[PATCH 4/4] arm: add support for libmm for arm with gumstix bsp
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Oct 12 21:29:27 UTC 2012
On 10/12/2012 08:40 AM, Gedare Bloom wrote:
> I did not get a chance to review this code before, so here is my
> initial take. Comments in-line.
Mine piled on Gedare's.
I did not get to review the other patches but since mine are
mostly formatting, look for similar issues in the other
modifications.
> On Thu, Oct 11, 2012 at 3:10 PM, Gedare Bloom<gedare at rtems.org> wrote:
>> From: Hesham AL-Matary<heshamelmatary at gmail.com>
>> c/src/lib/libcpu/arm/Makefile.am | 10 +-
>> c/src/lib/libcpu/arm/preinstall.am | 8 +
>> c/src/lib/libcpu/arm/shared/arm920/mmu_support.c | 365 ++++++++++++++++++++++
>> c/src/lib/libcpu/arm/shared/arm920/mmu_support.h | 95 ++++++
>> 4 files changed, 476 insertions(+), 2 deletions(-)
>> create mode 100644 c/src/lib/libcpu/arm/shared/arm920/mmu_support.c
>> create mode 100644 c/src/lib/libcpu/arm/shared/arm920/mmu_support.h
>> diff --git a/c/src/lib/libcpu/arm/Makefile.am b/c/src/lib/libcpu/arm/Makefile.am
>> index e488c45..b6f30ec 100644
>> --- a/c/src/lib/libcpu/arm/Makefile.am
>> +++ b/c/src/lib/libcpu/arm/Makefile.am
>> @@ -15,12 +15,18 @@ include_libcpu_HEADERS =
>> ## shared/include
>> if shared
>> -include_libcpu_HEADERS += shared/include/mmu.h
>> +include_libcpu_HEADERS += shared/include/mmu.h \
>> + ../shared/include/memorymanagement.h \
>> + shared/arm920/mmu_support.h
> Fix tabs replace with spaces, here and more below.
>> include_libcpu_HEADERS += shared/include/arm-cp15.h
>> ## shared/arm920
>> noinst_PROGRAMS += shared/arm920.rel
>> -shared_arm920_rel_SOURCES = shared/arm920/mmu.c
>> +shared_arm920_rel_SOURCES = shared/arm920/mmu.c \
>> + shared/arm920/mmu_support.h \
>> + shared/arm920/mmu_support.c \
>> + ../shared/src/memorymanagement_manager.c
>> shared_arm920_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/src
>> shared_arm920_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> endif
>> diff --git a/c/src/lib/libcpu/arm/preinstall.am b/c/src/lib/libcpu/arm/preinstall.am
>> index 751a085..ecc4509 100644
>> --- a/c/src/lib/libcpu/arm/preinstall.am
>> +++ b/c/src/lib/libcpu/arm/preinstall.am
>> @@ -33,6 +33,14 @@ $(PROJECT_INCLUDE)/libcpu/mmu.h: shared/include/mmu.h $(PROJECT_INCLUDE)/libcpu/
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/mmu.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/mmu.h
>> +$(PROJECT_INCLUDE)/libcpu/memorymanagement.h: ../shared/include/memorymanagement.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/memorymanagement.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/memorymanagement.h
>> +$(PROJECT_INCLUDE)/libcpu/mmu_support.h: shared/arm920/mmu_support.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/mmu_support.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/mmu_support.h
>> $(PROJECT_INCLUDE)/libcpu/arm-cp15.h: shared/include/arm-cp15.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
>> diff --git a/c/src/lib/libcpu/arm/shared/arm920/mmu_support.c b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.c
>> new file mode 100644
>> index 0000000..00e9049
>> --- /dev/null
>> +++ b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.c
>> @@ -0,0 +1,365 @@
>> +/* COPYRIGHT (c) 2012. Hesham AL-Matary
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.com/license/LICENSE.
Please add a blank line after the COPYRIGHT
>> +#include<libcpu/arm-cp15.h>
>> +#include<rtems/rtems/status.h>
>> +#include "mmu_support.h"
>> +#include<libcpu/memorymanagement.h>
>> +extern uint32_t _ttbl_base;
>> + * @brief Deleting MPE and freeing its Control block as well as uninstalling
>> + * mpe from HW and uninstall the high-level pointer to cpu_mpe
>> +static inline rtems_status_code _CPU_Memory_management_Delete_MPE(rtems_memory_management_entry *mpe)
> Why is this "static inline"? Also, it appears to be unused.
