[PATCH 3/3] bsps/powerpc: Add PPC_EXC_CONFIG_BOOKE_ONLY
Sebastian Huber
Fri Nov 30 08:50:14 UTC 2012
In combination with the PPC_EXC_CONFIG_USE_FIXED_HANDLER option this
removes all dependencies on valid read-write data. The exception
handling must be statically configured and all components reside in
read-only sections.
.../powerpc/shared/src/ppc-exc-handler-table.c | 6 ++++++
.../new-exceptions/bspsupport/ppc_exc_asm_macros.h | 20 ++++++++++++++++++++
.../new-exceptions/bspsupport/ppc_exc_hdl.c | 4 ++++
.../new-exceptions/bspsupport/ppc_exc_initialize.c | 8 +++++++-
.../new-exceptions/bspsupport/ppc_exc_naked.S | 12 ++++++++++++
.../powerpc/new-exceptions/bspsupport/vectors.h | 4 ++++
6 files changed, 53 insertions(+), 1 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c b/c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c
index f9fe0e2..c57f094 100644
--- a/c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c
+++ b/c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c
@@ -16,12 +16,14 @@
#ifdef PPC_EXC_CONFIG_USE_FIXED_HANDLER
+#ifndef PPC_EXC_CONFIG_BOOKE_ONLY
static int ppc_exc_interrupt_dispatch(BSP_Exception_frame *f, unsigned vector)
bsp_interrupt_dispatch();
return 0;
+#endif /* PPC_EXC_CONFIG_BOOKE_ONLY */
const ppc_exc_handler_t ppc_exc_handler_table [LAST_VALID_EXC + 1] = {
ppc_exc_handler_default,
@@ -29,7 +31,11 @@ const ppc_exc_handler_t ppc_exc_handler_table [LAST_VALID_EXC + 1] = {
ppc_exc_interrupt_dispatch,
+#else /* PPC_EXC_CONFIG_BOOKE_ONLY */
+ ppc_exc_handler_default,
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h
index d4bbaf4..e3d747f 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h
@@ -279,6 +279,8 @@ TEST_LOCK_crit_done_\_FLVR:
/* Standard*/
.macro RECOVER_CHECK_std _FLVR
/* Check if exception is recoverable */
lwz SCRATCH_REGISTER_0, SRR1_FRAME_OFFSET(FRAME_REGISTER)
lwz SCRATCH_REGISTER_1, ppc_exc_msr_bits at sdarel(r13)
@@ -290,6 +292,8 @@ recover_check_twiddle_std_\_FLVR:
/* Not recoverable? */
bne recover_check_twiddle_std_\_FLVR
.endm
/* Critical */
@@ -302,6 +306,8 @@ recover_check_twiddle_std_\_FLVR:
/* Machine check */
.macro RECOVER_CHECK_mchk _FLVR
@@ -313,6 +319,8 @@ recover_check_twiddle_mchk_\_FLVR:
bne recover_check_twiddle_mchk_\_FLVR
.endm
@@ -520,6 +528,8 @@ wrap_disable_thread_dispatching_done_\_FLVR:
/* Save vector number and exception type */
stw VECTOR_REGISTER, EXCEPTION_NUMBER_OFFSET(FRAME_REGISTER)
/* Load MSR bit mask */
lwz SCRATCH_REGISTER_0, ppc_exc_msr_bits at sdarel(r13)
@@ -532,6 +542,8 @@ wrap_disable_thread_dispatching_done_\_FLVR:
wrap_change_msr_done_\_FLVR:
#ifdef __ALTIVEC__
LA SCRATCH_REGISTER_0, _CPU_save_altivec_volatile
mtctr SCRATCH_REGISTER_0
@@ -660,11 +672,15 @@ wrap_thread_dispatching_done_\_FLVR:
bctrl
#endif
/* Restore MSR? */
bne CR_MSR, wrap_restore_msr_\_FLVR
wrap_restore_msr_done_\_FLVR:
* At this point r1 is a valid exception frame pointer and
* FRAME_REGISTER is no longer needed.
