[PATCH] score: Add CPU_Exception_frame
Sun Nov 25 21:07:56 UTC 2012
Is there a difference between CPU_Interrupt_frame and CPU_Exception_frame?
I think Interrupt_frame has been more commonly used; most of these
architectures have a CPU_Interrupt_frame defined. Instead of
defaulting CPU_Exception_frame to an empty struct, maybe we should
   typedef CPU_Exception_frame CPU_Interrupt_frame;
-Gedare
On Sun, Nov 25, 2012 at 11:48 AM, Sebastian Huber
> Add CPU port type CPU_Exception_frame and function
> _CPU_Exception_frame_print().
> The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
> sparc64, and v850 use an empty default implementation of
> Add rtems_exception_frame and rtems_exception_frame_print().
> Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions.  Use rtems_fatal()
> with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
> and sparc for unexpected exceptions.
> The powerpc port uses now a unified CPU_Exception_frame.  This resulted
> in a CPU_Exception_frame layout change for the MPC5XX.
> Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
> BSP_PRINT_EXCEPTION_CONTEXT define used in the default
> bsp_fatal_extension().
> Add test sptests/spfatal26.
>  c/src/aclocal/bsp-bspcleanup-options.m4            |    7 +-
>  .../lib/libbsp/mips/shared/irq/vectorexceptions.c  |    6 +-
>  c/src/lib/libbsp/powerpc/psim/configure.ac         |    2 +-
>  c/src/lib/libbsp/shared/bspclean.c                 |    8 +-
>  c/src/lib/libbsp/sparc/erc32/configure.ac          |    2 +-
>  c/src/lib/libbsp/sparc/erc32/startup/spurious.c    |   37 +++---
>  c/src/lib/libbsp/sparc/leon2/startup/spurious.c    |   37 +++---
>  c/src/lib/libbsp/sparc/leon3/startup/spurious.c    |   38 ++++---
>  c/src/lib/libcpu/powerpc/Makefile.am               |    3 +-
>  c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h  |  120 +++++++-------------
>  .../bspsupport/ppc_exc_global_handler.c            |    2 +-
>  .../new-exceptions/bspsupport/ppc_exc_initialize.c |   55 +++++++++
>  .../new-exceptions/bspsupport/ppc_exc_print.c      |    2 +-
>  .../powerpc/new-exceptions/bspsupport/vectors.h    |   51 +--------
>  cpukit/sapi/include/rtems/fatal.h                  |   17 +++
>  cpukit/score/cpu/arm/Makefile.am                   |    2 +
>  cpukit/score/cpu/arm/arm-exception-frame-print.c   |   28 +++++
>  .../score/cpu/arm/armv7m-exception-frame-print.c   |   28 +++++
>  cpukit/score/cpu/arm/rtems/score/cpu.h             |    5 +
>  cpukit/score/cpu/avr/Makefile.am                   |    1 +
>  cpukit/score/cpu/avr/avr-exception-frame-print.c   |   24 ++++
>  cpukit/score/cpu/avr/rtems/score/cpu.h             |    5 +
>  cpukit/score/cpu/bfin/Makefile.am                  |    1 +
>  cpukit/score/cpu/bfin/bfin-exception-frame-print.c |   24 ++++
>  cpukit/score/cpu/bfin/rtems/score/cpu.h            |    5 +
>  cpukit/score/cpu/h8300/Makefile.am                 |    1 +
>  .../score/cpu/h8300/h8300-exception-frame-print.c  |   24 ++++
>  cpukit/score/cpu/h8300/rtems/score/cpu.h           |    5 +
>  cpukit/score/cpu/i386/cpu.c                        |   12 +-
>  cpukit/score/cpu/i386/rtems/score/cpu.h            |    2 +
>  cpukit/score/cpu/lm32/Makefile.am                  |    1 +
>  cpukit/score/cpu/lm32/lm32-exception-frame-print.c |   24 ++++
>  cpukit/score/cpu/lm32/rtems/score/cpu.h            |    5 +
>  cpukit/score/cpu/m32c/Makefile.am                  |    1 +
>  cpukit/score/cpu/m32c/m32c-exception-frame-print.c |   24 ++++
>  cpukit/score/cpu/m32c/rtems/score/cpu.h            |    5 +
>  cpukit/score/cpu/m32r/Makefile.am                  |    1 +
>  cpukit/score/cpu/m32r/m32r-exception-frame-print.c |   24 ++++
>  cpukit/score/cpu/m32r/rtems/score/cpu.h            |    5 +
>  cpukit/score/cpu/m68k/Makefile.am                  |    1 +
>  cpukit/score/cpu/m68k/m68k-exception-frame-print.c |   24 ++++
>  cpukit/score/cpu/m68k/rtems/score/cpu.h            |    2 +
>  cpukit/score/cpu/mips/rtems/score/cpu.h            |   13 +++
>  cpukit/score/cpu/nios2/Makefile.am                 |    1 +
>  .../score/cpu/nios2/nios2-exception-frame-print.c  |   24 ++++
>  cpukit/score/cpu/nios2/rtems/score/cpu.h           |    2 +
>  cpukit/score/cpu/no_cpu/rtems/score/cpu.h          |   13 +++
>  cpukit/score/cpu/powerpc/rtems/score/cpu.h         |   57 ++++++++++
>  cpukit/score/cpu/sh/Makefile.am                    |    1 +
>  cpukit/score/cpu/sh/rtems/score/cpu.h              |    4 +
>  cpukit/score/cpu/sh/sh-exception-frame-print.c     |   24 ++++
>  cpukit/score/cpu/sparc/rtems/score/cpu.h           |   14 +++
>  cpukit/score/cpu/sparc64/Makefile.am               |    1 +
>  cpukit/score/cpu/sparc64/rtems/score/cpu.h         |    5 +
>  .../cpu/sparc64/sparc64-exception-frame-print.c    |   24 ++++
>  cpukit/score/cpu/v850/Makefile.am                  |    1 +
>  cpukit/score/cpu/v850/rtems/score/cpu.h            |    5 +
>  cpukit/score/cpu/v850/v850-exception-frame-print.c |   24 ++++
>  cpukit/score/include/rtems/score/interr.h          |    6 +-
>  doc/user/fatal.t                                   |   27 +++++
>  testsuites/sptests/Makefile.am                     |    1 +
>  testsuites/sptests/configure.ac                    |    1 +
>  testsuites/sptests/spfatal26/Makefile.am           |   19 ++++
>  testsuites/sptests/spfatal26/init.c                |   85 ++++++++++++++
>  testsuites/sptests/spfatal26/spfatal26.doc         |   11 ++
>  testsuites/sptests/spfatal26/spfatal26.scn         |    2 +
>  66 files changed, 838 insertions(+), 198 deletions(-)
