /* SPR: Instruction Address Compare 2 */
-#define iac3 0x13a /* SPR: Instruction Address Compare 3 */
-#define iac4 0x13b /* SPR: Instruction Address Compare 4 */
-#define dac1 0x13c /* SPR: Data Address Compare 1 */
-#define dac2 0x13d /* SPR: Data Address Compare 2 */
-#define dvc1 0x13e /* SPR: Data Value Compare 1 */
-#define dvc2 0x13f /* SPR: Data Value Compare 2 */
-#define tsr 0x150 /* SPR: Timer Status Register */
-#define tcr 0x154 /* SPR: Timer Control Register */
-#define ivor0 0x190 /* SPR: Interrupt Vector Offset Register 0 */
-#define ivor1 0x191 /* SPR: Interrupt Vector Offset Register 1 */
-#define ivor2 0x192 /* SPR: Interrupt Vector Offset Register 2 */
-#define ivor3 0x193 /* SPR: Interrupt Vector Offset Register 3 */
-#define ivor4 0x194 /* SPR: Interrupt Vector Offset Register 4 */
-#define ivor5 0x195 /* SPR: Interrupt Vector Offset Register 5 */
-#define ivor6 0x196 /* SPR: Interrupt Vector Offset Register 6 */
-#define ivor7 0x197 /* SPR: Interrupt Vector Offset Register 7 */
-#define ivor8 0x198 /* SPR: Interrupt Vector Offset Register 8 */
-#define ivor9 0x199 /* SPR: Interrupt Vector Offset Register 9 */
-#define ivor10 0x19a /* SPR: Interrupt Vector Offset Register 10 */
-#define ivor11 0x19b /* SPR: Interrupt Vector Offset Register 11 */
-#define ivor12 0x19c /* SPR: Interrupt Vector Offset Register 12 */
-#define ivor13 0x19d /* SPR: Interrupt Vector Offset Register 13 */
-#define ivor14 0x19e /* SPR: Interrupt Vector Offset Register 14 */
-#define ivor15 0x19f /* SPR: Interrupt Vector Offset Register 15 */
-#define mcsr 0x23c /* SPR: Machine Check Status Register */
-#define inv0 0x370 /* SPR: Instruction Cache Normal Victim 0 */
-#define inv1 0x371 /* SPR: Instruction Cache Normal Victim 1 */
-#define inv2 0x372 /* SPR: Instruction Cache Normal Victim 2 */
-#define inv3 0x373 /* SPR: Instruction Cache Normal Victim 3 */
-#define itv0 0x374 /* SPR: Instruction Cache Transient Victim 0 */
-#define itv1 0x375 /* SPR: Instruction Cache Transient Victim 1 */
-#define itv2 0x376 /* SPR: Instruction Cache Transient Victim 2 */
-#define itv3 0x377 /* SPR: Instruction Cache Transient Victim 3 */
-#define ccr1 0x378 /* SPR: Core Configuration Register 1 */
-#define dnv0 0x390 /* SPR: Data Cache Normal Victim 0 */
-#define dnv1 0x391 /* SPR: Data Cache Normal Victim 1 */
-#define dnv2 0x392 /* SPR: Data Cache Normal Victim 2 */
-#define dnv3 0x393 /* SPR: Data Cache Normal Victim 3 */
-#define dtv0 0x394 /* SPR: Data Cache Transient Victim 0 */
-#define dtv1 0x395 /* SPR: Data Cache Transient Victim 1 */
-#define dtv2 0x396 /* SPR: Data Cache Transient Victim 2 */
-#define dtv3 0x397 /* SPR: Data Cache Transient Victim 3 */
-#define dvlim 0x398 /* SPR: Data Cache Victim Limit */
-#define ivlim 0x399 /* SPR: Instruction Cache Victim Limit */
-#define rstcfg 0x39b /* SPR: Reset Configuration */
-#define dcdbtrl 0x39c /* SPR: Data Cache Debug Tag Register Low */
-#define dcdbtrh 0x39d /* SPR: Data Cache Debug Tag Register High */
-#define icdbtrl 0x39e /* SPR: Instruction Cache Debug Tag Register Low */
-#define icdbtrh 0x39f /* SPR: Instruction Cache Debug Tag Register High */
-#define mmucr 0x3b2 /* SPR: Memory Management Unit Control Register */
-#define ccr0 0x3b3 /* SPR: Core Configuration Register 0 */
-#define icdbdr 0x3d3 /* SPR: Instruction Cache Debug Data Register */
-#define dbdr 0x3f3 /* SPR: Debug Data Register */
/* end of IBM400 series register definitions */
#elif defined(mpc555)
diff --git a/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h b/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h
index 2eb9235..1e46b67 100644
--- a/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h
+++ b/cpukit/score/cpu/powerpc/rtems/powerpc/registers.h
@@ -17,33 +17,36 @@
#define _RTEMS_POWERPC_REGISTERS_H
/* Bit encodings for Machine State Register (MSR) */
-#define MSR_UCLE (1<<26) /* User-mode cache lock enable (e500) */
-#define MSR_VE (1<<25) /* Alti-Vec enable (7400+) */