>> + arm_bsp_mm_mpe *arm_mpe;
>> + arm_mpe = mpe->cpu_mpe;
>> + if ( arm_mpe == NULL )
>> + return RTEMS_NO_MEMORY;
>> + free(arm_mpe);
>> + return RTEMS_SUCCESSFUL;
>> +/* Changing Page table attributes to new attributes */
>> +static inline rtems_status_code arm_Region_Change_Attr(
>> + arm_bsp_mm_mpe *mpe,
>> + uint32_t AP,
>> + uint32_t CB
>> + mmu_lvl1_t *lvl1_pt;
>> + int sectionsNumber; /* 1MB sections */
>> + uint32_t vAddress;
>> + int PTEIndex;
>> + uint32_t paddr;
>> + int b,c,i;
>> + sectionsNumber = mpe->pagesNumber;
>> + lvl1_pt = (mmu_lvl1_t *)&_ttbl_base;
>> + PTEIndex = ((mpe->vAddress& 0xfff00000)>> 20);
>> + paddr = (mpe->vAddress& 0xfff00000);
>> + /* flush the cache and TLB */
>> + arm_cp15_cache_invalidate();
>> + arm_cp15_tlb_invalidate();
>> + /* I& D caches turned off */
>> + arm_cp15_set_control(
>> + MMU_CTRL_DEFAULT |
>> + MMU_CTRL_D_CACHE_DES |
>> + MMU_CTRL_I_CACHE_DES |
>> + MMU_CTRL_ALIGN_FAULT_EN |
>> + MMU_CTRL_LITTLE_ENDIAN |
>> + MMU_CTRL_MMU_DES
>> + c = 0;
>> + b = 0;
>> + switch (CB) {
>> + case ARM_MMU_cb:
>> + c = 0;
>> + b = 0;
>> + break;
>> + case ARM_MMU_cB:
>> + c = 0;
>> + b = 1;
>> + break;
>> + case ARM_MMU_WT:
>> + c = 1;
>> + b = 0;
>> + break;
>> + case ARM_MMU_WB:
>> + c = 1;
>> + b = 1;
>> + break;
>> + /* Return AP/CB for this region to defaults */
>> + for ( i = 0; i< sectionsNumber; i++) {
>> + uint32_t paddr_base = paddr;
>> + paddr_base = (i<<20) + paddr;
>> + lvl1_pt[PTEIndex++] = MMU_SET_LVL1_SECT(
>> + paddr_base,
>> + AP,
>> + 0,
>> + c,
>> + b
>> + uint32_t *PTE_debug = ((uint32_t *) ((mpe->ptAddress) + (mpe->pagesNumber * 4)));
>> + printk(" ~~~ Debug : Entered arm_Region_Change_Attr function succesfully and \n\
>> + changed the first PTE for region starting at base address %x with assigned \n\
>> + pagetable address at address %x is %x ~~~ \n",mpe->vAddress, mpe->ptAddress + (mpe->pagesNumber *4),\
>> + lvl1_pt[PTEIndex]);
> Guard this print with #ifdef DEBUG. I think I did this somewhere else already.
>> + mpe->ap = AP; /* Default when installing entry */
>> + mpe->cb = CB; /* Default */
>> + /* I& D caches turned on */
>> + MMU_CTRL_D_CACHE_EN |
>> + MMU_CTRL_I_CACHE_EN |
>> + MMU_CTRL_MMU_EN
>> +/* Verify that size must is multiple of page size */
>> +inline rtems_status_code _CPU_Memory_management_Verify_size(uint32_t size)
>> + if ( (size % MMU_SECT_SIZE) != 0)
>> + return RTEMS_INVALID_SIZE;
>> +/* Verify that size is a multiple of page size */
> I think this comment is misplaced.
>> +inline rtems_status_code _CPU_Memory_management_Initialize(void)
> Should this be inline?
If is inline, should be be static? This looks like a public
routine that should not be inlined.
>> + mmu_lvl1_t *lvl1_base;
>> + int i;
>> + uint32_t paddr;
>> + /* set manage mode access for all domains */
>> + arm_cp15_set_domain_access_control(0xffffffff);
>> + lvl1_base = (mmu_lvl1_t *)&_ttbl_base;
>> + /* set up the trans table */
>> + //mmu_set_map_inval(lvl1_base);
>> + arm_cp15_set_translation_table_base(lvl1_base);
>> + /* fill level 1 pagetable with no protection slots, Cache through attributes
>> + * and 1:1 address mapping */
>> + paddr = 0x00000000;
>> + for (i = 0; i< (0x4000 / 4); i++) {
>> + paddr = i; /* i = 1MB page size */
>> + lvl1_base[i] = MMU_SET_LVL1_SECT(
>> + paddr<< 20,
>> + ARM_MMU_AP_NOPR,
>> + 0,
>> + 1,
>> + 0
>> + MMU_CTRL_MMU_EN
>> +/* @brief Installing @mpe allocates new arm_bsp_mm_mpe for it
>> + * and set its value for then allocate a new lvl2 page table
>> + * and activate it */
This is not an @brief. @brief shows up in a Table of
Contents so should be about that length.