>  create mode 100644 cpukit/score/cpu/arm/arm-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/arm/armv7m-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/avr/avr-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/bfin/bfin-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/h8300/h8300-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/lm32/lm32-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/m32c/m32c-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/m32r/m32r-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/m68k/m68k-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/nios2/nios2-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/sh/sh-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/v850/v850-exception-frame-print.c
>  create mode 100644 testsuites/sptests/spfatal26/Makefile.am
>  create mode 100644 testsuites/sptests/spfatal26/init.c
>  create mode 100644 testsuites/sptests/spfatal26/spfatal26.doc
>  create mode 100644 testsuites/sptests/spfatal26/spfatal26.scn
> diff --git a/c/src/aclocal/bsp-bspcleanup-options.m4 b/c/src/aclocal/bsp-bspcleanup-options.m4
> index cac8d55..00bc0fb 100644
> --- a/c/src/aclocal/bsp-bspcleanup-options.m4
> +++ b/c/src/aclocal/bsp-bspcleanup-options.m4
> @@ -9,10 +9,11 @@ dnl
>  dnl To be used in bsp-configure scripts
>  dnl USAGE:
> -dnl    RTEMS_BSP_CLEANUP_OPTIONS([0|1], [0|1])
> +dnl    RTEMS_BSP_CLEANUP_OPTIONS([0|1], [0|1], [0|1])
>  dnl WHERE:
>  dnl    argument 1 indicates the default value for BSP_PRESS_KEY_FOR_RESET
>  dnl    argument 2 indicates the default value for BSP_RESET_BOARD_AT_EXIT
> +dnl    argument 3 indicates the default value for BSP_PRINT_EXCEPTION_CONTEXT
>  AC_DEFUN([RTEMS_BSP_CLEANUP_OPTIONS],[
>  RTEMS_BSPOPTS_SET([BSP_PRESS_KEY_FOR_RESET],[*],[$1])
> @@ -23,4 +24,8 @@ RTEMS_BSPOPTS_HELP([BSP_PRESS_KEY_FOR_RESET],
>  RTEMS_BSPOPTS_SET([BSP_RESET_BOARD_AT_EXIT],[*],[$2])
>  RTEMS_BSPOPTS_HELP([BSP_RESET_BOARD_AT_EXIT],
>  [If defined, reset the board when the application exits.])
> +RTEMS_BSPOPTS_SET([BSP_PRINT_EXCEPTION_CONTEXT],[*],[$3])
> +RTEMS_BSPOPTS_HELP([BSP_PRINT_EXCEPTION_CONTEXT],
> +[If defined, prints the exception context when an unexpected exception occurs.])
> diff --git a/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c b/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c
> index 91ecf33..e0e175c 100644
> --- a/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c
> +++ b/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c
> @@ -24,9 +24,7 @@
>  #include <rtems/bspIo.h>
>  #include <bsp/irq-generic.h>
> -void mips_vector_exceptions( CPU_Interrupt_frame *frame );
> -static const char *cause_strings[32] =
> +static const char *const cause_strings[32] =
>    /*  0 */ "Int",
>    /*  1 */ "TLB Mods",
> @@ -79,7 +77,7 @@ static const struct regdef dumpregs[]= {
>    { R_EPC,"R_EPC"}, { -1, NULL }
> -static void mips_dump_exception_frame( CPU_Interrupt_frame *frame )
> +void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
>    uint32_t *frame_u32;
>    int   i, j;
> diff --git a/c/src/lib/libbsp/powerpc/psim/configure.ac b/c/src/lib/libbsp/powerpc/psim/configure.ac
> index c21b7ec..4d6c453 100644
> --- a/c/src/lib/libbsp/powerpc/psim/configure.ac
> +++ b/c/src/lib/libbsp/powerpc/psim/configure.ac
> @@ -45,7 +45,7 @@ Note that the policy can still be defined by the application
>  CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is removed
>  and a little memory is saved.])
> -RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
> +RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 1)
>  # Explicitly list all Makefiles here
>  AC_CONFIG_FILES([Makefile])
> diff --git a/c/src/lib/libbsp/shared/bspclean.c b/c/src/lib/libbsp/shared/bspclean.c
> index 1d6f08a..3e48c29 100644
> --- a/c/src/lib/libbsp/shared/bspclean.c
> +++ b/c/src/lib/libbsp/shared/bspclean.c
> @@ -16,7 +16,7 @@
>  void bsp_fatal_extension(
>    rtems_fatal_source source,
>    bool is_internal,
> -  rtems_fatal_code error
> +  rtems_fatal_code code
>    #if (BSP_PRESS_KEY_FOR_RESET)
> @@ -31,6 +31,12 @@ void bsp_fatal_extension(
>      printk("\n");
>    #endif
> +  #if (BSP_PRINT_EXCEPTION_CONTEXT)
> +    if ( source == RTEMS_FATAL_SOURCE_EXCEPTION ) {
> +      rtems_exception_frame_print( (const rtems_exception_frame *) code );
> +  #endif
>     *  Check both conditions -- if you want to ask for reboot, then
>     *  you must have meant to reset the board.
> diff --git a/c/src/lib/libbsp/sparc/erc32/configure.ac b/c/src/lib/libbsp/sparc/erc32/configure.ac
> index 5f1317c..8155514 100644
> --- a/c/src/lib/libbsp/sparc/erc32/configure.ac
> +++ b/c/src/lib/libbsp/sparc/erc32/configure.ac
> @@ -42,7 +42,7 @@ RTEMS_BSPOPTS_HELP([ENABLE_SIS_QUIRKS],
>   BSP will be enabled.  In particular, SIS requires special
>   initialization not used on real ERC32 hardware.])
> -RTEMS_BSP_CLEANUP_OPTIONS(0,1)
> +RTEMS_BSP_CLEANUP_OPTIONS(0,1,1)
> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> index bbf6cca..b74f0c7 100644
> --- a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> @@ -16,20 +16,15 @@
>  #include <bsp.h>
> - *  bsp_spurious_handler
> - *  Print a message on the debug console and then die
> -rtems_isr bsp_spurious_handler(
> -   rtems_vector_number trap,
> -   CPU_Interrupt_frame *isf
> -  uint32_t         real_trap;
> +  uint32_t                   trap;
> +  uint32_t                   real_trap;
> +  const CPU_Interrupt_frame *isf;
> +  trap = frame->trap;
>    real_trap = SPARC_REAL_TRAP_NUMBER(trap);
> +  isf = frame->isf;
>    printk( "Unexpected trap (%2d) at address 0x%08x\n", real_trap, isf->tpc);
> @@ -121,12 +116,22 @@ rtems_isr bsp_spurious_handler(
>      default:
>        break;
> -   *  What else can we do but stop ...
