[PATCH 03/23] sptests/spfatal07: Use confdefs.h to trigger test
Sebastian Huber
Tue Nov 6 12:56:25 UTC 2012
testsuites/sptests/spfatal07/testcase.h | 9 +++++----
1 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/testsuites/sptests/spfatal07/testcase.h b/testsuites/sptests/spfatal07/testcase.h
index 77ef6e8..e05c7ce 100644
--- a/testsuites/sptests/spfatal07/testcase.h
+++ b/testsuites/sptests/spfatal07/testcase.h
@@ -41,11 +41,14 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
#define CONFIGURE_MEMORY_OVERHEAD (sizeof(ISR_Handler_entry) * ISR_NUMBER_OF_VECTORS)
#endif
+#if CPU_ALLOCATE_INTERRUPT_STACK == TRUE
+ #define CONFIGURE_INTERRUPT_STACK_SIZE (STACK_MINIMUM_SIZE - 1)
+#endif
void force_error()
#if (CPU_ALLOCATE_INTERRUPT_STACK == TRUE)
- Configuration.interrupt_stack_size = (STACK_MINIMUM_SIZE-1);
- _ISR_Handler_initialization();
+ /* we will not run this far */
#else
printk(
"WARNING - Test not applicable on this target architecture.\n"
@@ -54,6 +57,4 @@ void force_error()
rtems_test_exit(0);
#endif
- /* we will not run this far */
1.7.7