-#define MSR_SPE (1<<25) /* SPE enable (e500) */
-#define MSR_POW (1<<18) /* Enable Power Management */
-#define MSR_WE (1<<18) /* Wait state enable (e500) */
-#define MSR_TGPR (1<<17) /* TLB Update registers in use */
-#define MSR_CE (1<<17) /* BookE critical interrupt */
-#define MSR_ILE (1<<16) /* Interrupt Little-Endian enable */
-#define MSR_EE (1<<15) /* External Interrupt enable */
-#define MSR_PR (1<<14) /* Supervisor/User privilege */
-#define MSR_FP (1<<13) /* Floating Point enable */
-#define MSR_ME (1<<12) /* Machine Check enable */
-#define MSR_FE0 (1<<11) /* Floating Exception mode 0 */
-#define MSR_SE (1<<10) /* Single Step */
-#define MSR_UBLE (1<<10) /* User-mode BTB lock enable (e500) */
-#define MSR_BE (1<<9) /* Branch Trace */
-#define MSR_DE (1<<9) /* BookE debug exception */
-#define MSR_FE1 (1<<8) /* Floating Exception mode 1 */
-#define MSR_E300_CE (1<<7) /* e300 critical interrupt */
-#define MSR_IP (1<<6) /* Exception prefix 0x000/0xFFF */
-#define MSR_IR (1<<5) /* Instruction MMU enable */
-#define MSR_DR (1<<4) /* Data MMU enable */
-#define MSR_IS (1<<5) /* Instruction address space */
-#define MSR_DS (1<<4) /* Data address space */
-#define MSR_PMM (1<<2) /* Performance monitor mark */
-#define MSR_RI (1<<1) /* Recoverable Exception */
-#define MSR_LE (1<<0) /* Little-Endian enable */
+#define MSR_UCLE (1<<26) /* User-mode cache lock enable (e500) */
+#define MSR_VE (1<<25) /* Alti-Vec enable (7400+) */
+#define MSR_SPE (1<<25) /* SPE enable (e500) */
+#define MSR_AP (1<<25) /* Auxiliary processor available */
+#define MSR_APE (1<<19) /* APU exception enable */
+#define MSR_POW (1<<18) /* Enable Power Management */
+#define MSR_WE (1<<18) /* Wait state enable (e500, 4xx) */
+#define MSR_TGPR (1<<17) /* TLB Update registers in use */
+#define MSR_CE (1<<17) /* BookE critical interrupt */
+#define MSR_ILE (1<<16) /* Interrupt Little-Endian enable */
+#define MSR_EE (1<<15) /* External Interrupt enable */
+#define MSR_PR (1<<14) /* Supervisor/User privilege */
+#define MSR_FP (1<<13) /* Floating Point enable */
+#define MSR_ME (1<<12) /* Machine Check enable */
+#define MSR_FE0 (1<<11) /* Floating Exception mode 0 */
+#define MSR_SE (1<<10) /* Single Step */
+#define MSR_UBLE (1<<10) /* User-mode BTB lock enable (e500) */
+#define MSR_DWE (1<<10) /* Debug wait enable (4xx) */
+#define MSR_BE (1<<9) /* Branch Trace */
+#define MSR_DE (1<<9) /* BookE debug exception */
+#define MSR_FE1 (1<<8) /* Floating Exception mode 1 */
+#define MSR_E300_CE (1<<7) /* e300 critical interrupt */
+#define MSR_IP (1<<6) /* Exception prefix 0x000/0xFFF */
+#define MSR_IR (1<<5) /* Instruction MMU enable */
+#define MSR_DR (1<<4) /* Data MMU enable */
+#define MSR_IS (1<<5) /* Instruction address space */
+#define MSR_DS (1<<4) /* Data address space */
+#define MSR_PMM (1<<2) /* Performance monitor mark */
+#define MSR_RI (1<<1) /* Recoverable Exception */
+#define MSR_LE (1<<0) /* Little-Endian enable */
/* Bit encodings for Hardware Implementation Register (HID0)
on PowerPC 603, 604, etc. processors (not 601). */
@@ -55,41 +58,41 @@
* E.g., EMCP isHID0_DOZE is HID0_HI_BAT_EN on the
* on the 7450s. IFFT is XBSEN on 7450 and so on...
-#define HID0_EMCP (1<<31) /* Enable Machine Check pin */
-#define HID0_EBA (1<<29) /* Enable Bus Address Parity */
-#define HID0_EBD (1<<28) /* Enable Bus Data Parity */
-#define HID0_SBCLK (1<<27)
+#define HID0_EMCP (1<<31) /* Enable Machine Check pin */
+#define HID0_EBA (1<<29) /* Enable Bus Address Parity */
+#define HID0_EBD (1<<28) /* Enable Bus Data Parity */
+#define HID0_SBCLK (1<<27)
#define HID0_TBEN (1<<26) /* 7455:this bit must be set
- * and TBEN signal must be asserted
- * to enable the time base and
- * decrementer.
-#define HID0_EICE (1<<26)
-#define HID0_ECLK (1<<25)
-#define HID0_PAR (1<<24)
-#define HID0_DOZE (1<<23)
+ * and TBEN signal must be asserted
+ * to enable the time base and
+ * decrementer.