> -  __asm__ volatile( "mov 1, %g1; ta 0x0" );
> +rtems_isr bsp_spurious_handler(
> +   rtems_vector_number trap,
> +   CPU_Interrupt_frame *isf
> +  CPU_Exception_frame frame = {
> +    .trap = trap,
> +    .isf = isf
> +  rtems_fatal(
> +    RTEMS_FATAL_SOURCE_EXCEPTION,
> +    (rtems_fatal_code) &frame
> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> index c4bdf79..c0500c7 100644
> --- a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> @@ -16,20 +16,15 @@
>  #include <bsp.h>
> +  uint32_t                   trap;
> +  isf = frame->isf;
> @@ -102,12 +97,22 @@ rtems_isr bsp_spurious_handler(
>      default:
>        break;
> +    .trap = trap,
> +    .isf = isf
> +  rtems_fatal(
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> index f060e28..e12ac01 100644
> --- a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> @@ -18,23 +18,17 @@
>  #include <bsp.h>
> +  uint32_t                   trap;
> +  isf = frame->isf;
>    printk( "Unexpected trap (0x%02x) at address 0x%08x\n", real_trap, isf->tpc);
> @@ -113,12 +107,22 @@ rtems_isr bsp_spurious_handler(
>      default:
>        break;
> +    .trap = trap,
> +    .isf = isf
> +  rtems_fatal(
> diff --git a/c/src/lib/libcpu/powerpc/Makefile.am b/c/src/lib/libcpu/powerpc/Makefile.am
> index 4401b5f..febcc6b 100644
> --- a/c/src/lib/libcpu/powerpc/Makefile.am
> +++ b/c/src/lib/libcpu/powerpc/Makefile.am
> @@ -188,7 +188,8 @@ mpc5xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>  include_libcpu_HEADERS += mpc5xx/vectors/vectors.h
>  noinst_PROGRAMS += mpc5xx/vectors.rel
> -mpc5xx_vectors_rel_SOURCES = mpc5xx/vectors/vectors_init.c mpc5xx/vectors/vectors.S
> +mpc5xx_vectors_rel_SOURCES = mpc5xx/vectors/vectors_init.c mpc5xx/vectors/vectors.S \
> +    new-exceptions/bspsupport/ppc_exc_print.c
>  mpc5xx_vectors_rel_CPPFLAGS = $(AM_CPPFLAGS)
>  mpc5xx_vectors_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>  endif
> diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h b/c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h
> index 217c41d..c88e296 100644
> --- a/c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h
> +++ b/c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h
> @@ -34,43 +34,44 @@
>  #define SRR0_FRAME_OFFSET 8
>  #define SRR1_FRAME_OFFSET 12
>  #define EXCEPTION_NUMBER_OFFSET 16
> -#define GPR0_OFFSET 20
> -#define GPR1_OFFSET 24
> -#define GPR2_OFFSET 28
> -#define GPR3_OFFSET 32
> -#define GPR4_OFFSET 36
> -#define GPR5_OFFSET 40
> -#define GPR6_OFFSET 44
> -#define GPR7_OFFSET 48
> -#define GPR8_OFFSET 52
> -#define GPR9_OFFSET 56
> -#define GPR10_OFFSET 60
> -#define GPR11_OFFSET 64
> -#define GPR12_OFFSET 68
> -#define GPR13_OFFSET 72
> -#define GPR14_OFFSET 76
> -#define GPR15_OFFSET 80
> -#define GPR16_OFFSET 84
> -#define GPR17_OFFSET 88
> -#define GPR18_OFFSET 92
> -#define GPR19_OFFSET 96
> -#define GPR20_OFFSET 100
> -#define GPR21_OFFSET 104
> -#define GPR22_OFFSET 108
> -#define GPR23_OFFSET 112
> -#define GPR24_OFFSET 116
> -#define GPR25_OFFSET 120
> -#define GPR26_OFFSET 124
> -#define GPR27_OFFSET 128
> -#define GPR28_OFFSET 132
> -#define GPR29_OFFSET 136
> -#define GPR30_OFFSET 140
> -#define GPR31_OFFSET 144
> -#define EXC_CR_OFFSET 148
> -#define EXC_CTR_OFFSET 152
> -#define EXC_XER_OFFSET 156
> -#define EXC_LR_OFFSET 160
> -#define EXC_DAR_OFFSET 164
> +#define EXC_CR_OFFSET 20
> +#define EXC_CTR_OFFSET 24
> +#define EXC_XER_OFFSET 28
> +#define EXC_LR_OFFSET 32
> +#define GPR0_OFFSET 36
> +#define GPR1_OFFSET 40
> +#define GPR2_OFFSET 44
> +#define GPR3_OFFSET 48
> +#define GPR4_OFFSET 52
> +#define GPR5_OFFSET 56
> +#define GPR6_OFFSET 60
> +#define GPR7_OFFSET 64
> +#define GPR8_OFFSET 68
> +#define GPR9_OFFSET 72
> +#define GPR10_OFFSET 76
> +#define GPR11_OFFSET 80
> +#define GPR12_OFFSET 84
> +#define GPR13_OFFSET 88
> +#define GPR14_OFFSET 92
> +#define GPR15_OFFSET 96
> +#define GPR16_OFFSET 100
> +#define GPR17_OFFSET 104
> +#define GPR18_OFFSET 108
> +#define GPR19_OFFSET 112
> +#define GPR20_OFFSET 116
> +#define GPR21_OFFSET 120
> +#define GPR22_OFFSET 124
> +#define GPR23_OFFSET 128
> +#define GPR24_OFFSET 132
> +#define GPR25_OFFSET 136
> +#define GPR26_OFFSET 140
> +#define GPR27_OFFSET 144
> +#define GPR28_OFFSET 148
> +#define GPR29_OFFSET 152
> +#define GPR30_OFFSET 156
> +#define GPR31_OFFSET 160
> +#define EXC_MSR_OFFSET 164
> +#define EXC_DAR_OFFSET 168
>   * maintain the EABI requested 8 bytes aligment
>   * As SVR4 ABI requires 16, make it 16 (as some
> @@ -87,51 +88,6 @@ extern       void default_exception_vector_code_prolog();
>  extern int  default_exception_vector_code_prolog_size;
>  extern  void initialize_exceptions();
> -typedef struct {
> -  unsigned     EXC_SRR0;
> -  unsigned     EXC_SRR1;
> -  unsigned     _EXC_number;
> -  unsigned     GPR0;
> -  unsigned     GPR1;
> -  unsigned     GPR2;
> -  unsigned     GPR3;
> -  unsigned     GPR4;
> -  unsigned     GPR5;
> -  unsigned     GPR6;
> -  unsigned     GPR7;
> -  unsigned     GPR8;
> -  unsigned     GPR9;
> -  unsigned     GPR10;
> -  unsigned     GPR11;
> -  unsigned     GPR12;
> -  unsigned     GPR13;
> -  unsigned     GPR14;
> -  unsigned     GPR15;
> -  unsigned     GPR16;
> -  unsigned     GPR17;
> -  unsigned     GPR18;
> -  unsigned     GPR19;
> -  unsigned     GPR20;
> -  unsigned     GPR21;
> -  unsigned     GPR22;
> -  unsigned     GPR23;
> -  unsigned     GPR24;
> -  unsigned     GPR25;
> -  unsigned     GPR26;
> -  unsigned     GPR27;
> -  unsigned     GPR28;
> -  unsigned     GPR29;
> -  unsigned     GPR30;
> -  unsigned     GPR31;
> -  unsigned     EXC_CR;
> -  unsigned     EXC_CTR;
> -  unsigned     EXC_XER;
> -  unsigned     EXC_LR;
> -  unsigned     EXC_MSR;
> -  unsigned     EXC_DAR;
> -}CPU_Exception_frame;
>  typedef void rtems_exception_handler_t (CPU_Exception_frame* excPtr);
>  /*DEBUG typedef rtems_exception_handler_t cpuExcHandlerType; */
> diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c
> index 255e401..008611c 100644
> --- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c
> +++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c
