[PATCH 4/4] arm: add support for libmm for arm with gumstix bsp
Hesham Moustafa heshamelmatary at gmail.com
Fri Oct 12 19:45:32 UTC 2012
On Fri, Oct 12, 2012 at 3:40 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I did not get a chance to review this code before, so here is my
> initial take. Comments in-line.
thanks gedare for reviewing the code, i will fix these issues in my
forked repo and push it again.
> On Thu, Oct 11, 2012 at 3:10 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> From: Hesham AL-Matary <heshamelmatary at gmail.com>
>>  c/src/lib/libcpu/arm/Makefile.am                 |   10 +-
>>  c/src/lib/libcpu/arm/preinstall.am               |    8 +
>>  c/src/lib/libcpu/arm/shared/arm920/mmu_support.c |  365 ++++++++++++++++++++++
>>  c/src/lib/libcpu/arm/shared/arm920/mmu_support.h |   95 ++++++
>>  4 files changed, 476 insertions(+), 2 deletions(-)
>>  create mode 100644 c/src/lib/libcpu/arm/shared/arm920/mmu_support.c
>>  create mode 100644 c/src/lib/libcpu/arm/shared/arm920/mmu_support.h
>> diff --git a/c/src/lib/libcpu/arm/Makefile.am b/c/src/lib/libcpu/arm/Makefile.am
>> index e488c45..b6f30ec 100644
>> --- a/c/src/lib/libcpu/arm/Makefile.am
>> +++ b/c/src/lib/libcpu/arm/Makefile.am
>> @@ -15,12 +15,18 @@ include_libcpu_HEADERS =
>>  ## shared/include
>>  if shared
>> -include_libcpu_HEADERS += shared/include/mmu.h
>> +include_libcpu_HEADERS += shared/include/mmu.h \
>> +        ../shared/include/memorymanagement.h \
>> +        shared/arm920/mmu_support.h
> Fix tabs replace with spaces, here and more below.
>>  include_libcpu_HEADERS += shared/include/arm-cp15.h
>>  ## shared/arm920
>>  noinst_PROGRAMS += shared/arm920.rel
>> -shared_arm920_rel_SOURCES = shared/arm920/mmu.c
>> +shared_arm920_rel_SOURCES = shared/arm920/mmu.c \
>> +        shared/arm920/mmu_support.h \
>> +        shared/arm920/mmu_support.c \
>> +        ../shared/src/memorymanagement_manager.c
>>  shared_arm920_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/src
>>  shared_arm920_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>  endif
>> diff --git a/c/src/lib/libcpu/arm/preinstall.am b/c/src/lib/libcpu/arm/preinstall.am
>> index 751a085..ecc4509 100644
>> --- a/c/src/lib/libcpu/arm/preinstall.am
>> +++ b/c/src/lib/libcpu/arm/preinstall.am
>> @@ -33,6 +33,14 @@ $(PROJECT_INCLUDE)/libcpu/mmu.h: shared/include/mmu.h $(PROJECT_INCLUDE)/libcpu/
>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/mmu.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/mmu.h
>> +$(PROJECT_INCLUDE)/libcpu/memorymanagement.h: ../shared/include/memorymanagement.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/memorymanagement.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/memorymanagement.h
>> +$(PROJECT_INCLUDE)/libcpu/mmu_support.h: shared/arm920/mmu_support.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/mmu_support.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/mmu_support.h
>>  $(PROJECT_INCLUDE)/libcpu/arm-cp15.h: shared/include/arm-cp15.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
>> diff --git a/c/src/lib/libcpu/arm/shared/arm920/mmu_support.c b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.c
>> new file mode 100644
>> index 0000000..00e9049
>> --- /dev/null
>> +++ b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.c
>> @@ -0,0 +1,365 @@
>> +/* COPYRIGHT (c) 2012. Hesham AL-Matary
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.com/license/LICENSE.
>> +#include <libcpu/arm-cp15.h>
>> +#include <rtems/rtems/status.h>
>> +#include "mmu_support.h"
>> +#include <libcpu/memorymanagement.h>
>> +extern uint32_t _ttbl_base;
>> + * @brief Deleting MPE and freeing its Control block as well as uninstalling
>> + * mpe from HW and uninstall the high-level pointer to cpu_mpe
>> +static inline rtems_status_code _CPU_Memory_management_Delete_MPE(rtems_memory_management_entry *mpe)
> Why is this "static inline"? Also, it appears to be unused.
