[PATCH 08/15] Restored to pre-PPC440 changes
Ric Claus claus at slac.stanford.edu
Tue Nov 27 03:26:46 UTC 2012
 c/src/lib/libcpu/powerpc/ppc403/clock/clock.c |  158 ++++++++-----------------
 1 files changed, 49 insertions(+), 109 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c b/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c
index d684f12..e5c2b64 100644
--- a/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c
+++ b/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c
@@ -52,18 +52,18 @@
 #include <bsp/vectors.h>
 #include <bsp/irq.h>
-extern uint32_t bsp_clicks_per_usec;
-extern bool bsp_timer_internal_clock;
+extern uint32_t   bsp_clicks_per_usec;
+extern bool       bsp_timer_internal_clock;
-volatile uint32_t   Clock_driver_ticks;
+volatile uint32_t Clock_driver_ticks;
 static uint32_t   pit_value, tick_time;
-static bool auto_restart;
+static bool       auto_restart;
 void Clock_exit( void );
-static inline uint32_t   get_itimer(void)
+static inline uint32_t get_itimer(void)
-  register uint32_t   rc;
+  register uint32_t rc;
 #ifndef ppc405 /* this is a ppc403 */
   __asm__ volatile ("mfspr %0, 0x3dd" : "=r" ((rc))); /* TBLO */
@@ -79,13 +79,13 @@ static inline uint32_t   get_itimer(void)
 void Clock_isr(void* handle)
-  uint32_t   clicks_til_next_interrupt;
+  uint32_t clicks_til_next_interrupt;
 #if defined(BSP_PPC403_CLOCK_ISR_IRQ_LEVEL)
-  uint32_t   l_orig = _ISR_Get_level();
+  uint32_t l_orig = _ISR_Get_level();
 #endif
   if (!auto_restart) {
-    uint32_t   itimer_value;
+    uint32_t itimer_value;
      * setup for next interrupt; making sure the new value is reasonably
      * in the future.... in case we lost out on an interrupt somehow
@@ -106,7 +106,6 @@ void Clock_isr(void* handle)
      * This should only happen if CPU_HPPA_CLICKS_PER_TICK is too small.
      * But setting it low is useful for debug, so...
     if (clicks_til_next_interrupt < 400) {
       tick_time = itimer_value + 1000;
       clicks_til_next_interrupt = 1000;
@@ -117,27 +116,17 @@ void Clock_isr(void* handle)
      * If it is too late, that means we missed the interrupt somehow.
      * Rather than wait 35-50s for a wrap, we just fudge it here.
     if (clicks_til_next_interrupt > pit_value) {
       /* XXX: count these! this should never happen :-) */
-#ifndef ppc440
     __asm__ volatile ("mtspr 0x3db, %0" :: "r"
-                      (clicks_til_next_interrupt)); /* PIT */
-#else
-    __asm__ volatile ("mtspr 0x016, %0" :: "r"
-                      (clicks_til_next_interrupt)); /* Decrementer */
-#endif
+                      (clicks_til_next_interrupt));                  /* PIT */
-#ifndef ppc440
-    __asm__ volatile ( "mtspr 0x3d8, %0" :: "r" (0x08000000)); /* TSR */
-#else /* Book E */
-    __asm__ volatile ( "mtspr 0x150, %0" :: "r" (0x08000000)); /* TSR */
-#endif
+  __asm__ volatile ("mtspr 0x3d8, %0" :: "r" (0x08000000));          /* TSR */
   Clock_driver_ticks++;
@@ -154,121 +143,92 @@ void Clock_isr(void* handle)
 int ClockIsOn(const rtems_irq_connect_data* unused)
-  register uint32_t   tcr;
+  register uint32_t tcr;
-#ifndef ppc440
-  __asm__ volatile ("mfspr %0, 0x3da" : "=r" ((tcr))); /* TCR */
-#else /* Book E */
-  __asm__ volatile ("mfspr %0, 0x154" : "=r" ((tcr))); /* TCR */
-#endif
+  __asm__ volatile ("mfspr %0, 0x3da" : "=r" ((tcr)));               /* TCR */
   return (tcr & 0x04000000) != 0;
 void ClockOff(const rtems_irq_connect_data* unused)
-#ifndef ppc440
   tcr &= ~ 0x04400000;
   __asm__ volatile ("mtspr 0x3da, %0" : "=r" ((tcr)) : "0" ((tcr))); /* TCR */
-#else /* Book E */
-  tcr &= ~ 0x04400000;
-  __asm__ volatile ("mtspr 0x154, %0" : "=r" ((tcr)) : "0" ((tcr))); /* TCR */
-#endif
 void ClockOn(const rtems_irq_connect_data* unused)
-  uint32_t   iocr;
-#ifdef ppc403
-  uint32_t   pvr;
+  uint32_t          iocr;
+#ifndef ppc405
+  uint32_t          pvr;
 #endif /* ppc403 */
   Clock_driver_ticks = 0;
-#ifdef ppc403 /* this is a ppc403 */
-  __asm__ volatile ("mfdcr %0, 0xa0" : "=r" (iocr)); /* IOCR */
+#ifndef ppc405 /* this is a ppc403 */
+  __asm__ volatile ("mfdcr %0, 0xa0" : "=r" (iocr));              /* IOCR */
   if (bsp_timer_internal_clock) {
-    iocr &= ~4; /* timer clocked from system clock */
+    iocr &= ~4;                         /* timer clocked from system clock */
   } else {
-    iocr |= 4; /* select external timer clock */
+    iocr |= 4;                          /* select external timer clock */