> @@ -24,7 +24,7 @@ exception_handler_t globalExceptHdl = C_exception_handler;
>  void C_exception_handler(BSP_Exception_frame *excPtr)
>    rtems_fatal(
> -    RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION,
>      (rtems_fatal_code) excPtr
> diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
> index d9bb872..121a4c1 100644
> --- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
> +++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
> @@ -27,6 +27,61 @@
>  #include <bsp/vectors.h>
>  #include <bsp/bootcard.h>
> +#define PPC_EXC_ASSERT_OFFSET(field, off) \
> +  RTEMS_STATIC_ASSERT( \
> +    offsetof(CPU_Exception_frame, field) + 8 == off, \
> +    CPU_Exception_frame_offset_ ## field \
> +#define PPC_EXC_ASSERT_CANONIC_OFFSET(field) \
> +  PPC_EXC_ASSERT_OFFSET(field, field ## _OFFSET)
> +PPC_EXC_ASSERT_OFFSET(EXC_SRR0, SRR0_FRAME_OFFSET);
> +PPC_EXC_ASSERT_OFFSET(EXC_SRR1, SRR1_FRAME_OFFSET);
> +PPC_EXC_ASSERT_OFFSET(_EXC_number, EXCEPTION_NUMBER_OFFSET);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(EXC_CR);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(EXC_CTR);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(EXC_XER);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(EXC_LR);
> +#ifdef __SPE__
> +  PPC_EXC_ASSERT_OFFSET(EXC_SPEFSCR, PPC_EXC_SPEFSCR);
> +  PPC_EXC_ASSERT_OFFSET(EXC_ACC, PPC_EXC_ACC);
> +#endif
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR0);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR1);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR2);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR3);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR4);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR5);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR6);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR7);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR8);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR9);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR10);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR11);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR12);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR13);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR14);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR15);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR16);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR17);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR18);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR19);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR20);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR21);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR22);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR23);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR24);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR25);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR26);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR27);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR28);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR29);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR30);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(GPR31);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(EXC_MSR);
> +PPC_EXC_ASSERT_CANONIC_OFFSET(EXC_DAR);
>  uint32_t ppc_exc_cache_wb_check = 1;
>  #define MTIVPR(prefix) __asm__ volatile ("mtivpr %0" : : "r" (prefix))
> diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
> index e1bbf12..34233ba 100644
> --- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
> +++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
> @@ -85,7 +85,7 @@ void BSP_printStackTrace(const BSP_Exception_frame *excPtr)
> -void ppc_exc_print_frame_and_context(const BSP_Exception_frame *excPtr)
> +void _BSP_Exception_frame_print(const CPU_Exception_frame *excPtr)
>    const Thread_Control *executing = _Thread_Executing;
>    bool synch = (int) excPtr->_EXC_number >= 0;
> diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
> index e62dfbd..b103dec 100644
> --- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
> +++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
> @@ -248,53 +248,7 @@ extern "C" {
> -typedef struct {
> -  unsigned EXC_CR;
> -  unsigned EXC_CTR;
> -  unsigned EXC_XER;
> -  unsigned EXC_LR;
> -  #ifdef __SPE__
> -    uint32_t EXC_SPEFSCR;
> -    uint64_t EXC_ACC;
> -  #endif
> -  PPC_GPR_TYPE GPR0;
> -  PPC_GPR_TYPE GPR1;
> -  PPC_GPR_TYPE GPR2;
> -  PPC_GPR_TYPE GPR3;
> -  PPC_GPR_TYPE GPR4;
> -  PPC_GPR_TYPE GPR5;
> -  PPC_GPR_TYPE GPR6;
> -  PPC_GPR_TYPE GPR7;
> -  PPC_GPR_TYPE GPR8;
> -  PPC_GPR_TYPE GPR9;
> -  PPC_GPR_TYPE GPR10;
> -  PPC_GPR_TYPE GPR11;
> -  PPC_GPR_TYPE GPR12;
> -  PPC_GPR_TYPE GPR13;
> -  PPC_GPR_TYPE GPR14;
> -  PPC_GPR_TYPE GPR15;
> -  PPC_GPR_TYPE GPR16;
> -  PPC_GPR_TYPE GPR17;
> -  PPC_GPR_TYPE GPR18;
> -  PPC_GPR_TYPE GPR19;
> -  PPC_GPR_TYPE GPR20;
> -  PPC_GPR_TYPE GPR21;
> -  PPC_GPR_TYPE GPR22;
> -  PPC_GPR_TYPE GPR23;
> -  PPC_GPR_TYPE GPR24;
> -  PPC_GPR_TYPE GPR25;
> -  PPC_GPR_TYPE GPR26;
> -  PPC_GPR_TYPE GPR27;
> -  PPC_GPR_TYPE GPR28;
> -  PPC_GPR_TYPE GPR29;
> -  PPC_GPR_TYPE GPR30;
> -  PPC_GPR_TYPE GPR31;
> -  unsigned EXC_MSR;
> -  unsigned EXC_DAR;
> -} BSP_Exception_frame;
> +typedef CPU_Exception_frame BSP_Exception_frame;
> @@ -319,8 +273,6 @@ extern exception_handler_t globalExceptHdl;
>  void C_exception_handler(BSP_Exception_frame* excPtr);
> -void ppc_exc_print_frame_and_context(const BSP_Exception_frame *excPtr);
>  void BSP_printStackTrace(const BSP_Exception_frame *excPtr);
> @@ -538,7 +490,6 @@ int ppc_exc_alignment_handler(BSP_Exception_frame *frame, unsigned excNum);
>   * Compatibility with pc386
> -typedef BSP_Exception_frame CPU_Exception_frame;
>  typedef exception_handler_t cpuExcHandlerType;
>  #endif /* ASM */
> diff --git a/cpukit/sapi/include/rtems/fatal.h b/cpukit/sapi/include/rtems/fatal.h
> index 6692605..64344b3 100644
> --- a/cpukit/sapi/include/rtems/fatal.h
> +++ b/cpukit/sapi/include/rtems/fatal.h
> @@ -37,6 +37,23 @@ extern "C" {
> + * @brief Exception frame.