@brief <about this long or maybe this long>
+ * and activate it.
Add period at tend of sentence.
>> +rtems_status_code _CPU_Memory_management_Install_MPE(
>> + rtems_memory_management_entry *mpe
I think the { should be pulled down on the next line.
>> + size_t size; /* per Byte */
>> + int PTEIndex;
>> + uint32_t paddr;
>> + int i;
>> + uint32_t paddr_base;
>> + PTEIndex = ((((uint32_t)mpe->region.base)& 0xfff00000)>> 20);
>> + paddr = ((((uint32_t)mpe->region.base))& 0xfff00000);
>> + size = mpe->region.size;
>> + arm_mpe = (arm_bsp_mm_mpe *) malloc(sizeof(arm_bsp_mm_mpe));
>> + sectionsNumber = (size / MMU_SECT_SIZE);
>> + MMU_CTRL_MMU_DES
>> + /* Set AP for this region to NO ACCESS */
>> + paddr_base,
>> + ARM_MMU_AP_NO_ACCESS,
>> + 0,
>> + 1,
>> + 0
>> + arm_mpe->vAddress = mpe->region.base;
>> + /* for level 1 page table ptAddress is the same as ptlvl1Address */
>> + arm_mpe->ptAddress = lvl1_pt;
>> + arm_mpe->ptlvl1Address = lvl1_pt;
>> + arm_mpe->pagesNumber = sectionsNumber;
>> + arm_mpe->type = LVL1_PT; /* Default value now */
>> + arm_mpe->ap = ARM_MMU_AP_NO_ACCESS; /* Default when installing entry */
>> + arm_mpe->cb = ARM_MMU_WT; /* Default */
>> + /* TODO: Domain may be defined as read only, write.. and any page may
>> + * be attached to it */
> What is this TODO saying we should do?
And what limits does it not being implemented impose? Why
would this impact someone?
>> + arm_mpe->domain = 0;
>> + /* install a pointer to high-level API to bsp_mm_mpe */
>> + mpe->cpu_mpe = arm_mpe;
>> + MMU_CTRL_MMU_EN
>> + PTEIndex = (arm_mpe->vAddress& 0xfff00000)>> 20;
>> +#ifdef DEBUG
>> + PTE_debug = (uint32_t *)(arm_mpe->ptAddress + arm_mpe->pagesNumber * 4);
>> + printk("Installed PTE at base %x with pagetable address %x\n",
>> + arm_mpe->vAddress, arm_mpe->ptAddress + (arm_mpe->pagesNumber *4),
>> + lvl1_pt[PTEIndex + arm_mpe->pagesNumber - 1]);
>> +#endif
>> +/* @brief Unistalling @mpe from level1 page table and return
>> + * access/cache attributes to its defaults. Note that bsp MPE
>> + * will still exist even after uninstalling mpe
@brief ditto
>> +rtems_status_code _CPU_Memory_management_UnInstall_MPE(
>> + int PTEIndex;
>> + uint32_t paddr;
>> + arm_mpe = (arm_bsp_mm_mpe *) mpe->cpu_mpe;
>> + return RTEMS_UNSATISFIED;
>> + sectionsNumber = arm_mpe->pagesNumber;
>> + paddr = (((uint32_t)mpe->region.base)& 0xfff00000);
>> + MMU_CTRL_MMU_DES
>> + /* Return ap/CB for this region to defaults */
>> + int i;
>> + paddr_base,
>> + 0,
>> + 1,
>> + 0
> It seems like this code is mostly copy-pasted, can it be consolidated
> into some helper functions?
>> + arm_mpe->ap = ARM_MMU_AP_NO_ACCESS; /* Default */
>> + MMU_CTRL_MMU_EN
Indentation here is 4, not 2. Be consistent.
>> +rtems_status_code _CPU_Memory_management_Set_read_only(
>> + arm_bsp_mm_mpe *arm_mpe = (arm_bsp_mm_mpe *)mpe->cpu_mpe;
>> + return arm_Region_Change_Attr(arm_mpe, ARM_MMU_AP_USER_READ_ONLY, ARM_MMU_WT);
>> +rtems_status_code _CPU_Memory_management_Set_write(
>> + return arm_Region_Change_Attr(arm_mpe, ARM_MMU_AP_NOPR, ARM_MMU_WT);
>> diff --git a/c/src/lib/libcpu/arm/shared/arm920/mmu_support.h b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.h
>> index 0000000..98744e9
>> --- /dev/null
>> +++ b/c/src/lib/libcpu/arm/shared/arm920/mmu_support.h
>> @@ -0,0 +1,95 @@
>> +* COPYRIGHT (c) 2012
>> +* On-Line Applications Research Corporation (OAR).