+#define HID0_EICE (1<<26)
+#define HID0_ECLK (1<<25)
+#define HID0_PAR (1<<24)
+#define HID0_DOZE (1<<23)
/* this HI_BAT_EN only on 7445, 7447, 7448, 7455 & 7457 !! */
#define HID0_7455_HIGH_BAT_EN (1<<23)
-#define HID0_NAP (1<<22)
-#define HID0_SLEEP (1<<21)
-#define HID0_DPM (1<<20)
-#define HID0_ICE (1<<15) /* Instruction Cache Enable */
-#define HID0_DCE (1<<14) /* Data Cache Enable */
-#define HID0_ILOCK (1<<13) /* Instruction Cache Lock */
-#define HID0_DLOCK (1<<12) /* Data Cache Lock */
-#define HID0_ICFI (1<<11) /* Instruction Cache Flash Invalidate */
-#define HID0_DCI (1<<10) /* Data Cache Invalidate */
+#define HID0_NAP (1<<22)
+#define HID0_SLEEP (1<<21)
+#define HID0_DPM (1<<20)
+#define HID0_ICE (1<<15) /* Instruction Cache Enable */
+#define HID0_DCE (1<<14) /* Data Cache Enable */
+#define HID0_ILOCK (1<<13) /* Instruction Cache Lock */
+#define HID0_DLOCK (1<<12) /* Data Cache Lock */
+#define HID0_ICFI (1<<11) /* Instruction Cache Flash Invalidate */
+#define HID0_DCI (1<<10) /* Data Cache Invalidate */
/* this bit is XSBSEN (xtended block size enable) on 7447, 7448, 7455 and 7457 only */
#define HID0_7455_XBSEN (1<<8)
-#define HID0_SIED (1<<7) /* Serial Instruction Execution [Disable] */
-#define HID0_BTIC (1<<5) /* Branch Target Instruction Cache [Enable] */
+#define HID0_SIED (1<<7) /* Serial Instruction Execution [Disable] */
+#define HID0_BTIC (1<<5) /* Branch Target Instruction Cache [Enable] */
/* S.K. Feng 10/03, added for MPC7455 */
-#define HID0_LRSTK (1<<4) /* Link register stack enable (7455) */
-#define HID0_FOLD (1<<3) /* Branch folding enable (7455) */
+#define HID0_LRSTK (1<<4) /* Link register stack enable (7455) */
+#define HID0_FOLD (1<<3) /* Branch folding enable (7455) */
-#define HID0_BHTE (1<<2) /* Branch History Table Enable */
-#define HID0_BTCD (1<<1) /* Branch target cache disable */
+#define HID0_BHTE (1<<2) /* Branch History Table Enable */
+#define HID0_BTCD (1<<1) /* Branch target cache disable */
/* fpscr settings */
#define FPSCR_FX (1<<31)
@@ -113,160 +116,160 @@
#define _CHRP_IBM 0x05 /* IBM chrp, the longtrail and longtrail 2 */
#define _GLOBAL(n)\
- .globl n;\
+ .globl n;\
n:
-#define TBRU 269 /* Time base Upper/Lower (Reading) */
-#define TBRL 268
-#define TBWU 285 /* Time base Upper/Lower (Writing) */
-#define TBWL 284
-#define PPC_XER 1
-#define PPC_LR 8
-#define PPC_CTR 9
-#define HID0 1008 /* Hardware Implementation 0 */
-#define HID1 1009 /* Hardware Implementation 1 */
-#define HID2 1011 /* Hardware Implementation 2 */
-#define DABR 1013 /* Data Access Breakpoint */
-#define PPC_PVR 287 /* Processor Version */
-#define IBAT0U 528 /* Instruction BAT #0 Upper/Lower */
-#define IBAT0L 529
-#define IBAT1U 530 /* Instruction BAT #1 Upper/Lower */
-#define IBAT1L 531
-#define IBAT2U 532 /* Instruction BAT #2 Upper/Lower */
-#define IBAT2L 533
-#define IBAT3U 534 /* Instruction BAT #3 Upper/Lower */
-#define IBAT3L 535
+#define TBRU 269 /* Time base Upper/Lower (Reading) */
+#define TBRL 268
+#define TBWU 285 /* Time base Upper/Lower (Writing) */
+#define TBWL 284
+#define PPC_XER 1
+#define PPC_LR 8
+#define PPC_CTR 9
+#define HID0 1008 /* Hardware Implementation 0 */
+#define HID1 1009 /* Hardware Implementation 1 */
+#define HID2 1011 /* Hardware Implementation 2 */
+#define DABR 1013 /* Data Access Breakpoint */
+#define PPC_PVR 287 /* Processor Version */
+#define IBAT0U 528 /* Instruction BAT #0 Upper/Lower */
+#define IBAT0L 529
+#define IBAT1U 530 /* Instruction BAT #1 Upper/Lower */
+#define IBAT1L 531
+#define IBAT2U 532 /* Instruction BAT #2 Upper/Lower */
+#define IBAT2L 533
+#define IBAT3U 534 /* Instruction BAT #3 Upper/Lower */
+#define IBAT3L 535
/* Only present on 7445, 7447, 7448, 7455 and 7457 (if HID0[HIGH_BAT_EN]) */