   __asm__ volatile ("mtdcr 0xa0, %0" : "=r" (iocr) : "0" (iocr)); /* IOCR */
   __asm__ volatile ("mfspr %0, 0x11f" : "=r" ((pvr))); /* PVR */
   if (((pvr & 0xffff0000) >> 16) != 0x0020)
-    return; /* Not a ppc403 */
+    return;                             /* Not a ppc403 */
-  if ((pvr & 0xff00) == 0x0000) /* 403GA */
+  if ((pvr & 0xff00) == 0x0000)         /* 403GA */
 #if 0 /* FIXME: in which processor versions will "autoload" work properly? */
-   auto_restart = (pvr & 0x00f0) > 0x0000 ? true : false;
+    auto_restart = (pvr & 0x00f0) > 0x0000 ? true : false;
 #else
-   /* no known chip version supports auto restart of timer... */
-   auto_restart = false;
+    /* no known chip version supports auto restart of timer... */
+    auto_restart = false;
 #endif
-   else if ((pvr & 0xff00) == 0x0100) /* 403GB */
-     auto_restart = true;
+  else if ((pvr & 0xff00) == 0x0100)    /* 403GB */
+    auto_restart = true;
-#elif defined(ppc405) /* ppc405 */
-  __asm__ volatile ("mfdcr %0, 0x0b2" : "=r" (iocr));  /*405GP CPC0_CR1 */
+#else /* ppc405 */
+  __asm__ volatile ("mfdcr %0, 0x0b2" : "=r" (iocr));              /*405GP CPC0_CR1 */
-    iocr &=~0x800000; /* timer clocked from system clock CETE */
+    iocr &=~0x800000;               /* timer clocked from system clock CETE*/
   } else {
-    iocr |= 0x800000; /* select external timer clock CETE */
+    iocr |= 0x800000;               /* select external timer clock CETE*/
-  /* 405GP CPC0_CR1 */
-  __asm__ volatile ("mtdcr 0x0b2, %0" : "=r" (iocr) : "0" (iocr));
+  __asm__ volatile ("mtdcr 0x0b2, %0" : "=r" (iocr) : "0" (iocr)); /* 405GP CPC0_CR1 */
    * Enable auto restart
-#else
-  /* PPC440 */
-  __asm__ volatile ("mfspr %0, 0x378" : "=r" (iocr));  /* 440 CCR1 */
-  if (bsp_timer_internal_clock) {
-    iocr &= ~0x00000100;           /* timer clocked from system clock CETE */
-  } else {
-    iocr |= 0x00000100;           /* select external timer clock CETE */
-  __asm__ volatile ("mtspr 0x378, %0" : "=r" (iocr) : "0" (iocr)); /*440 CCR1*/
-#endif
+#endif /* ppc405 */
   pit_value = rtems_configuration_get_microseconds_per_tick() *
    * Set PIT value
-#ifndef ppc440
   __asm__ volatile ("mtspr 0x3db, %0" : : "r" (pit_value)); /* PIT */
-#else /* Book E */
-  __asm__ volatile ("mtspr 0x016, %0" : : "r" (pit_value)); /* Decrementer */
-#endif
-    * Set timer to autoreload, bit TCR->ARE = 1  0x0400000
-    * Enable PIT interrupt, bit TCR->PIE = 1     0x4000000
+   * Set timer to autoreload, bit TCR->ARE = 1  0x0400000
+   * Enable PIT interrupt,    bit TCR->PIE = 1  0x4000000
   tick_time = get_itimer() + pit_value;
-#ifndef ppc440
   tcr = (tcr & ~0x04400000) | (auto_restart ? 0x04400000 : 0x04000000);
+#if 1
-#else /* Book E */
-  tcr = (tcr & ~0x04400000) | (auto_restart ? 0x04400000 : 0x04000000);
 #endif
-void Install_clock(
-  void (*clock_isr)(void *)
+void Install_clock(void (*clock_isr)(void *))
   rtems_irq_connect_data clockIrqConnData;
@@ -284,11 +244,7 @@ void Install_clock(
   clockIrqConnData.on   = ClockOn;
   clockIrqConnData.off  = ClockOff;
   clockIrqConnData.isOn = ClockIsOn;
-#if defined(ppc440) || defined(ppc405)
   clockIrqConnData.name = BSP_PIT;
-#else
-  clockIrqConnData.name = BSP_DECREMENTER;
-#endif
   clockIrqConnData.hdl  = clock_isr;
   if (!BSP_install_rtems_irq_handler (&clockIrqConnData)) {
     printk("Unable to connect Clock Irq handler\n");
@@ -298,20 +254,14 @@ void Install_clock(
   atexit(Clock_exit);
-void ReInstall_clock(
-  void (*new_clock_isr)(void *)
+void ReInstall_clock(void (*new_clock_isr)(void *))
-  uint32_t   isrlevel = 0;
+  uint32_t               isrlevel = 0;
   rtems_interrupt_disable(isrlevel);
-#else
-#endif
   if (!BSP_get_current_rtems_irq_handler(&clockIrqConnData)) {
     printk("Unable to stop system clock\n");
     rtems_fatal_error_occurred(1);
@@ -322,11 +272,7 @@ void ReInstall_clock(
-#else
-#endif
   clockIrqConnData.hdl  = new_clock_isr;
@@ -348,11 +294,7 @@ void Clock_exit(void)
-#else
-#endif
@@ -361,11 +303,9 @@ void Clock_exit(void)
   BSP_remove_rtems_irq_handler (&clockIrqConnData);
-rtems_device_driver Clock_initialize(
-  rtems_device_major_number major,
-  rtems_device_minor_number minor,
-  void *pargp
+rtems_device_driver Clock_initialize(rtems_device_major_number major,
+                                     rtems_device_minor_number minor,
+                                     void *pargp)
   Install_clock( Clock_isr );
1.7.1