>> +* The license and distribution terms for this file may be
>> +* found in the file LICENSE in this distribution or at
>> +* http://www.rtems.com/license/LICENSE.
>> +#ifndef __MMU_SUPPORT_H_
>> +#define __MMU_SUPPORT_H_
>> +#include<stdint.h>
>> +#define MMU_CTRL_MMU_EN (1<< 0)
>> +#define MMU_CTRL_MMU_DES (0<< 0)
>> +#define MMU_CTRL_ALIGN_FAULT_EN (1<< 1)
>> +#define MMU_CTRL_D_CACHE_EN (1<< 2)
>> +#define MMU_CTRL_D_CACHE_DES (0<< 2)
>> +#define MMU_CTRL_DEFAULT (0xf<< 3)
>> +#define MMU_CTRL_LITTLE_ENDIAN (0<< 7)
>> +#define MMU_CTRL_BIG_ENDIAN (1<< 7)
>> +#define MMU_CTRL_SYS_PROT (1<< 8)
>> +#define MMU_CTRL_ROM_PROT (1<< 9)
>> +#define MMU_CTRL_I_CACHE_EN (1<< 12)
>> +#define MMU_CTRL_I_CACHE_DES (0<< 12)
>> +#define MMU_CTRL_LOW_VECT (0<< 13)
>> +#define MMU_CTRL_HIGH_VECT (1<< 13)
>> +#define ARM_MMU_AP_NOPR 0x03
>> +#define ARM_MMU_AP_USER_READ_ONLY 0x02
>> +#define ARM_MMU_AP_USER_NO_ACCESS 0x01
>> +#define ARM_MMU_AP_NO_ACCESS 0x00
>> +#define ARM_MMU_cb 0x0 //cache and buffer disabled
>> +#define ARM_MMU_cB 0x1 // cache disable and buffer enabled
>> +#define ARM_MMU_WT 0x2 // Write through
>> +#define ARM_MMU_WB 0x3 // Write Back
Please no C++ style comments
>> +/* FAULT ENTRY */
>> +#define MMU_SET_FAULT (0x0)
>> +/* FIXME: ARM supports various page sizes */
>> +#define ARM_MMU_PAGE_SIZE 0x1000
>> +#define MMU_SECT_SIZE 0x100000
>> +/* Set lvl1 PTE to point to the base of a page table mapping
>> + * 4K pages
>> +#define MMU_SET_LVL1_DIR_4K_PAGES(lvl2_base, dom) \
>> + ((((lvl2_base)& 0xfffffc00)) | \
>> + (((dom)&0xf)<<5) | \
>> + 0x11)
>> +#define MMU_SET_LVL2_PTE_4KB(paddr,ap,c,b) \
>> + (((paddr)&0xfffff000) | \
>> + ((ap)<<10) | \
>> + ((ap)<<8) | \
>> + ((ap)<<6) | \
>> + ((ap)<<4) | \
>> + ((c)<<3) | \
>> + ((b)<<2) | \
>> + 0x2)
>> +#define MMU_SET_LVL1_SECT(addr, ap, dom, ce, be) \
>> + ((((addr)& 0xfff00000)) | \
>> + ((ap)<< 10) | \
>> + ((dom)<< 5) | \
>> + ((ce)<< 3) | \
>> + ((be)<< 2) | \
>> + 0x12)
>> +/* TODO: Add other page sizes */
>> +typedef enum { LVL1_PT, LVL2_PT } pt_type;
>> +typedef uint32_t mmu_lvl1_t;
>> +typedef uint32_t mmu_lvl2_t;
>> +/* This Control Structure applies for most ARM architectures */
>> +typedef struct{
>> +uint32_t vAddress;
>> +/* physical address for page table lvl2 or lvl1 controlling a region */
>> +uint32_t ptAddress;
>> +/* physical address for level 1 page table */
>> +uint32_t ptlvl1Address;
>> +/* Number of used PTEs from this page table */
>> +uint16_t pagesNumber;
>> +/* lvl2 , lvl1 */
>> +pt_type type;
>> +uint8_t ap;
>> +uint8_t cb;
>> +uint8_t domain;
>> +} arm_bsp_mm_mpe;
> This probably should be arm920_mm_mpe or something, or the definition
> should be provided in a shared arm-bsp header file.
The indentation looks suspect.
>> +#endif
>> 1.7.1
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
Ask me about RTEMS: a free RTOS Huntsville AL 35806