-#define IBAT4U 560 /* Instruction BAT #4 Upper/Lower */
-#define IBAT4L 561
-#define IBAT5U 562 /* Instruction BAT #5 Upper/Lower */
-#define IBAT5L 563
-#define IBAT6U 564 /* Instruction BAT #6 Upper/Lower */
-#define IBAT6L 565
-#define IBAT7U 566 /* Instruction BAT #7 Upper/Lower */
-#define IBAT7L 567
-#define DBAT0U 536 /* Data BAT #0 Upper/Lower */
-#define DBAT0L 537
-#define DBAT1U 538 /* Data BAT #1 Upper/Lower */
-#define DBAT1L 539
-#define DBAT2U 540 /* Data BAT #2 Upper/Lower */
-#define DBAT2L 541
-#define DBAT3U 542 /* Data BAT #3 Upper/Lower */
-#define DBAT3L 543
+#define IBAT4U 560 /* Instruction BAT #4 Upper/Lower */
+#define IBAT4L 561
+#define IBAT5U 562 /* Instruction BAT #5 Upper/Lower */
+#define IBAT5L 563
+#define IBAT6U 564 /* Instruction BAT #6 Upper/Lower */
+#define IBAT6L 565
+#define IBAT7U 566 /* Instruction BAT #7 Upper/Lower */
+#define IBAT7L 567
+#define DBAT0U 536 /* Data BAT #0 Upper/Lower */
+#define DBAT0L 537
+#define DBAT1U 538 /* Data BAT #1 Upper/Lower */
+#define DBAT1L 539
+#define DBAT2U 540 /* Data BAT #2 Upper/Lower */
+#define DBAT2L 541
+#define DBAT3U 542 /* Data BAT #3 Upper/Lower */
+#define DBAT3L 543
-#define DBAT4U 568 /* Instruction BAT #4 Upper/Lower */
-#define DBAT4L 569
-#define DBAT5U 570 /* Instruction BAT #5 Upper/Lower */
-#define DBAT5L 571
-#define DBAT6U 572 /* Instruction BAT #6 Upper/Lower */
-#define DBAT6L 573
-#define DBAT7U 574 /* Instruction BAT #7 Upper/Lower */
-#define DBAT7L 575
-#define DMISS 976 /* TLB Lookup/Refresh registers */
-#define DCMP 977
-#define HASH1 978
-#define HASH2 979
-#define IMISS 980
-#define ICMP 981
-#define PPC_RPA 982
-#define SDR1 25 /* MMU hash base register */
-#define PPC_DAR 19 /* Data Address Register */
+#define DBAT4U 568 /* Instruction BAT #4 Upper/Lower */
+#define DBAT4L 569
+#define DBAT5U 570 /* Instruction BAT #5 Upper/Lower */
+#define DBAT5L 571
+#define DBAT6U 572 /* Instruction BAT #6 Upper/Lower */
+#define DBAT6L 573
+#define DBAT7U 574 /* Instruction BAT #7 Upper/Lower */
+#define DBAT7L 575
+#define DMISS 976 /* TLB Lookup/Refresh registers */
+#define DCMP 977
+#define HASH1 978
+#define HASH2 979
+#define IMISS 980
+#define ICMP 981
+#define PPC_RPA 982
+#define SDR1 25 /* MMU hash base register */
+#define PPC_DAR 19 /* Data Address Register */
#define DEAR_BOOKE 61
#define DEAR_405 981
-#define SPR0 272 /* Supervisor Private Registers */
+#define SPR0 272 /* Supervisor Private Registers */
#define SPRG0 272
-#define SPR1 273
+#define SPR1 273
#define SPRG1 273
-#define SPR2 274
+#define SPR2 274
#define SPRG2 274
-#define SPR3 275
+#define SPR3 275
#define SPRG3 275
#define SPRG4 276
#define SPRG5 277
#define SPRG6 278
#define SPRG7 279
#define USPRG0 256
-#define DSISR 18
-#define SRR0 26 /* Saved Registers (exception) */
-#define SRR1 27
-#define IABR 1010 /* Instruction Address Breakpoint */
-#define PPC_DEC 22 /* Decrementer */
-#define PPC_EAR 282 /* External Address Register */
+#define DSISR 18
+#define SRR0 26 /* Saved Registers (exception) */
+#define SRR1 27
+#define IABR 1010 /* Instruction Address Breakpoint */
+#define PPC_DEC 22 /* Decrementer */
+#define PPC_EAR 282 /* External Address Register */
#define MSSCR0 1014 /* Memory Subsystem Control Register */
-#define L2CR 1017 /* PPC 750 and 74xx L2 control register */
+#define L2CR 1017 /* PPC 750 and 74xx L2 control register */
-#define L2CR_L2E (1<<31) /* enable */
-#define L2CR_L2I (1<<21) /* global invalidate */
+#define L2CR_L2E (1<<31) /* enable */
+#define L2CR_L2I (1<<21) /* global invalidate */
/* watch out L2IO and L2DO are different between 745x and 7400/7410 */
/* Oddly, the following L2CR bit defintions in 745x
* is different from that of 7400 and 7410.
* Though not used in 7400 and 7410, it is appeded with _745x just
* to be clarified.
