[PATCH] Move <memory.h> and <sys/uio.h> to non-networking directory
Wed Sep 5 18:39:44 UTC 2012
Hi
This is the patch to RTEMS which needs review.
I have built both current networking code and new
networking code.
These two header files were installed from libnetworking even
when networking was disabled. This patch moves them to a
non-networking location and updates uio.h to match the FreeBSD 8.x
source being used for the USB stack and TCP/IP stack upgrade.
  - cpukit/include/memory.h
    Move from cpukit/libnetworking/memory.h. No changes
  - cpukit/include/sys/uio.h
    Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x
version.
  - cpukit/include/sys/_iovec.h
    New. FreeBSD 8.x file supporting <sys/uio.h>.
  - cpukit/Makefile.am
    Reflect movement of <memory.h> and <sys/uio.h>.
  - cpukit/preinstall.am
    Regenerate
  - cpukit/libnetworking/nfs/bootp_subr.c
    Eliminate use of uio_procp field no longer in FreeBSD structure. This
    field was set and never read so eliminating the set has no impact.
Joel Sherrill, Ph.D.             Director of Research&   Development
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120905/8645ffa9/attachment.ksh>
