[PATCH 04/23] sapi: Use rtems_configuration_get_maximum_drivers
Tue Nov 6 12:56:26 UTC 2012
 cpukit/sapi/include/rtems/config.h |    3 +++
 cpukit/sapi/src/io.c               |    2 +-
 2 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/cpukit/sapi/include/rtems/config.h b/cpukit/sapi/include/rtems/config.h
index d0e181c..494effc 100644
--- a/cpukit/sapi/include/rtems/config.h
+++ b/cpukit/sapi/include/rtems/config.h
@@ -320,6 +320,9 @@ extern rtems_configuration_table    Configuration;
 #define rtems_configuration_get_do_zero_of_workspace() \
    (Configuration.do_zero_of_workspace)
+#define rtems_configuration_get_maximum_drivers() \
+        (Configuration.maximum_drivers)
 #define rtems_configuration_get_number_of_device_drivers() \
         (Configuration.number_of_device_drivers)
diff --git a/cpukit/sapi/src/io.c b/cpukit/sapi/src/io.c
index 1bcb045..679bae5 100644
--- a/cpukit/sapi/src/io.c
+++ b/cpukit/sapi/src/io.c
@@ -40,7 +40,7 @@ void _IO_Manager_initialization(void)
   driver_table      = Configuration.Device_driver_table;
   drivers_in_table  = Configuration.number_of_device_drivers;
-  number_of_drivers = Configuration.maximum_drivers;
+  number_of_drivers = rtems_configuration_get_maximum_drivers();
    *  If the user claims there are less drivers than are actually in
1.7.7
