[PATCH 08/15] Restored to pre-PPC440 changes
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Tue Nov 27 06:55:04 UTC 2012
Ric,
when browsing your patches here I got the impression that the PPC440 is
no longer supported with this code. Is this really intended?
wkr,
Thomas.
Am 27.11.2012 04:26, schrieb Ric Claus:
>  c/src/lib/libcpu/powerpc/ppc403/clock/clock.c |  158 ++++++++-----------------
>  1 files changed, 49 insertions(+), 109 deletions(-)
> diff --git a/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c b/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c
> index d684f12..e5c2b64 100644
> --- a/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c
> +++ b/c/src/lib/libcpu/powerpc/ppc403/clock/clock.c
> @@ -52,18 +52,18 @@
>  #include <bsp/vectors.h>
>  #include <bsp/irq.h>
> -extern uint32_t bsp_clicks_per_usec;
> -extern bool bsp_timer_internal_clock;
> +extern uint32_t   bsp_clicks_per_usec;
> +extern bool       bsp_timer_internal_clock;
> -volatile uint32_t   Clock_driver_ticks;
> +volatile uint32_t Clock_driver_ticks;
>  static uint32_t   pit_value, tick_time;
> -static bool auto_restart;
> +static bool       auto_restart;
>  void Clock_exit( void );
> -static inline uint32_t   get_itimer(void)
> +static inline uint32_t get_itimer(void)
> -  register uint32_t   rc;
> +  register uint32_t rc;
>  #ifndef ppc405 /* this is a ppc403 */
>    __asm__ volatile ("mfspr %0, 0x3dd" : "=r" ((rc))); /* TBLO */
> @@ -79,13 +79,13 @@ static inline uint32_t   get_itimer(void)
>  void Clock_isr(void* handle)
> -  uint32_t   clicks_til_next_interrupt;
> +  uint32_t clicks_til_next_interrupt;
>  #if defined(BSP_PPC403_CLOCK_ISR_IRQ_LEVEL)
> -  uint32_t   l_orig = _ISR_Get_level();
> +  uint32_t l_orig = _ISR_Get_level();
>  #endif
>    if (!auto_restart) {
> -    uint32_t   itimer_value;
> +    uint32_t itimer_value;
>       * setup for next interrupt; making sure the new value is reasonably
>       * in the future.... in case we lost out on an interrupt somehow
> @@ -106,7 +106,6 @@ void Clock_isr(void* handle)
>       * This should only happen if CPU_HPPA_CLICKS_PER_TICK is too small.
>       * But setting it low is useful for debug, so...
>      if (clicks_til_next_interrupt < 400) {
>        tick_time = itimer_value + 1000;
>        clicks_til_next_interrupt = 1000;
> @@ -117,27 +116,17 @@ void Clock_isr(void* handle)
>       * If it is too late, that means we missed the interrupt somehow.
>       * Rather than wait 35-50s for a wrap, we just fudge it here.
