rtems_xxxx_ident() does not support global search for all objects in the classic API
Andrei Dimitrief-Jianu
andrei.dimitrief.jianu at gmail.com
Tue Oct 9 21:47:45 UTC 2012
Hello,
Below are two different implementations for rtems_xxxx_ident()
directive, one for semaphores and the second for barriers.
rtems_status_code rtems_semaphore_ident(
rtems_name name,
uint32_t node,
rtems_id *id
Objects_Name_or_id_lookup_errors status;
status = _Objects_Name_to_id_u32( &_Semaphore_Information, name, node, id );
return _Status_Object_name_errors_to_status[ status ];
rtems_status_code rtems_barrier_ident(
rtems_name name,
rtems_id *id
status = _Objects_Name_to_id_u32( &_Barrier_Information, name,
OBJECTS_SEARCH_LOCAL_NODE, id );
Anyone can explain why for barriers the search is done only on the
local node? Was it simply an implementation choice? Any other reason
for that?
Thanks!