#define L2CR_L2IO_745x 0x100000 /* (1<<20) L2 Instruction-Only */
#define L2CR_L2DO_745x 0x10000 /* (1<<16) L2 Data-Only */
#define L2CR_LOCK_745x (L2CR_L2IO_745x|L2CR_L2DO_745x)
#define L2CR_L3OH0 0x00080000 /* 12:L3 output hold 0 */
#define L3CR 1018 /* PPC 7450/7455 L3 control register */
#define L3CR_L3IO_745x 0x400000 /* (1<<22) L3 Instruction-Only */
-#define L3CR_L3DO_745x 0x40 /* (1<<6) L3 Data-Only */
+#define L3CR_L3DO_745x 0x40 /* (1<<6) L3 Data-Only */
#define L3CR_LOCK_745x (L3CR_L3IO_745x|L3CR_L3DO_745x)
-#define L3CR_RESERVED 0x0438003a /* Reserved bits in L3CR */
-#define L3CR_L3E 0x80000000 /* 0: L3 enable */
-#define L3CR_L3PE 0x40000000 /* 1: L3 data parity checking enable */
-#define L3CR_L3APE 0x20000000 /* 2: L3 address parity checking enable */
-#define L3CR_L3SIZ 0x10000000 /* 3: L3 size (0=1MB, 1=2MB) */
-#define L3SIZ_1M 0x00000000
-#define L3SIZ_2M 0x10000000
-#define L3CR_L3CLKEN 0x08000000 /* 4: Enables the L3_CLK[0:1] signals */
-#define L3CR_L3CLK 0x03800000 /* 6-8: L3 clock ratio */
-#define L3CLK_60 0x00000000 /* core clock / 6 */
-#define L3CLK_20 0x01000000 /* / 2 */
-#define L3CLK_25 0x01800000 /* / 2.5 */
-#define L3CLK_30 0x02000000 /* / 3 */
-#define L3CLK_35 0x02800000 /* / 3.5 */
-#define L3CLK_40 0x03000000 /* / 4 */
-#define L3CLK_50 0x03800000 /* / 5 */
-#define L3CR_L3IO 0x00400000 /* 9: L3 instruction-only mode */
-#define L3CR_L3SPO 0x00040000 /* 13: L3 sample point override */
-#define L3CR_L3CKSP 0x00030000 /* 14-15: L3 clock sample point */
-#define L3CKSP_2 0x00000000 /* 2 clocks */
-#define L3CKSP_3 0x00010000 /* 3 clocks */
-#define L3CKSP_4 0x00020000 /* 4 clocks */
-#define L3CKSP_5 0x00030000 /* 5 clocks */
-#define L3CR_L3PSP 0x0000e000 /* 16-18: L3 P-clock sample point */
-#define L3PSP_0 0x00000000 /* 0 clocks */
-#define L3PSP_1 0x00002000 /* 1 clocks */
-#define L3PSP_2 0x00004000 /* 2 clocks */
-#define L3PSP_3 0x00006000 /* 3 clocks */
-#define L3PSP_4 0x00008000 /* 4 clocks */
-#define L3PSP_5 0x0000a000 /* 5 clocks */
-#define L3CR_L3REP 0x00001000 /* 19: L3 replacement algorithm (0=default, 1=alternate) */
-#define L3CR_L3HWF 0x00000800 /* 20: L3 hardware flush */
-#define L3CR_L3I 0x00000400 /* 21: L3 global invaregisters.h.orig
+#define L3CR_RESERVED 0x0438003a /* Reserved bits in L3CR */
+#define L3CR_L3E 0x80000000 /* 0: L3 enable */
+#define L3CR_L3PE 0x40000000 /* 1: L3 data parity checking enable */
+#define L3CR_L3APE 0x20000000 /* 2: L3 address parity checking enable */
+#define L3CR_L3SIZ 0x10000000 /* 3: L3 size (0=1MB, 1=2MB) */
+#define L3SIZ_1M 0x00000000
+#define L3SIZ_2M 0x10000000
+#define L3CR_L3CLKEN 0x08000000 /* 4: Enables the L3_CLK[0:1] signals */
+#define L3CR_L3CLK 0x03800000 /* 6-8: L3 clock ratio */
+#define L3CLK_60 0x00000000 /* core clock / 6 */
+#define L3CLK_20 0x01000000 /* / 2 */
+#define L3CLK_25 0x01800000 /* / 2.5 */
+#define L3CLK_30 0x02000000 /* / 3 */
+#define L3CLK_35 0x02800000 /* / 3.5 */
+#define L3CLK_40 0x03000000 /* / 4 */
+#define L3CLK_50 0x03800000 /* / 5 */
+#define L3CR_L3IO 0x00400000 /* 9: L3 instruction-only mode */
+#define L3CR_L3SPO 0x00040000 /* 13: L3 sample point override */
+#define L3CR_L3CKSP 0x00030000 /* 14-15: L3 clock sample point */
+#define L3CKSP_2 0x00000000 /* 2 clocks */
+#define L3CKSP_3 0x00010000 /* 3 clocks */
+#define L3CKSP_4 0x00020000 /* 4 clocks */
+#define L3CKSP_5 0x00030000 /* 5 clocks */
+#define L3CR_L3PSP 0x0000e000 /* 16-18: L3 P-clock sample point */
+#define L3PSP_0 0x00000000 /* 0 clocks */
+#define L3PSP_1 0x00002000 /* 1 clocks */
+#define L3PSP_2 0x00004000 /* 2 clocks */
+#define L3PSP_3 0x00006000 /* 3 clocks */
+#define L3PSP_4 0x00008000 /* 4 clocks */
+#define L3PSP_5 0x0000a000 /* 5 clocks */
+#define L3CR_L3REP 0x00001000 /* 19: L3 replacement algorithm (0=default, 1=alternate) */