>      if (clicks_til_next_interrupt > pit_value) {
>        /* XXX: count these! this should never happen :-) */
> -#ifndef ppc440
>      __asm__ volatile ("mtspr 0x3db, %0" :: "r"
> -                      (clicks_til_next_interrupt)); /* PIT */
> -#else
> -    __asm__ volatile ("mtspr 0x016, %0" :: "r"
> -                      (clicks_til_next_interrupt)); /* Decrementer */
> -#endif
> +                      (clicks_til_next_interrupt));                  /* PIT */
> -#ifndef ppc440
> -    __asm__ volatile ( "mtspr 0x3d8, %0" :: "r" (0x08000000)); /* TSR */
> -#else /* Book E */
> -    __asm__ volatile ( "mtspr 0x150, %0" :: "r" (0x08000000)); /* TSR */
> -#endif
> +  __asm__ volatile ("mtspr 0x3d8, %0" :: "r" (0x08000000));          /* TSR */
>    Clock_driver_ticks++;
> @@ -154,121 +143,92 @@ void Clock_isr(void* handle)
>  int ClockIsOn(const rtems_irq_connect_data* unused)
> -  register uint32_t   tcr;
> +  register uint32_t tcr;
> -#ifndef ppc440
> -  __asm__ volatile ("mfspr %0, 0x3da" : "=r" ((tcr))); /* TCR */
> -#else /* Book E */
> -  __asm__ volatile ("mfspr %0, 0x154" : "=r" ((tcr))); /* TCR */
> -#endif
> +  __asm__ volatile ("mfspr %0, 0x3da" : "=r" ((tcr)));               /* TCR */
>    return (tcr & 0x04000000) != 0;
>  void ClockOff(const rtems_irq_connect_data* unused)
> -#ifndef ppc440
>    tcr &= ~ 0x04400000;
>    __asm__ volatile ("mtspr 0x3da, %0" : "=r" ((tcr)) : "0" ((tcr))); /* TCR */
> -#else /* Book E */
> -  tcr &= ~ 0x04400000;
> -  __asm__ volatile ("mtspr 0x154, %0" : "=r" ((tcr)) : "0" ((tcr))); /* TCR */
> -#endif
>  void ClockOn(const rtems_irq_connect_data* unused)
> -  uint32_t   iocr;
> -#ifdef ppc403
> -  uint32_t   pvr;
> +  uint32_t          iocr;
> +#ifndef ppc405
> +  uint32_t          pvr;
>  #endif /* ppc403 */
>    Clock_driver_ticks = 0;
> -#ifdef ppc403 /* this is a ppc403 */
> -  __asm__ volatile ("mfdcr %0, 0xa0" : "=r" (iocr)); /* IOCR */
> +#ifndef ppc405 /* this is a ppc403 */
> +  __asm__ volatile ("mfdcr %0, 0xa0" : "=r" (iocr));              /* IOCR */
>    if (bsp_timer_internal_clock) {
> -    iocr &= ~4; /* timer clocked from system clock */
> +    iocr &= ~4;                         /* timer clocked from system clock */
>    } else {
> -    iocr |= 4; /* select external timer clock */
> +    iocr |= 4;                          /* select external timer clock */
>    __asm__ volatile ("mtdcr 0xa0, %0" : "=r" (iocr) : "0" (iocr)); /* IOCR */
>    __asm__ volatile ("mfspr %0, 0x11f" : "=r" ((pvr))); /* PVR */
>    if (((pvr & 0xffff0000) >> 16) != 0x0020)
> -    return; /* Not a ppc403 */
> +    return;                             /* Not a ppc403 */
> -  if ((pvr & 0xff00) == 0x0000) /* 403GA */
> +  if ((pvr & 0xff00) == 0x0000)         /* 403GA */
>  #if 0 /* FIXME: in which processor versions will "autoload" work properly? */
> -   auto_restart = (pvr & 0x00f0) > 0x0000 ? true : false;
> +    auto_restart = (pvr & 0x00f0) > 0x0000 ? true : false;
>  #else
> -   /* no known chip version supports auto restart of timer... */
> -   auto_restart = false;
> +    /* no known chip version supports auto restart of timer... */
> +    auto_restart = false;
>  #endif
> -   else if ((pvr & 0xff00) == 0x0100) /* 403GB */
> -     auto_restart = true;
> +  else if ((pvr & 0xff00) == 0x0100)    /* 403GB */
> +    auto_restart = true;
> -#elif defined(ppc405) /* ppc405 */
> -  __asm__ volatile ("mfdcr %0, 0x0b2" : "=r" (iocr));  /*405GP CPC0_CR1 */
> +#else /* ppc405 */
> +  __asm__ volatile ("mfdcr %0, 0x0b2" : "=r" (iocr));              /*405GP CPC0_CR1 */
> -    iocr &=~0x800000; /* timer clocked from system clock CETE */
