rtems_xxxx_ident() does not support global search for all objects in the classic API
    Andrei Dimitrief-Jianu
    andrei.dimitrief.jianu at gmail.com
    Tue Oct  9 22:59:36 UTC 2012
On Tue, Oct 9, 2012 at 6:36 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 10/9/2012 4:47 PM, Andrei Dimitrief-Jianu wrote:
>> Hello,
>> Below are two different implementations for rtems_xxxx_ident()
>> directive, one for semaphores and the second for barriers.
>> rtems_status_code rtems_semaphore_ident(
>>    rtems_name  name,
>>    uint32_t    node,
>>    rtems_id   *id
>>    Objects_Name_or_id_lookup_errors  status;
>>    status = _Objects_Name_to_id_u32( &_Semaphore_Information, name, node,
>> id );
>>    return _Status_Object_name_errors_to_status[ status ];
>> rtems_status_code rtems_barrier_ident(
>>    rtems_name  name,
>>    rtems_id   *id
>>    status = _Objects_Name_to_id_u32( &_Barrier_Information, name,
>> OBJECTS_SEARCH_LOCAL_NODE, id );
>> Anyone can explain why for barriers the search is done only on the
>> local node? Was it simply an implementation choice? Any other reason
>> for that?
> It is much simpler than you think. If the Object Class supports remote
> operations
> (e.g., global attribute on create and helpers internally), then it has the
> three argument
> form. Otherwise it takes the two argument form.
> Timers and Rate Monotonic Periods are strictly local. Two argument form.
> Barriers COULD be global but don't implement that so they use the two
> argument form.
> In general terms, only the objects originally required to be global by the
> RTEID/ORKID specification support global operations. The development and
> testing effort has never been put into adding global support on more recent
> Object classes even when it logically could make sense to support it.
That makes sense.
What I would like to ask is: would it make sense for an event flag
manager to support
global operations?
>> Thanks!
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