+#define L3CR_L3HWF 0x00000800 /* 20: L3 hardware flush */
+#define L3CR_L3I 0x00000400 /* 21: L3 global invaregisters.h.orig
lidate */
-#define L3CR_L3RT 0x00000300 /* 22-23: L3 SRAM type */
-#define L3RT_MSUG2_DDR 0x00000000 /* MSUG2 DDR SRAM */
-#define L3RT_PIPELINE_LATE 0x00000100 /* Pipelined (register-register) synchronous late-write SRAM */
-#define L3RT_PB2_SRAM 0x00000300 /* PB2 SRAM */
-#define L3CR_L3NIRCA 0x00000080 /* 24: L3 non-integer ratios clock adjustment for the SRAM */
-#define L3CR_L3DO 0x00000040 /* 25: L3 data-only mode */
-#define L3CR_PMEN 0x00000004 /* 29: Private memory enable */
-#define L3CR_PMSIZ 0x00000004 /* 31: Private memory size (0=1MB, 1=2MB) */
-#define THRM1 1020
-#define THRM2 1021
-#define THRM3 1022
+#define L3CR_L3RT 0x00000300 /* 22-23: L3 SRAM type */
+#define L3RT_MSUG2_DDR 0x00000000 /* MSUG2 DDR SRAM */
+#define L3RT_PIPELINE_LATE 0x00000100 /* Pipelined (register-register) synchronous late-write SRAM */
+#define L3RT_PB2_SRAM 0x00000300 /* PB2 SRAM */
+#define L3CR_L3NIRCA 0x00000080 /* 24: L3 non-integer ratios clock adjustment for the SRAM */
+#define L3CR_L3DO 0x00000040 /* 25: L3 data-only mode */
+#define L3CR_PMEN 0x00000004 /* 29: Private memory enable */
+#define L3CR_PMSIZ 0x00000004 /* 31: Private memory size (0=1MB, 1=2MB) */
+#define THRM1 1020
+#define THRM2 1021
+#define THRM3 1022
#define THRM1_TIN (1<<(31-0))
#define THRM1_TIV (1<<(31-1))
#define THRM1_THRES (0x7f<<(31-8))
@@ -277,60 +280,159 @@ lidate */
#define THRM3_E (1<<(31-31))
/* Segment Registers */
-#define PPC_SR0 0
-#define PPC_SR1 1
-#define PPC_SR2 2
-#define PPC_SR3 3
-#define PPC_SR4 4
-#define PPC_SR5 5
-#define PPC_SR6 6
-#define PPC_SR7 7
-#define PPC_SR8 8
-#define PPC_SR9 9
-#define PPC_SR10 10
-#define PPC_SR11 11
-#define PPC_SR12 12
-#define PPC_SR13 13
-#define PPC_SR14 14
-#define PPC_SR15 15
-#define BOOKE_DECAR 54
-#define PPC405_TSR 0x3D8
-#define BOOKE_TSR 336
-#define BOOKE_TSR_ENW (1<<31)
-#define BOOKE_TSR_WIS (1<<30)
-#define BOOKE_TSR_DIS (1<<27)
-#define BOOKE_TSR_FIS (1<<26)
-#define PPC405_TCR 0x3DA
-#define BOOKE_TCR 340
-#define BOOKE_TCR_WP(x) (((x)&3)<<30)
-#define BOOKE_TCR_WP_MASK (3<<30)
-#define BOOKE_TCR_WRC(x) (((x)&3)<<28)
-#define BOOKE_TCR_WRC_MASK (3<<28)
-#define BOOKE_TCR_WIE (1<<27)
-#define BOOKE_TCR_DIE (1<<26)
-#define BOOKE_TCR_FP(x) (((x)&3)<<24)
-#define BOOKE_TCR_FIE (1<<23)
-#define BOOKE_TCR_ARE (1<<22)
-#define BOOKE_TCR_WPEXT(x) (((x)&0xf)<<17)
-#define BOOKE_TCR_WPEXT_MASK (0xf<<17)
-#define BOOKE_TCR_FPEXT(x) (((x)&0xf)<<13)
-#define BOOKE_TCR_FPEXT_MASK (0xf<<13)
-#define BOOKE_PID 48
-#define BOOKE_ESR 62
-#define BOOKE_IVPR 63
-#define BOOKE_PIR 286
-#define BOOKE_DBSR 304
-#define BOOKE_DBCR0 308
-#define BOOKE_DBCR1 309
-#define BOOKE_DBCR2 310
-#define BOOKE_DAC1 316
-#define BOOKE_DAC2 317
-#define BOOKE_DVC1 318
-#define BOOKE_DVC2 319
+#define PPC_SR0 0
+#define PPC_SR1 1
+#define PPC_SR2 2
+#define PPC_SR3 3
+#define PPC_SR4 4
+#define PPC_SR5 5
+#define PPC_SR6 6
+#define PPC_SR7 7
+#define PPC_SR8 8
+#define PPC_SR9 9
+#define PPC_SR10 10
+#define PPC_SR11 11
+#define PPC_SR12 12
+#define PPC_SR13 13
+#define PPC_SR14 14
+#define PPC_SR15 15
+#define BOOKE_DECAR 54
+#define PPC405_DEAR 0x3D5
+#define BOOKE_DEAR 61
+#define PPC405_TSR 0x3D8
+#define BOOKE_TSR 336
+#define BOOKE_TSR_ENW (1<<31)
+#define BOOKE_TSR_WIS (1<<30)
+#define BOOKE_TSR_DIS (1<<27)
+#define BOOKE_TSR_FIS (1<<26)
+#define PPC405_TCR 0x3DA
+#define BOOKE_TCR 340
+#define BOOKE_TCR_WP(x) (((x)&3)<<30)
+#define BOOKE_TCR_WP_MASK (3<<30)
+#define BOOKE_TCR_WRC(x) (((x)&3)<<28)
+#define BOOKE_TCR_WRC_MASK (3<<28)
+#define BOOKE_TCR_WIE (1<<27)
+#define BOOKE_TCR_DIE (1<<26)
+#define BOOKE_TCR_FP(x) (((x)&3)<<24)
+#define BOOKE_TCR_FIE (1<<23)
+#define BOOKE_TCR_ARE (1<<22)