> +    iocr &=~0x800000;               /* timer clocked from system clock CETE*/
>    } else {
> -    iocr |= 0x800000; /* select external timer clock CETE */
> +    iocr |= 0x800000;               /* select external timer clock CETE*/
> -  /* 405GP CPC0_CR1 */
> -  __asm__ volatile ("mtdcr 0x0b2, %0" : "=r" (iocr) : "0" (iocr));
> +  __asm__ volatile ("mtdcr 0x0b2, %0" : "=r" (iocr) : "0" (iocr)); /* 405GP CPC0_CR1 */
>     * Enable auto restart
> -#else
> -  /* PPC440 */
> -  __asm__ volatile ("mfspr %0, 0x378" : "=r" (iocr));  /* 440 CCR1 */
> -  if (bsp_timer_internal_clock) {
> -    iocr &= ~0x00000100;           /* timer clocked from system clock CETE */
> -  } else {
> -    iocr |= 0x00000100;           /* select external timer clock CETE */
> -  __asm__ volatile ("mtspr 0x378, %0" : "=r" (iocr) : "0" (iocr)); /*440 CCR1*/
> -#endif
> +#endif /* ppc405 */
>    pit_value = rtems_configuration_get_microseconds_per_tick() *
>     * Set PIT value
> -#ifndef ppc440
>    __asm__ volatile ("mtspr 0x3db, %0" : : "r" (pit_value)); /* PIT */
> -#else /* Book E */
> -  __asm__ volatile ("mtspr 0x016, %0" : : "r" (pit_value)); /* Decrementer */
> -#endif
> -    * Set timer to autoreload, bit TCR->ARE = 1  0x0400000
> -    * Enable PIT interrupt, bit TCR->PIE = 1     0x4000000
> +   * Set timer to autoreload, bit TCR->ARE = 1  0x0400000
> +   * Enable PIT interrupt,    bit TCR->PIE = 1  0x4000000
>    tick_time = get_itimer() + pit_value;
> -#ifndef ppc440
>    tcr = (tcr & ~0x04400000) | (auto_restart ? 0x04400000 : 0x04000000);
> +#if 1
> -#else /* Book E */
> -  tcr = (tcr & ~0x04400000) | (auto_restart ? 0x04400000 : 0x04000000);
>  #endif
> -void Install_clock(
> -  void (*clock_isr)(void *)
> +void Install_clock(void (*clock_isr)(void *))
>    rtems_irq_connect_data clockIrqConnData;
> @@ -284,11 +244,7 @@ void Install_clock(
>    clockIrqConnData.on   = ClockOn;
>    clockIrqConnData.off  = ClockOff;
>    clockIrqConnData.isOn = ClockIsOn;
> -#if defined(ppc440) || defined(ppc405)
>    clockIrqConnData.name = BSP_PIT;
> -#else
> -  clockIrqConnData.name = BSP_DECREMENTER;
> -#endif
>    clockIrqConnData.hdl  = clock_isr;
>    if (!BSP_install_rtems_irq_handler (&clockIrqConnData)) {
>      printk("Unable to connect Clock Irq handler\n");
> @@ -298,20 +254,14 @@ void Install_clock(
>    atexit(Clock_exit);
> -void ReInstall_clock(
> -  void (*new_clock_isr)(void *)
> +void ReInstall_clock(void (*new_clock_isr)(void *))
> -  uint32_t   isrlevel = 0;
> +  uint32_t               isrlevel = 0;
>    rtems_interrupt_disable(isrlevel);
> -#else
> -#endif
>    if (!BSP_get_current_rtems_irq_handler(&clockIrqConnData)) {
>      printk("Unable to stop system clock\n");
>      rtems_fatal_error_occurred(1);
> @@ -322,11 +272,7 @@ void ReInstall_clock(
> -#else
> -#endif
>    clockIrqConnData.hdl  = new_clock_isr;
> @@ -348,11 +294,7 @@ void Clock_exit(void)
> -#else
> -#endif
> @@ -361,11 +303,9 @@ void Clock_exit(void)
>    BSP_remove_rtems_irq_handler (&clockIrqConnData);
> -rtems_device_driver Clock_initialize(
> -  rtems_device_major_number major,
> -  rtems_device_minor_number minor,
> -  void *pargp
> +rtems_device_driver Clock_initialize(rtems_device_major_number major,
> +                                     rtems_device_minor_number minor,
> +                                     void *pargp)
>    Install_clock( Clock_isr );
embedded brains GmbH
Thomas Doerfler
Obere Lagerstrasse 30
D-82178 Puchheim
Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax: +49-89-18908079-9
PGP: Public key available on request.
