[PATCH] score: Critical fix for thread dispatching
Sebastian Huber
Tue Oct 2 14:13:00 UTC 2012
The changes in _Thread_Dispatch() of commits
dad36c52b8be5d7b46bc7af85655055db7208652 and
d4dc7c8196355f08044e67a3f5c1e19485f17ff1 introduced a severe bug which
destroys the real-time properties of RTEMS completely.
Consider the following scenario. We have three tasks L (lowest
priority), M (middle priority), and H (highest priority). Now let a
thread dispatch from M to L happen. An interrupt occurs in
_Thread_Dispatch() here:
void _Thread_Dispatch( void )
post_switch:
_ISR_Enable( level );
<-- INTERRUPT
<-- AFTER INTERRUPT
_Thread_Unnest_dispatch();
_API_extensions_Run_postswitch();
The interrupt event makes task H ready. The interrupt code will see
_Thread_Dispatch_disable_level > 0 and thus doesn't perform a
_Thread_Dispatch(). Now we return to position "AFTER INTERRUPT". This
means task L executes now although task H is ready! Task H will execute
once someone calls _Thread_Dispatch().
cpukit/score/src/threaddispatch.c | 47 +++++++++++++++++++++++++++++++++---
1 files changed, 43 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index c8bc006..877a9c3 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -55,9 +55,41 @@ void _Thread_Dispatch( void )
Thread_Control *heir;
ISR_Level level;
- _Thread_Disable_dispatch();
#if defined(RTEMS_SMP)
+ * WARNING: The SMP sequence has severe defects regarding the real-time
+ * performance.
+ * Consider the following scenario. We have three tasks L (lowest
+ * priority), M (middle priority), and H (highest priority). Now let a
+ * thread dispatch from M to L happen. An interrupt occurs in
+ * _Thread_Dispatch() here:
+ * void _Thread_Dispatch( void )
+ * post_switch:
+ * _ISR_Enable( level );
+ * <-- INTERRUPT
+ * <-- AFTER INTERRUPT
+ * _Thread_Unnest_dispatch();
+ * _API_extensions_Run_postswitch();
+ * The interrupt event makes task H ready. The interrupt code will see
+ * _Thread_Dispatch_disable_level > 0 and thus doesn't perform a
+ * _Thread_Dispatch(). Now we return to position "AFTER INTERRUPT". This
+ * means task L executes now although task H is ready! Task H will execute
+ * once someone calls _Thread_Dispatch().
+ _Thread_Disable_dispatch();
* If necessary, send dispatch request to other cores.
_SMP_Request_other_cores_to_dispatch();
@@ -69,8 +101,10 @@ void _Thread_Dispatch( void )
executing = _Thread_Executing;
_ISR_Disable( level );
while ( _Thread_Dispatch_necessary == true ) {
heir = _Thread_Heir;
+ #ifndef RTEMS_SMP
+ _Thread_Dispatch_set_disable_level( 1 );
+ #endif
_Thread_Dispatch_necessary = false;
_Thread_Executing = heir;
@@ -167,10 +201,15 @@ void _Thread_Dispatch( void )
post_switch:
+ #ifndef RTEMS_SMP
+ _Thread_Dispatch_set_disable_level( 0 );
+ #endif
- _Thread_Unnest_dispatch();
+ #ifdef RTEMS_SMP
+ _Thread_Unnest_dispatch();
+ #endif
1.7.7