+#define BOOKE_TCR_WPEXT(x) (((x)&0xf)<<17)
+#define BOOKE_TCR_WPEXT_MASK (0xf<<17)
+#define BOOKE_TCR_FPEXT(x) (((x)&0xf)<<13)
+#define BOOKE_TCR_FPEXT_MASK (0xf<<13)
+#define BOOKE_PID 48 /* Process ID */
+#define BOOKE_ESR 62 /* Exception Syndrome Register */
+#define BOOKE_IVPR 63 /* Interrupt Vector Prefix Register */
+#define BOOKE_SPRG4_W 260 /* Special Purpose Register General 4 (WO) */
+#define BOOKE_SPRG5_W 261 /* Special Purpose Register General 5 (WO) */
+#define BOOKE_SPRG6_W 262 /* Special Purpose Register General 6 (WO) */
+#define BOOKE_SPRG7_W 263 /* Special Purpose Register General 7 (WO) */
+#define BOOKE_PIR 286 /* Processor ID Register */
+#define BOOKE_DBSR 304 /* Debug Status Register */
+#define BOOKE_DBCR0 308 /* Debug Control Register 0 */
+#define BOOKE_DBCR1 309 /* Debug Control Register 1 */
+#define BOOKE_DBCR2 310 /* Debug Control Register 2 */
+#define BOOKE_IAC1 312 /* Instruction Address Compare 1 */
+#define BOOKE_IAC2 313 /* Instruction Address Compare 2 */
+#define BOOKE_IAC3 314 /* Instruction Address Compare 3 */
+#define BOOKE_IAC4 315 /* Instruction Address Compare 4 */
+#define BOOKE_DAC1 316 /* Data Address Compare 1 */
+#define BOOKE_DAC2 317 /* Data Address Compare 2 */
+#define BOOKE_DVC1 318 /* Data Value Compare 1 */
+#define BOOKE_DVC2 319 /* Data Value Compare 2 */
+#define BOOKE_IVOR0 400 /* Interrupt Vector Offset Register 0 */
+#define BOOKE_IVOR1 401 /* Interrupt Vector Offset Register 1 */
+#define BOOKE_IVOR2 402 /* Interrupt Vector Offset Register 2 */
+#define BOOKE_IVOR3 403 /* Interrupt Vector Offset Register 3 */
+#define BOOKE_IVOR4 404 /* Interrupt Vector Offset Register 4 */
+#define BOOKE_IVOR5 405 /* Interrupt Vector Offset Register 5 */
+#define BOOKE_IVOR6 406 /* Interrupt Vector Offset Register 6 */
+#define BOOKE_IVOR7 407 /* Interrupt Vector Offset Register 7 */
+#define BOOKE_IVOR8 408 /* Interrupt Vector Offset Register 8 */
+#define BOOKE_IVOR9 409 /* Interrupt Vector Offset Register 9 */
+#define BOOKE_IVOR10 410 /* Interrupt Vector Offset Register 10 */
+#define BOOKE_IVOR11 411 /* Interrupt Vector Offset Register 11 */
+#define BOOKE_IVOR12 412 /* Interrupt Vector Offset Register 12 */
+#define BOOKE_IVOR13 413 /* Interrupt Vector Offset Register 13 */
+#define BOOKE_IVOR14 414 /* Interrupt Vector Offset Register 14 */
+#define BOOKE_IVOR15 415 /* Interrupt Vector Offset Register 15 */
+#define BOOKE_MCSR 572 /* Machine Check Status Register */
+#define PPC440_INV0 880 /* Instruction Cache Normal Victim 0 */
+#define PPC440_INV1 881 /* Instruction Cache Normal Victim 1 */
+#define PPC440_INV2 882 /* Instruction Cache Normal Victim 2 */
+#define PPC440_INV3 883 /* Instruction Cache Normal Victim 3 */
+#define PPC440_ITV0 884 /* Instruction Cache Transient Victim 0 */
+#define PPC440_ITV1 885 /* Instruction Cache Transient Victim 1 */
+#define PPC440_ITV2 886 /* Instruction Cache Transient Victim 2 */
+#define PPC440_ITV3 887 /* Instruction Cache Transient Victim 3 */
+#define PPC440_CCR1 888 /* Core Configuration Register 1 */
+#define PPC440_DNV0 912 /* Data Cache Normal Victim 0 */
+#define PPC440_DNV1 913 /* Data Cache Normal Victim 1 */
+#define PPC440_DNV2 914 /* Data Cache Normal Victim 2 */
+#define PPC440_DNV3 915 /* Data Cache Normal Victim 3 */
+#define PPC440_DTV0 916 /* Data Cache Transient Victim 0 */
+#define PPC440_DTV1 917 /* Data Cache Transient Victim 1 */
+#define PPC440_DTV2 918 /* Data Cache Transient Victim 2 */
+#define PPC440_DTV3 919 /* Data Cache Transient Victim 3 */
+#define PPC440_DVLIM 920 /* Data Cache Victim Limit */
+#define PPC440_IVLIM 921 /* Instruction Cache Victim Limit */
+#define PPC440_RSTCFG 923 /* Reset Configuration */
+#define PPC440_DCDBTRL 924 /* Data Cache Debug Tag Register Low */