> +typedef CPU_Exception_frame rtems_exception_frame;
> + *  @brief Prints the exception frame via printk().
> + *  @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
> +static inline void rtems_exception_frame_print(
> +  const rtems_exception_frame *frame
> +  _CPU_Exception_frame_print( frame );
>   * @brief Invokes the internal error handler with a source of
>   * INTERNAL_ERROR_RTEMS_API and is internal set to false.
> diff --git a/cpukit/score/cpu/arm/Makefile.am b/cpukit/score/cpu/arm/Makefile.am
> index 0da1984..f0ddbd6 100644
> --- a/cpukit/score/cpu/arm/Makefile.am
> +++ b/cpukit/score/cpu/arm/Makefile.am
> @@ -18,9 +18,11 @@ libscorecpu_a_SOURCES += arm_exc_abort.S
>  libscorecpu_a_SOURCES += arm_exc_interrupt.S
>  libscorecpu_a_SOURCES += arm_exc_handler_low.S
>  libscorecpu_a_SOURCES += arm_exc_handler_high.c
> +libscorecpu_a_SOURCES += arm-exception-frame-print.c
>  libscorecpu_a_SOURCES += armv7m-context-initialize.c
>  libscorecpu_a_SOURCES += armv7m-context-restore.c
>  libscorecpu_a_SOURCES += armv7m-context-switch.c
> +libscorecpu_a_SOURCES += armv7m-exception-frame-print.c
>  libscorecpu_a_SOURCES += armv7m-exception-handler-get.c
>  libscorecpu_a_SOURCES += armv7m-exception-handler-set.c
>  libscorecpu_a_SOURCES += armv7m-exception-priority-get.c
> diff --git a/cpukit/score/cpu/arm/arm-exception-frame-print.c b/cpukit/score/cpu/arm/arm-exception-frame-print.c
> new file mode 100644
> index 0000000..4d89f69
> --- /dev/null
> +++ b/cpukit/score/cpu/arm/arm-exception-frame-print.c
> @@ -0,0 +1,28 @@
> + * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Obere Lagerstr. 30
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/score/cpu.h>
> +#ifdef ARM_MULTILIB_ARCH_V4
> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> +  /* TODO */
> +#endif /* ARM_MULTILIB_ARCH_V4 */
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-frame-print.c b/cpukit/score/cpu/arm/armv7m-exception-frame-print.c
> index 0000000..86931b2
> --- /dev/null
> +++ b/cpukit/score/cpu/arm/armv7m-exception-frame-print.c
> @@ -0,0 +1,28 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +#ifdef ARM_MULTILIB_ARCH_V7M
> +  /* TODO */
> +#endif /* ARM_MULTILIB_ARCH_V7M */
> diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
> index 1528533..b7666ad 100644
> --- a/cpukit/score/cpu/arm/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
> @@ -580,10 +580,15 @@ typedef CPU_Exception_frame CPU_Interrupt_frame;
>  #else /* !defined(ARM_MULTILIB_ARCH_V4) */
> +typedef struct {
> +} CPU_Exception_frame;
>  typedef void CPU_Interrupt_frame;
>  #endif /* !defined(ARM_MULTILIB_ARCH_V4) */
> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
>  #ifdef __cplusplus
>  #endif
> diff --git a/cpukit/score/cpu/avr/Makefile.am b/cpukit/score/cpu/avr/Makefile.am
> index 4079b69..efaf36e 100644
> --- a/cpukit/score/cpu/avr/Makefile.am
> +++ b/cpukit/score/cpu/avr/Makefile.am
> @@ -161,6 +161,7 @@ include_rtems_avr_HEADERS += avr/wdt.h
>  noinst_LIBRARIES = libscorecpu.a
>  libscorecpu_a_SOURCES = cpu.c cpu_asm.S
> +libscorecpu_a_SOURCES += avr-exception-frame-print.c
>  libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
>  include $(srcdir)/preinstall.am
> diff --git a/cpukit/score/cpu/avr/avr-exception-frame-print.c b/cpukit/score/cpu/avr/avr-exception-frame-print.c
> index 0000000..5ae4979
> --- /dev/null
> +++ b/cpukit/score/cpu/avr/avr-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/avr/rtems/score/cpu.h b/cpukit/score/cpu/avr/rtems/score/cpu.h
> index 5436c21..9c4d2f4 100644
> --- a/cpukit/score/cpu/avr/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/avr/rtems/score/cpu.h
> @@ -1112,6 +1112,11 @@ void _CPU_Context_restore_fp(
>    Context_Control_fp **fp_context_ptr
> +typedef struct {
>  /*  The following routine swaps the endian format of an unsigned int.
>   *  It must be static because it is referenced indirectly.