>> +  arm_bsp_mm_mpe *arm_mpe;
>> +  arm_mpe = mpe->cpu_mpe;
>> +  if ( arm_mpe == NULL )
>> +    return RTEMS_NO_MEMORY;
>> +  free(arm_mpe);
>> +  return RTEMS_SUCCESSFUL;
>> +/* Changing Page table attributes to new attributes */
>> +static inline rtems_status_code arm_Region_Change_Attr(
>> +    arm_bsp_mm_mpe *mpe,
>> +    uint32_t AP,
>> +    uint32_t CB
>> +  mmu_lvl1_t     *lvl1_pt;
>> +  int             sectionsNumber; /* 1MB sections */
>> +  uint32_t        vAddress;
>> +  int             PTEIndex;
>> +  uint32_t        paddr;
>> +  int b,c,i;
>> +  sectionsNumber = mpe->pagesNumber;
>> +  lvl1_pt = (mmu_lvl1_t *) &_ttbl_base;
>> +  PTEIndex = ((mpe->vAddress & 0xfff00000) >> 20);
>> +  paddr = (mpe->vAddress & 0xfff00000);
>> +  /* flush the cache and TLB */
>> +  arm_cp15_cache_invalidate();
>> +  arm_cp15_tlb_invalidate();
>> +  /*  I & D caches turned off */
>> +  arm_cp15_set_control(
>> +      MMU_CTRL_DEFAULT |
>> +      MMU_CTRL_D_CACHE_DES |
>> +      MMU_CTRL_I_CACHE_DES |
>> +      MMU_CTRL_ALIGN_FAULT_EN |
>> +      MMU_CTRL_LITTLE_ENDIAN |
>> +      MMU_CTRL_MMU_DES
>> +  c = 0;
>> +  b = 0;
>> +  switch (CB) {
>> +    case ARM_MMU_cb:
>> +      c = 0;
>> +      b = 0;
>> +      break;
>> +    case ARM_MMU_cB:
>> +      c = 0;
>> +      b = 1;
>> +      break;
>> +    case ARM_MMU_WT:
>> +      c = 1;
>> +      b = 0;
>> +      break;
>> +    case ARM_MMU_WB:
>> +      c = 1;
>> +      b = 1;
>> +      break;
>> +  /* Return AP/CB for this region to defaults */
>> +  for ( i = 0; i < sectionsNumber; i++) {
>> +    uint32_t paddr_base = paddr;
>> +    paddr_base = (i<<20) + paddr;
>> +    lvl1_pt[PTEIndex++] = MMU_SET_LVL1_SECT(
>> +        paddr_base,
>> +        AP,
>> +        0,
>> +        c,
>> +        b
>> +  uint32_t *PTE_debug = ((uint32_t *) ((mpe->ptAddress) + (mpe->pagesNumber * 4)));
>> +  printk(" ~~~ Debug : Entered arm_Region_Change_Attr function succesfully and \n\
>> +      changed the first PTE for region starting at base address %x with assigned \n\
>> +     pagetable address at address %x is %x ~~~ \n",mpe->vAddress, mpe->ptAddress + (mpe->pagesNumber *4),\
>> +     lvl1_pt[PTEIndex]);
> Guard this print with #ifdef DEBUG. I think I did this somewhere else already.
>> +  mpe->ap = AP; /* Default when installing entry */
>> +  mpe->cb = CB; /* Default */
>> +  /*  I & D caches turned on */
>> +      MMU_CTRL_D_CACHE_EN |
>> +      MMU_CTRL_I_CACHE_EN |
>> +      MMU_CTRL_MMU_EN
>> +/* Verify that size must is multiple of page size */
>> +inline rtems_status_code _CPU_Memory_management_Verify_size(uint32_t size)
>> +  if ( (size % MMU_SECT_SIZE) != 0)
>> +    return RTEMS_INVALID_SIZE;
>> +/* Verify that size is a multiple of page size */
> I think this comment is misplaced.
>> +inline rtems_status_code _CPU_Memory_management_Initialize(void)
> Should this be inline?