+#define PPC440_DCDBTRH 925 /* Data Cache Debug Tag Register High */
+#define PPC440_ICDBTRL 926 /* Instruction Cache Debug Tag Register Low */
+#define PPC440_ICDBTRH 927 /* Instruction Cache Debug Tag Register High */
+#define PPC440_MMUCR 946 /* Memory Management Unit Control Register */
+#define PPC440_CCR0 947 /* Core Configuration Register 0 */
+#define PPC440_ICDBDR 979 /* Instruction Cache Debug Data Register */
+#define PPC440_DBDR 1011 /* Debug Data Register */
+#define PPC440_TLB0_EPN(n) ( (((1<<22)-1)&(n)) << (31-21)) /* Etended Page Number */
+#define PPC440_TLB0_EPN_GET(n) ( ((n) >> (31-21)) & ((1<<22)-1))
+#define PPC440_TLB0_V ( 1 << (31-22)) /* Entry valid */
+#define PPC440_TLB0_TS ( 1 << (31-23)) /* Translation space */
+#define PPC440_TLB0_TSIZE(n) ( (0xf & (n)) << (31-27)) /* Page size */
+#define PPC440_TLB0_TSIZE_GET(n) ( ((n) >> (31-27)) & 0xf)
+#define PPC440_TLB0_TPAR(n) ( (0xf & (n)) << (31-31)) /* Tag Parity */
+#define PPC440_TLB0_TPAR_GET(n) ( ((n) >> (31-31)) & 0xf)
+#define PPC440_PID_TID(n) ( (0xff & (n)) << (31-31)) /* Translation ID */
+#define PPC440_PID_TID_GET(n) ( ((n) >> (31-31)) & 0xff)
+#define PPC440_TLB1_RPN(n) ( (((1<<22)-1)&(n)) << (31-21)) /* Real Page Number */
+#define PPC440_TLB1_RPN_GET(n) ( ((n) >> (31-21)) & ((1<<22)-1))
+#define PPC440_TLB1_PAR1(n) ( (0x3 & (n)) << (31-23)) /* Parity for TLB word 1 */
+#define PPC440_TLB1_PAR1_GET(n) ( ((n) >> (31-23)) & 0x3)
+#define PPC440_TLB1_ERPN(n) ( (0xf & (n)) << (31-31)) /* Extended Real Page No. */
+#define PPC440_TLB1_ERPN_GET(n) ( ((n) >> (31-31)) & 0xf)
+#define PPC440_TLB2_PAR2(n) ( (0x3 & (n)) << (31- 1)) /* Parity for TLB word 2 */
+#define PPC440_TLB2_PAR2_GET(n) ( ((n) >> (31- 1)) & 0x3)
+#define PPC440_TLB2_U0 ( 1 << (31-16)) /* User attr. 0 */
+#define PPC440_TLB2_U1 ( 1 << (31-17)) /* User attr. 1 */
+#define PPC440_TLB2_U2 ( 1 << (31-18)) /* User attr. 2 */
+#define PPC440_TLB2_U3 ( 1 << (31-19)) /* User attr. 3 */
+#define PPC440_TLB2_W ( 1 << (31-20)) /* Write-through */
+#define PPC440_TLB2_I ( 1 << (31-21)) /* Cache-inhibited */
+#define PPC440_TLB2_M ( 1 << (31-22)) /* Memory-coherence req. */
+#define PPC440_TLB2_G ( 1 << (31-23)) /* Guarded */
+#define PPC440_TLB2_E ( 1 << (31-24)) /* Little-endian */
+#define PPC440_TLB2_UX ( 1 << (31-26)) /* User exec. */
+#define PPC440_TLB2_UW ( 1 << (31-27)) /* User write */
+#define PPC440_TLB2_UR ( 1 << (31-28)) /* User read */
+#define PPC440_TLB2_SX ( 1 << (31-29)) /* Super exec. */
+#define PPC440_TLB2_SW ( 1 << (31-30)) /* Super write */
+#define PPC440_TLB2_SR ( 1 << (31-31)) /* Super read */
+#define PPC440_TLB2_ATTR(x) ( ((x) & 0x1ff) << 7 )
+#define PPC440_TLB2_ATTR_GET(x) ( ((x) >> 7) & 0x1ff )
+#define PPC440_TLB2_PERM(n) ( (n) & 0x3f )
+#define PPC440_TLB2_PERM_GET(n) ( (n) & 0x3f )
/* Freescale Book E Implementation Standards (EIS): Branch Operations */
@@ -442,9 +544,9 @@ lidate */
/* Freescale Book E Implementation Standards (EIS): Interrupt */
-#define FSL_EIS_MCAR 573
-#define FSL_EIS_DSRR0 574
-#define FSL_EIS_DSRR1 575
+#define FSL_EIS_MCAR 573
+#define FSL_EIS_DSRR0 574
+#define FSL_EIS_DSRR1 575
/* Freescale Book E Implementation Standards (EIS): Signal Processing Engine (SPE) */
@@ -452,16 +554,16 @@ lidate */
/* Freescale Book E Implementation Standards (EIS): Software-Use SPRs */
-#define FSL_EIS_SPRG8 604
-#define FSL_EIS_SPRG9 605
+#define FSL_EIS_SPRG8 604
+#define FSL_EIS_SPRG9 605
/* Freescale Book E Implementation Standards (EIS): Debug */
-#define FSL_EIS_DBCR3 561
-#define FSL_EIS_DBCR4 563
-#define FSL_EIS_DBCR5 564
-#define FSL_EIS_DBCR6 603
-#define FSL_EIS_DBCNT 562
+#define FSL_EIS_DBCR3 561
+#define FSL_EIS_DBCR4 563
+#define FSL_EIS_DBCR5 564
+#define FSL_EIS_DBCR6 603
+#define FSL_EIS_DBCNT 562
* @brief Default value for the interrupt disable mask.
1.7.1