> diff --git a/cpukit/score/cpu/bfin/Makefile.am b/cpukit/score/cpu/bfin/Makefile.am
> index dfec9ea..c8a7cf7 100644
> --- a/cpukit/score/cpu/bfin/Makefile.am
> +++ b/cpukit/score/cpu/bfin/Makefile.am
> @@ -16,6 +16,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
> +libscorecpu_a_SOURCES += bfin-exception-frame-print.c
> diff --git a/cpukit/score/cpu/bfin/bfin-exception-frame-print.c b/cpukit/score/cpu/bfin/bfin-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/bfin/bfin-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
> index a8cfc17..491c30f 100644
> --- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
> @@ -1204,6 +1204,11 @@ void _CPU_Context_restore_fp(
> +typedef struct {
>   *  @ingroup CPUEndian
> diff --git a/cpukit/score/cpu/h8300/Makefile.am b/cpukit/score/cpu/h8300/Makefile.am
> index 8ac7e76..5a3a8cc 100644
> --- a/cpukit/score/cpu/h8300/Makefile.am
> +++ b/cpukit/score/cpu/h8300/Makefile.am
> @@ -10,6 +10,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
> +libscorecpu_a_SOURCES += h8300-exception-frame-print.c
> diff --git a/cpukit/score/cpu/h8300/h8300-exception-frame-print.c b/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h b/cpukit/score/cpu/h8300/rtems/score/cpu.h
> index 1811ce7..413b9e1 100644
> --- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/h8300/rtems/score/cpu.h
> @@ -1095,6 +1095,11 @@ void _CPU_Context_restore_fp(
> +typedef struct {
> diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
> index acd2768..15ff3c7 100644
> --- a/cpukit/score/cpu/i386/cpu.c
> +++ b/cpukit/score/cpu/i386/cpu.c
> @@ -117,7 +117,7 @@ struct Frame_ {
>         uintptr_t               pc;
> -static void _defaultExcHandler (CPU_Exception_frame *ctx)
> +void _CPU_Exception_frame_print (const CPU_Exception_frame *ctx)
>    unsigned int faultAddr = 0;
>    printk("----------------------------------------------------------\n");
> @@ -148,7 +148,6 @@ static void _defaultExcHandler (CPU_Exception_frame *ctx)
>       * because the eip points to the faulty instruction so...
>      printk("Exception while executing ISR!!!. System locked\n");
> -    _CPU_Fatal_halt(faultAddr);
>    else {
>         struct Frame_ *fp = (struct Frame_*)ctx->ebp;
> @@ -171,10 +170,17 @@ static void _defaultExcHandler (CPU_Exception_frame *ctx)
>      printk(" ************ FAULTY THREAD WILL BE SUSPENDED **************\n");
>      rtems_task_suspend(_Thread_Executing->Object.id);
>  #endif
> -    bsp_reset();
> +static void _defaultExcHandler (CPU_Exception_frame *ctx)
> +  rtems_fatal(
> +    (rtems_fatal_code) ctx
>  cpuExcHandlerType _currentExcHandler = _defaultExcHandler;
>  extern void rtems_exception_prologue_0(void);
> diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
> index 2a48711..03d6209 100644
> --- a/cpukit/score/cpu/i386/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
> @@ -665,6 +665,8 @@ void _CPU_Context_restore_fp(
>    } while (0)
>  #endif
>  #endif /* ASM */
>  #ifdef __cplusplus
> diff --git a/cpukit/score/cpu/lm32/Makefile.am b/cpukit/score/cpu/lm32/Makefile.am
> index d3b49bf..c03e11c 100644
> --- a/cpukit/score/cpu/lm32/Makefile.am
> +++ b/cpukit/score/cpu/lm32/Makefile.am
> @@ -11,6 +11,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
>  libscorecpu_a_SOURCES = cpu.c cpu_asm.S irq.c
> +libscorecpu_a_SOURCES += lm32-exception-frame-print.c
> diff --git a/cpukit/score/cpu/lm32/lm32-exception-frame-print.c b/cpukit/score/cpu/lm32/lm32-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/lm32/lm32-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
> index 9f0876a..917fe7f 100644
> --- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
> @@ -1195,6 +1195,11 @@ void _CPU_Context_restore_fp(
> +typedef struct {
> diff --git a/cpukit/score/cpu/m32c/Makefile.am b/cpukit/score/cpu/m32c/Makefile.am
> index f836c58..4d63dfd 100644
> --- a/cpukit/score/cpu/m32c/Makefile.am
> +++ b/cpukit/score/cpu/m32c/Makefile.am
> @@ -14,6 +14,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
>  libscorecpu_a_SOURCES = cpu.c cpu_asm.c context_switch.S context_init.c \
>      varvects.S
> +libscorecpu_a_SOURCES += m32c-exception-frame-print.c
> diff --git a/cpukit/score/cpu/m32c/m32c-exception-frame-print.c b/cpukit/score/cpu/m32c/m32c-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/m32c/m32c-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
> index d83e93d..8719c42 100644
> --- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
> @@ -1131,6 +1131,11 @@ void _CPU_Context_restore(
>    Context_Control *new_context
>  ) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
> +typedef struct {
> diff --git a/cpukit/score/cpu/m32r/Makefile.am b/cpukit/score/cpu/m32r/Makefile.am
> index 37b49ed..9db2c89 100644
> --- a/cpukit/score/cpu/m32r/Makefile.am
> +++ b/cpukit/score/cpu/m32r/Makefile.am
> @@ -13,6 +13,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
> +libscorecpu_a_SOURCES += m32r-exception-frame-print.c
> diff --git a/cpukit/score/cpu/m32r/m32r-exception-frame-print.c b/cpukit/score/cpu/m32r/m32r-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/m32r/m32r-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu.h b/cpukit/score/cpu/m32r/rtems/score/cpu.h
> index 02bc928..cc5fc56 100644
> --- a/cpukit/score/cpu/m32r/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/m32r/rtems/score/cpu.h
> @@ -1189,6 +1189,11 @@ void _CPU_Context_restore_fp(
> +typedef struct {
> diff --git a/cpukit/score/cpu/m68k/Makefile.am b/cpukit/score/cpu/m68k/Makefile.am
> index 319cbdd..5669177 100644
> --- a/cpukit/score/cpu/m68k/Makefile.am
> +++ b/cpukit/score/cpu/m68k/Makefile.am
> @@ -18,6 +18,7 @@ include_rtems_score_HEADERS += rtems/score/m68k.h
> +libscorecpu_a_SOURCES += m68k-exception-frame-print.c
>  include $(top_srcdir)/automake/local.am
> diff --git a/cpukit/score/cpu/m68k/m68k-exception-frame-print.c b/cpukit/score/cpu/m68k/m68k-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/m68k/m68k-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
> index 89b0295..fb970eb 100644
> --- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
> @@ -709,6 +709,8 @@ void _CPU_Context_restore_fp(
>  #if (M68K_HAS_FPSP_PACKAGE == 1)
>   *  Hooks for the Floating Point Support Package (FPSP) provided by Motorola
> diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
> index 9aa72d4..1da23db 100644
> --- a/cpukit/score/cpu/mips/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
> @@ -609,6 +609,8 @@ typedef struct