>> +  mmu_lvl1_t *lvl1_base;
>> +  int i;
>> +  uint32_t paddr;
>> +  /* set manage mode access for all domains */
>> +  arm_cp15_set_domain_access_control(0xffffffff);
>> +  lvl1_base = (mmu_lvl1_t *) &_ttbl_base;
>> +  /* set up the trans table */
>> +  //mmu_set_map_inval(lvl1_base);
>> +  arm_cp15_set_translation_table_base(lvl1_base);
>> +  /* fill level 1 pagetable with no protection slots, Cache through attributes
>> +   * and 1:1 address mapping */
>> +  paddr = 0x00000000;
>> +  for (i = 0; i < (0x4000 / 4); i++) {
>> +    paddr = i; /* i = 1MB page size */
>> +    lvl1_base[i] = MMU_SET_LVL1_SECT(
>> +        paddr << 20,
>> +        ARM_MMU_AP_NOPR,
>> +        0,
>> +        1,
>> +        0
>> +      MMU_CTRL_MMU_EN
>> +/* @brief Installing @mpe allocates new arm_bsp_mm_mpe for it
>> + * and set its value for then allocate a new lvl2 page table
>> + * and activate it */
>> +rtems_status_code _CPU_Memory_management_Install_MPE(
>> +  rtems_memory_management_entry *mpe
>> +  size_t          size; /* per Byte */
>> +  int             PTEIndex;
>> +  uint32_t        paddr;
>> +  int i;
>> +  uint32_t        paddr_base;
>> +  PTEIndex = ((((uint32_t)mpe->region.base) & 0xfff00000) >> 20);
>> +  paddr = ((((uint32_t)mpe->region.base)) & 0xfff00000);
>> +  size = mpe->region.size;
>> +  arm_mpe = (arm_bsp_mm_mpe *) malloc(sizeof(arm_bsp_mm_mpe));
>> +  sectionsNumber = (size / MMU_SECT_SIZE);
>> +      MMU_CTRL_MMU_DES
>> +  /* Set AP for this region to NO ACCESS */
>> +        paddr_base,
>> +        ARM_MMU_AP_NO_ACCESS,
>> +        0,
>> +        1,
>> +        0
>> +  arm_mpe->vAddress = mpe->region.base;
>> +  /* for level 1 page table ptAddress is the same as ptlvl1Address */
>> +  arm_mpe->ptAddress = lvl1_pt;
>> +  arm_mpe->ptlvl1Address = lvl1_pt;
>> +  arm_mpe->pagesNumber = sectionsNumber;
>> +  arm_mpe->type = LVL1_PT; /* Default value now */
>> +  arm_mpe->ap   = ARM_MMU_AP_NO_ACCESS; /* Default when installing entry */
>> +  arm_mpe->cb   = ARM_MMU_WT; /* Default */
>> +  /* TODO: Domain may be defined as read only, write.. and any page may
>> +   * be attached to it */
> What is this TODO saying we should do?
>> +  arm_mpe->domain = 0;
>> +  /* install a pointer to high-level API to bsp_mm_mpe */
>> +  mpe->cpu_mpe = arm_mpe;
>> +      MMU_CTRL_MMU_EN
>> +  PTEIndex = (arm_mpe->vAddress & 0xfff00000) >> 20;
>> +#ifdef DEBUG
>> +  PTE_debug = (uint32_t *)(arm_mpe->ptAddress + arm_mpe->pagesNumber * 4);
>> +  printk("Installed PTE at base %x with pagetable address %x\n",
>> +      arm_mpe->vAddress, arm_mpe->ptAddress + (arm_mpe->pagesNumber *4),
>> +      lvl1_pt[PTEIndex + arm_mpe->pagesNumber - 1]);
>> +#endif
>> +/* @brief Unistalling @mpe from level1 page table and return
>> + * access/cache attributes to its defaults. Note that bsp MPE
>> + * will still exist even after uninstalling mpe
>> +rtems_status_code _CPU_Memory_management_UnInstall_MPE(
>> +  int             PTEIndex;
>> +  uint32_t        paddr;
>> +  arm_mpe = (arm_bsp_mm_mpe *) mpe->cpu_mpe;
>> +    return RTEMS_UNSATISFIED;
>> +  sectionsNumber = arm_mpe->pagesNumber;
>> +  paddr = (((uint32_t)mpe->region.base) & 0xfff00000);
>> +      MMU_CTRL_MMU_DES
>> +  /* Return ap/CB for this region to defaults */
>> +  int i;
>> +        paddr_base,
>> +        0,
>> +        1,
>> +        0
> It seems like this code is mostly copy-pasted, can it be consolidated
> into some helper functions?
>> +  arm_mpe->ap   = ARM_MMU_AP_NO_ACCESS; /* Default */
>> +      MMU_CTRL_MMU_EN
>> +rtems_status_code _CPU_Memory_management_Set_read_only(
>> +  arm_bsp_mm_mpe *arm_mpe = (arm_bsp_mm_mpe *)mpe->cpu_mpe;
>> +  return arm_Region_Change_Attr(arm_mpe, ARM_MMU_AP_USER_READ_ONLY, ARM_MMU_WT);
>> +rtems_status_code _CPU_Memory_management_Set_write(
>> +  return arm_Region_Change_Attr(arm_mpe, ARM_MMU_AP_NOPR, ARM_MMU_WT);
>> diff --git a/c/src/lib/libcpu/arm/shared/arm920/mmu_support.h b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.h
>> index 0000000..98744e9
>> --- /dev/null
>> +++ b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.h
>> @@ -0,0 +1,95 @@
>> +*  COPYRIGHT (c) 2012
>> +*  On-Line Applications Research Corporation (OAR).
