[rtems commit] New fstest to cover RFS bitmaps - fsrfsbitmap01
Sebastian Huber
Mon Oct 15 12:38:15 UTC 2012
On 10/01/2012 10:36 PM, Joel Sherrill wrote:
> +void nullpointer_test(void){
> + rtems_rfs_bitmap_control* control=NULL;
> + rtems_rfs_bitmap_control notnullcontrol;
> + rtems_rfs_bitmap_bit bit = 0;
> + rtems_rfs_bitmap_bit seed_bit = 0;
> + int rc;
> + bool result;
> + printf("\n Testing bitmap_map functions with NULL bitmap control " "pointer\n");
> + /* Invoke all functions with NULL control */
> + rc = rtems_rfs_bitmap_map_set(control, bit);
> + rtems_test_assert(rc>0);
> + rc = rtems_rfs_bitmap_map_clear(control, bit);
> + rc = rtems_rfs_bitmap_map_test(control, bit, &result);
> + rc = rtems_rfs_bitmap_map_set_all(control);
> + rc = rtems_rfs_bitmap_map_clear_all(control);
> + rc = rtems_rfs_bitmap_create_search(control);
> + rc = rtems_rfs_bitmap_map_alloc(control, seed_bit, &result, &bit);
> + rtems_test_assert(!result);
> + * Invoke map_alloc with not-null pointer to control, but with
> + * control uninitialized. It is to cover check in rtems_rfs_bitmap_load_map.
> + * We can't check directly if it goes this path, but we will see this in
> + * coverage
> + rc = rtems_rfs_bitmap_map_set(¬nullcontrol, bit);
> + rtems_test_assert(rc > 0);
What is the purpose of this test? It accesses illegal memory on some targets
(e.g. NULL pointer access).
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