@@ -725,6 +741,8 @@ wrap_restore_msr_done_\_FLVR:
/* Return */
\_RFI
wrap_change_msr_\_FLVR:
mfmsr SCRATCH_REGISTER_1
@@ -744,6 +762,8 @@ wrap_restore_msr_\_FLVR:
isync
b wrap_restore_msr_done_\_FLVR
wrap_save_non_volatile_regs_\_FLVR:
/* Load pristine stack pointer */
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c
index b24467b..228c030 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c
@@ -31,6 +31,8 @@ uint32_t ppc_exc_vector_register_std = 0;
uint32_t ppc_exc_vector_register_crit = 0;
uint32_t ppc_exc_vector_register_mchk = 0;
/* MSR bits to enable once critical status info is saved and the stack
* is switched; must be set depending on CPU type
@@ -39,6 +41,8 @@ uint32_t ppc_exc_vector_register_mchk = 0;
uint32_t ppc_exc_msr_bits = MSR_IR | MSR_DR | MSR_RI;
int ppc_exc_handler_default(BSP_Exception_frame *f, unsigned int vector)
return -1;
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
index b239cdd..872eed4 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c
@@ -192,6 +192,8 @@ void ppc_exc_initialize(
ppc_interrupt_set_disable_mask(interrupt_disable_mask);
/* Use current MMU / RI settings when running C exception handlers */
ppc_exc_msr_bits = ppc_machine_state_register() & (MSR_DR | MSR_IR | MSR_RI);
@@ -199,7 +201,9 @@ void ppc_exc_initialize(
/* Need vector unit enabled to save/restore altivec context */
ppc_exc_msr_bits |= MSR_VE;
#endif
if (ppc_cpu_is_bookE() == PPC_BOOKE_STD || ppc_cpu_is_bookE() == PPC_BOOKE_E500) {
ppc_exc_initialize_booke();
@@ -221,6 +225,7 @@ void ppc_exc_initialize(
/* If we are on a classic PPC with MSR_DR enabled then
* assert that the mapping for at least this task's
* stack is write-back-caching enabled (see README/CAVEATS)
@@ -252,4 +257,5 @@ void ppc_exc_initialize(
__asm__ volatile ("dcbz 0, %0"::"b" (p));
/* If we make it thru here then things seem to be OK */
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_naked.S b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_naked.S
index c5df56f..725b087 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_naked.S
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_naked.S
@@ -76,6 +76,8 @@ ppc_exc_wrap_naked:
mflr SCRATCH_REGISTER_0
stw SCRATCH_REGISTER_0, EXC_LR_OFFSET(r1)
@@ -88,6 +90,8 @@ ppc_exc_wrap_naked:
wrap_change_msr_done_naked:
* Call high level exception handler
@@ -127,11 +131,15 @@ wrap_change_msr_done_naked:
bctrl
/* Restore MSR? */
bne CR_MSR, wrap_restore_msr_naked
wrap_restore_msr_done_naked:
/* Restore XER and CTR */
lwz SCRATCH_REGISTER_0, EXC_XER_OFFSET(r1)
lwz SCRATCH_REGISTER_1, EXC_CTR_OFFSET(r1)
@@ -175,6 +183,8 @@ wrap_restore_msr_done_naked:
/* Return */
rfi
wrap_change_msr_naked:
@@ -193,3 +203,5 @@ wrap_restore_msr_naked:
sync
isync
b wrap_restore_msr_done_naked
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
index bcb3b9a..a275d2e 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
@@ -410,6 +410,8 @@ typedef int (*ppc_exc_handler_t)(BSP_Exception_frame *f, unsigned vector);
int ppc_exc_handler_default(BSP_Exception_frame *f, unsigned int vector);
* @brief Bits for MSR update.
@@ -422,6 +424,8 @@ int ppc_exc_handler_default(BSP_Exception_frame *f, unsigned int vector);
extern uint32_t ppc_exc_msr_bits;
* @brief Cache write back check flag.
1.7.7
