PowerPC Book E ESR missing from exception frame
Fri Nov 23 08:15:49 UTC 2012
On 11/22/2012 08:02 PM, Claus, Ric wrote:
> On the PPC 405 and PPC 440, it is often useful to look at the Exception Syndrome Register (SPR 62), especially after a program exception.  Would the PowerPC gurus please comment on why it is missing from the register dump and/or whether it would be agreeable to add it?  I volunteer to do the work.
I moved the register dump to the new ppc_exc_print_frame_and_context() function:
http://git.rtems.org/rtems/commit/?id=7e32b62a59ae91d67096c03b592dfd691ab32214
The default action during an unexpected exception is now to print nothing and
reset the target.
You can add custom fatal handlers, for example:
#include <bsp/vectors.h>
static void fatal_extension(
   rtems_fatal_source source,
   bool is_internal,
   rtems_fatal_code code
   if ( source == RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION ) {
     const BSP_Exception_frame *frame =
       (const BSP_Exception_frame *) code;
     ppc_exc_print_frame_and_context( frame );
#define CONFIGURE_INIT
#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
#include <rtems/confdefs.h>
You can add the Exception Syndrome Register to
ppc_exc_print_frame_and_context(), but please check that this register is
available, otherwise we have the next exception and so on.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
