[rtems commit] New fstest to cover RFS bitmaps - fsrfsbitmap01
    Krzysztof Mięsowicz
    krzysztof.miesowicz at gmail.com
    Mon Oct 15 15:34:25 UTC 2012
Hi,
> What is the purpose of this test?  It accesses illegal memory on some
> targets (e.g. NULL pointer access).
> The purpose of this test is to cause fail on loading bitmap in invoking
functions and to execute ranges which can execute only when bitmap load
fails. rtems_rfs_bitmap_load_map can fail only when control->buffer is null
or when buffer request fail. This test is part of my ESA SOCIS project on
improving RTEMS coverage.
Krzysztof Miesowicz
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121015/acee5df0/attachment-0001.html>
