rtems_xxxx_ident() does not support global search for all objects in the classic API
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Oct 9 22:36:18 UTC 2012
On 10/9/2012 4:47 PM, Andrei Dimitrief-Jianu wrote:
> Hello,
> Below are two different implementations for rtems_xxxx_ident()
> directive, one for semaphores and the second for barriers.
> rtems_status_code rtems_semaphore_ident(
> rtems_name name,
> uint32_t node,
> rtems_id *id
> Objects_Name_or_id_lookup_errors status;
> status = _Objects_Name_to_id_u32( &_Semaphore_Information, name, node, id );
> return _Status_Object_name_errors_to_status[ status ];
> rtems_status_code rtems_barrier_ident(
> rtems_name name,
> rtems_id *id
> status = _Objects_Name_to_id_u32( &_Barrier_Information, name,
> OBJECTS_SEARCH_LOCAL_NODE, id );
> Anyone can explain why for barriers the search is done only on the
> local node? Was it simply an implementation choice? Any other reason
> for that?
It is much simpler than you think. If the Object Class supports remote
operations
(e.g., global attribute on create and helpers internally), then it has
the three argument
form. Otherwise it takes the two argument form.
Timers and Rate Monotonic Periods are strictly local. Two argument form.
Barriers COULD be global but don't implement that so they use the two
argument form.
In general terms, only the objects originally required to be global by the
RTEID/ORKID specification support global operations. The development and
testing effort has never been put into adding global support on more recent
Object classes even when it logically could make sense to support it.
> Thanks!
> rtems-devel mailing list
> rtems-devel at rtems.org