>> +*  The license and distribution terms for this file may be
>> +*  found in the file LICENSE in this distribution or at
>> +*  http://www.rtems.com/license/LICENSE.
>> +#ifndef __MMU_SUPPORT_H_
>> +#define __MMU_SUPPORT_H_
>> +#include <stdint.h>
>> +#define MMU_CTRL_MMU_EN             (1 << 0)
>> +#define MMU_CTRL_MMU_DES            (0 << 0)
>> +#define MMU_CTRL_ALIGN_FAULT_EN     (1 << 1)
>> +#define MMU_CTRL_D_CACHE_EN         (1 << 2)
>> +#define MMU_CTRL_D_CACHE_DES        (0 << 2)
>> +#define MMU_CTRL_DEFAULT            (0xf << 3)
>> +#define MMU_CTRL_LITTLE_ENDIAN      (0 << 7)
>> +#define MMU_CTRL_BIG_ENDIAN         (1 << 7)
>> +#define MMU_CTRL_SYS_PROT           (1 << 8)
>> +#define MMU_CTRL_ROM_PROT           (1 << 9)
>> +#define MMU_CTRL_I_CACHE_EN         (1 << 12)
>> +#define MMU_CTRL_I_CACHE_DES        (0 << 12)
>> +#define MMU_CTRL_LOW_VECT           (0 << 13)
>> +#define MMU_CTRL_HIGH_VECT          (1 << 13)
>> +#define ARM_MMU_AP_NOPR             0x03
>> +#define ARM_MMU_AP_USER_READ_ONLY   0x02
>> +#define ARM_MMU_AP_USER_NO_ACCESS   0x01
>> +#define ARM_MMU_AP_NO_ACCESS        0x00
>> +#define ARM_MMU_cb 0x0 //cache and buffer disabled
>> +#define ARM_MMU_cB 0x1 // cache disable and buffer enabled
>> +#define ARM_MMU_WT 0x2 // Write through
>> +#define ARM_MMU_WB 0x3 // Write Back
>> +/* FAULT ENTRY */
>> +#define MMU_SET_FAULT (0x0)
>> +/* FIXME: ARM supports various page sizes */
>> +#define ARM_MMU_PAGE_SIZE  0x1000
>> +#define MMU_SECT_SIZE      0x100000
>> +/* Set lvl1 PTE to point to the base of a page table mapping
>> + * 4K pages
>> +#define MMU_SET_LVL1_DIR_4K_PAGES(lvl2_base, dom) \
>> +           ((((lvl2_base) & 0xfffffc00)) |     \
>> +           (((dom)&0xf)<<5)                  |     \
>> +           0x11)
>> +#define MMU_SET_LVL2_PTE_4KB(paddr,ap,c,b) \
>> +                           (((paddr)&0xfffff000)   | \
>> +                            ((ap)<<10)      | \
>> +                            ((ap)<<8)       | \
>> +                            ((ap)<<6)       | \
>> +                            ((ap)<<4)       | \
>> +                            ((c)<<3)        | \
>> +                            ((b)<<2)        | \
>> +                            0x2)
>> +#define MMU_SET_LVL1_SECT(addr, ap, dom, ce, be) \
>> +          ((((addr) & 0xfff00000)) |     \
>> +           ((ap) << 10)            |     \
>> +           ((dom) << 5)            |     \
>> +           ((ce) << 3)             |     \
>> +           ((be) << 2)             |     \
>> +           0x12)
>> +/* TODO: Add other page sizes */
>> +typedef enum { LVL1_PT, LVL2_PT } pt_type;
>> +typedef uint32_t mmu_lvl1_t;
>> +typedef uint32_t mmu_lvl2_t;
>> +/* This Control Structure applies for most ARM architectures */
>> +typedef struct{
>> +uint32_t vAddress;
>> +/* physical address for page table lvl2 or lvl1 controlling a region */
>> +uint32_t ptAddress;
>> +/* physical address for  level 1 page table */
>> +uint32_t ptlvl1Address;
>> +/* Number of used PTEs from this page table */
>> +uint16_t pagesNumber;
>> +/* lvl2 , lvl1 */
>> +pt_type  type;
>> +uint8_t  ap;
>> +uint8_t  cb;
>> +uint8_t domain;
>> +} arm_bsp_mm_mpe;
> This probably should be arm920_mm_mpe or something, or the definition
> should be provided in a shared arm-bsp header file.
>> +#endif
>> 1.7.1