>  } CPU_Interrupt_frame;
> +typedef CPU_Interrupt_frame CPU_Exception_frame;
>   *  This variable is optional.  It is used on CPUs on which it is difficult
>   *  to generate an "uninitialized" FP context.  It is filled in by
> @@ -703,6 +705,8 @@ extern unsigned int mips_interrupt_number_of_vectors;
>  #define CPU_STACK_ALIGNMENT        CPU_ALIGNMENT
> +void mips_vector_exceptions( CPU_Interrupt_frame *frame );
>   *  ISR handler macros
> @@ -1112,6 +1116,15 @@ void _CPU_Context_restore_fp(
> +void _BSP_Exception_frame_print( const CPU_Exception_frame *frame );
> +static inline void _CPU_Exception_frame_print(
> +  const CPU_Exception_frame *frame
> +  _BSP_Exception_frame_print( frame );
> diff --git a/cpukit/score/cpu/nios2/Makefile.am b/cpukit/score/cpu/nios2/Makefile.am
> index f662946..c2947dd 100644
> --- a/cpukit/score/cpu/nios2/Makefile.am
> +++ b/cpukit/score/cpu/nios2/Makefile.am
> @@ -24,6 +24,7 @@ libscorecpu_a_SOURCES += nios2-context-initialize.c
>  libscorecpu_a_SOURCES += nios2-context-switch.S
>  libscorecpu_a_SOURCES += nios2-eic-il-low-level.S
>  libscorecpu_a_SOURCES += nios2-eic-rsie-low-level.S
> +libscorecpu_a_SOURCES += nios2-exception-frame-print.c
>  libscorecpu_a_SOURCES += nios2-fatal-halt.c
>  libscorecpu_a_SOURCES += nios2-iic-low-level.S
>  libscorecpu_a_SOURCES += nios2-initialize.c
> diff --git a/cpukit/score/cpu/nios2/nios2-exception-frame-print.c b/cpukit/score/cpu/nios2/nios2-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/nios2/nios2-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
> index 4d61c42..68ab01d 100644
> --- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
> @@ -338,6 +338,8 @@ void _CPU_Context_restore(
>  static inline uint32_t CPU_swap_u32( uint32_t value )
>    uint32_t byte1, byte2, byte3, byte4, swapped;
> diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> index 9ab1f26..e137122 100644
> --- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> @@ -1263,6 +1263,19 @@ void _CPU_Context_restore_fp(
> +typedef struct {
> +  uint32_t processor_state_register;
> +  uint32_t integer_registers;
> +  double float_registers;
> diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> index 31b4e7c..93e632d 100644
> --- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> @@ -990,6 +990,63 @@ void _CPU_Context_restore_fp(
> +typedef struct {
> +  uint32_t EXC_SRR0;
> +  uint32_t EXC_SRR1;
> +  uint32_t _EXC_number;
> +  uint32_t EXC_CR;
> +  uint32_t EXC_CTR;
> +  uint32_t EXC_XER;
> +  uint32_t EXC_LR;
> +  #ifdef __SPE__
> +    uint32_t EXC_SPEFSCR;
> +    uint64_t EXC_ACC;
> +  #endif
> +  PPC_GPR_TYPE GPR0;
> +  PPC_GPR_TYPE GPR1;
> +  PPC_GPR_TYPE GPR2;
> +  PPC_GPR_TYPE GPR3;
> +  PPC_GPR_TYPE GPR4;
> +  PPC_GPR_TYPE GPR5;
> +  PPC_GPR_TYPE GPR6;
> +  PPC_GPR_TYPE GPR7;
> +  PPC_GPR_TYPE GPR8;
> +  PPC_GPR_TYPE GPR9;
> +  PPC_GPR_TYPE GPR10;
> +  PPC_GPR_TYPE GPR11;
> +  PPC_GPR_TYPE GPR12;
> +  PPC_GPR_TYPE GPR13;
> +  PPC_GPR_TYPE GPR14;
> +  PPC_GPR_TYPE GPR15;
> +  PPC_GPR_TYPE GPR16;
> +  PPC_GPR_TYPE GPR17;
> +  PPC_GPR_TYPE GPR18;
> +  PPC_GPR_TYPE GPR19;
> +  PPC_GPR_TYPE GPR20;
> +  PPC_GPR_TYPE GPR21;
> +  PPC_GPR_TYPE GPR22;
> +  PPC_GPR_TYPE GPR23;
> +  PPC_GPR_TYPE GPR24;
> +  PPC_GPR_TYPE GPR25;
> +  PPC_GPR_TYPE GPR26;
> +  PPC_GPR_TYPE GPR27;
> +  PPC_GPR_TYPE GPR28;
> +  PPC_GPR_TYPE GPR29;
> +  PPC_GPR_TYPE GPR30;
> +  PPC_GPR_TYPE GPR31;
> +  uint32_t EXC_MSR;
> +  uint32_t EXC_DAR;
>   * _CPU_Initialize_altivec()
> diff --git a/cpukit/score/cpu/sh/Makefile.am b/cpukit/score/cpu/sh/Makefile.am
> index 8e148d8..a524dfc 100644
> --- a/cpukit/score/cpu/sh/Makefile.am
> +++ b/cpukit/score/cpu/sh/Makefile.am
> @@ -11,6 +11,7 @@ include_rtems_score_HEADERS += rtems/score/sh_io.h
>  libscorecpu_a_SOURCES = cpu.c context.c
> +libscorecpu_a_SOURCES += sh-exception-frame-print.c
> diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
> index 789024e..53cceac 100644
> --- a/cpukit/score/cpu/sh/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
> @@ -885,6 +885,10 @@ void _CPU_Context_restore_fp(
> +typedef struct {
>  #ifdef __cplusplus
> diff --git a/cpukit/score/cpu/sh/sh-exception-frame-print.c b/cpukit/score/cpu/sh/sh-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/sh/sh-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index d92b63c..2e1e718 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -1221,6 +1221,20 @@ void _CPU_Context_restore_fp(
> +typedef struct {
> +  uint32_t trap;
> +  CPU_Interrupt_frame *isf;
>   *  @brief SPARC Specific Method to Endian Swap an uint32_t
> diff --git a/cpukit/score/cpu/sparc64/Makefile.am b/cpukit/score/cpu/sparc64/Makefile.am
> index 33ba844..2897a46 100644
> --- a/cpukit/score/cpu/sparc64/Makefile.am
> +++ b/cpukit/score/cpu/sparc64/Makefile.am
>  libscorecpu_a_SOURCES = context.S cpu.c
> +libscorecpu_a_SOURCES += sparc64-exception-frame-print.c
> diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> index f821e96..88457e8 100644
> --- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> @@ -1024,6 +1024,11 @@ void _CPU_Context_restore_fp(
> +typedef struct {
>   *  CPU_swap_u32
> diff --git a/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c b/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/cpu/v850/Makefile.am b/cpukit/score/cpu/v850/Makefile.am
> index 2119f62..6f1ce67 100644
> --- a/cpukit/score/cpu/v850/Makefile.am
> +++ b/cpukit/score/cpu/v850/Makefile.am
> @@ -11,6 +11,7 @@ include_rtems_score_HEADERS += rtems/score/cpu_asm.h rtems/score/types.h
>  libscorecpu_a_SOURCES += cpu_asm.S
> +libscorecpu_a_SOURCES += v850-exception-frame-print.c
> diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
> index 371bc32..cf855d3 100644
> --- a/cpukit/score/cpu/v850/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
> @@ -1124,6 +1124,11 @@ void _CPU_Context_restore_fp(
>  #endif
> +typedef struct {
> diff --git a/cpukit/score/cpu/v850/v850-exception-frame-print.c b/cpukit/score/cpu/v850/v850-exception-frame-print.c
> --- /dev/null
> +++ b/cpukit/score/cpu/v850/v850-exception-frame-print.c
> @@ -0,0 +1,24 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +  /* TODO */
> diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
> index 367c1ab..e325e68 100644
> --- a/cpukit/score/include/rtems/score/interr.h
> +++ b/cpukit/score/include/rtems/score/interr.h
> @@ -98,13 +98,13 @@ typedef enum {
>    RTEMS_FATAL_SOURCE_STACK_CHECKER,
> -   * @brief Fatal source of the PowerPC exceptions.
> +   * @brief Fatal source of the exceptions.
>     * The fatal code is the pointer value of the exception frame pointer.
> -   * @see BSP_Exception_frame.
> +   * @see rtems_exception_frame and rtems_exception_frame_print().
>     * @brief The last available fatal source.
> diff --git a/doc/user/fatal.t b/doc/user/fatal.t
> index 42a2432..1b725e8 100644
> --- a/doc/user/fatal.t
> +++ b/doc/user/fatal.t
> @@ -203,6 +203,33 @@ false.  See also @code{@value{DIRPREFIX}fatal_error_occurred}.
>  @c
>  @c
>  @page
> + at subsection EXCEPTION_FRAME_PRINT - Prints the exception frame
> + at cindex exception frame
> + at subheading CALLING SEQUENCE:
> + at ifset is-C
> + at findex rtems_exception_frame_print
> + at example
> +void rtems_exception_frame_print(
> + at end example
> + at end ifset
> + at subheading DIRECTIVE STATUS CODES
> +NONE
> + at subheading DESCRIPTION:
> +Prints the exception frame via printk().
> + at c
> + at c
> + at c
> + at page
>  @subsection INTERNAL_ERROR_DESCRIPTION - Returns a description for an internal error code
>  @cindex fatal error
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 1e183eb..c00d73c 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -28,6 +28,7 @@ SUBDIRS = \
>      spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
>      spedfsched01 spedfsched02 spedfsched03 \
>      spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01
> +SUBDIRS += spfatal26
>  SUBDIRS += speventtransient01
>  SUBDIRS += speventsystem01
>  SUBDIRS += spinternalerror01
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index a71746f..6d899a3 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -27,6 +27,7 @@ AC_CHECK_SIZEOF([time_t])
> +spfatal26/Makefile
>  spinternalerror02/Makefile
>  spinternalerror01/Makefile
>  speventsystem01/Makefile
> diff --git a/testsuites/sptests/spfatal26/Makefile.am b/testsuites/sptests/spfatal26/Makefile.am
> index 0000000..9cc5dba
> --- /dev/null
> +++ b/testsuites/sptests/spfatal26/Makefile.am
> @@ -0,0 +1,19 @@
> +rtems_tests_PROGRAMS = spfatal26
> +spfatal26_SOURCES = init.c
> +dist_rtems_tests_DATA = spfatal26.scn spfatal26.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(spfatal26_OBJECTS)
> +LINK_LIBS = $(spfatal26_LDLIBS)
> +spfatal26$(EXEEXT): $(spfatal26_OBJECTS) $(spfatal26_DEPENDENCIES)
> +       @rm -f spfatal26$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/spfatal26/init.c b/testsuites/sptests/spfatal26/init.c
> index 0000000..556410f
> --- /dev/null
> +++ b/testsuites/sptests/spfatal26/init.c
> @@ -0,0 +1,85 @@
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +#include "tmacros.h"
> +#include <limits.h>
> +#include <rtems.h>
> +static void provoke_aligment_or_data_access_exception( void )
> +  uintptr_t one = 1;
> +  int i = sizeof(void *) * CHAR_BIT;
> +  uintptr_t n = 1;
> +  uintptr_t base = 0;
> +  uintptr_t inc;
> +  *(volatile uint64_t *) base;
> +  do {
> +    int j;
> +    --i;
> +    base = one << i;
> +    inc = base << 1;
> +    for (j = 0; j < n; ++j, base += inc) {
> +    n <<= 1;
> +  } while (i > 0);
> +static void Init( rtems_task_argument arg )
> +  printk( "\n\n*** TEST SPFATAL 26 ***\n" );
> +  provoke_aligment_or_data_access_exception();
> +  rtems_test_assert( 0 );
> +static void fatal_extension(
> +  rtems_fatal_source source,
> +  bool is_internal,
> +  rtems_test_assert( source == RTEMS_FATAL_SOURCE_EXCEPTION );
> +  rtems_test_assert( !is_internal );
> +  printk( "*** END OF TEST SPFATAL 26 ***\n" );
> +#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/spfatal26/spfatal26.doc b/testsuites/sptests/spfatal26/spfatal26.doc
> index 0000000..fb9097c
> --- /dev/null
> +++ b/testsuites/sptests/spfatal26/spfatal26.doc
> @@ -0,0 +1,11 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: spfatal26
> +directives:
> +  - rtems_exception_frame_print
> +concepts:
> +  - Ensure that we get an fatal condition with RTEMS_FATAL_SOURCE_EXCEPTION.
> diff --git a/testsuites/sptests/spfatal26/spfatal26.scn b/testsuites/sptests/spfatal26/spfatal26.scn
> index 0000000..0dfa62a
> --- /dev/null
> +++ b/testsuites/sptests/spfatal26/spfatal26.scn
> @@ -0,0 +1,2 @@
> +*** TEST SPFATAL 26 ***
> +*** END OF TEST SPFATAL 26 ***
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
