[rtems-libbsd commit] Merge branch 'master' of ssh://git.rtems.org/data/git /rtems-libbsd
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Sep 6 15:49:22 UTC 2012
Is all it takes to get this doing a push which gets rejected because
you forgot to pull to get up to date first?
Is there a "reset" step I am completely unaware of when this
happens?
===> Push attempt rejected
[joel at iceland rtems-libbsd]$ git push
To ssh://joel@git.rtems.org/data/git/rtems-libbsd.git
! [rejected] master -> master (non-fast-forward)
error: failed to push some refs to
'ssh://joel@git.rtems.org/data/git/rtems-libbsd.git'
To prevent you from losing history, non-fast-forward updates were rejected
Merge the remote changes before pushing again. See the 'Note about
fast-forwards' section of 'git push --help' for details.
===> Then a pull attempt
[joel at iceland rtems-libbsd]$ git pull
remote: Counting objects: 26, done.
remote: Compressing objects: 100% (15/15), done.
remote: Total 17 (delta 5), reused 0 (delta 0)
Unpacking objects: 100% (17/17), done.
From ssh://git.rtems.org/data/git/rtems-libbsd
6d7f488..bd2941b master -> origin/master
error: Your local changes to 'freebsd-userspace/Makefile' would be
overwritten by merge. Aborting.
Please, commit your changes or stash them before you can merge.
===> OK.. stashing my local changes
[joel at iceland rtems-libbsd]$ git stash
Saved working directory and index state WIP on master: 7b1b5b8 Revert
patches moving include of port_local.h to top of file
HEAD is now at 7b1b5b8 Revert patches moving include of port_local.h to
top of file
===> Then a successful pull
Merge made by recursive.
.gitignore | 1 +
freebsd-userspace/Makefile | 15 +-
freebsd-userspace/commands/sbin/route/keywords | 55 +
freebsd-userspace/commands/sbin/route/route.8 | 411 ++++++
freebsd-userspace/commands/sbin/route/route.c | 1681
freebsd-userspace/from-freebsd.sh | 2 +
freebsd-userspace/include/netatalk/at.h | 2 +
freebsd-userspace/include/netinet/if_ether.h | 2 +
8 files changed, 2168 insertions(+), 1 deletions(-)
create mode 100644 freebsd-userspace/commands/sbin/route/keywords
create mode 100644 freebsd-userspace/commands/sbin/route/route.8
create mode 100644 freebsd-userspace/commands/sbin/route/route.c
create mode 100644 freebsd-userspace/include/netatalk/at.h
create mode 100644 freebsd-userspace/include/netinet/if_ether.h
===> Finally the push I tried initially works
Counting objects: 74, done.
Delta compression using up to 2 threads.
Compressing objects: 100% (33/33), done.
Writing objects: 100% (39/39), 7.01 KiB, done.
Total 39 (delta 28), reused 5 (delta 3)
remote: 1: mail rtems-vc at rtems.org
remote: 2: update github
bd2941b..9dd5921 master -> master
On 09/06/2012 10:32 AM, Joel Sherrill wrote:
> Module: rtems-libbsd
> Branch: master
> Commit: 9dd59215ce0de247fadd2ad186e4050500943b4f
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=9dd59215ce0de247fadd2ad186e4050500943b4f
> Author: Joel Sherrill<joel.sherrill at oarcorp.com>
> Date: Thu Sep 6 10:36:47 2012 -0500
> Merge branch 'master' of ssh://git.rtems.org/data/git/rtems-libbsd
> rtems-vc mailing list
> http://www.rtems.org/mailman/listinfo/rtems-vc
Joel Sherrill, Ph.D. Director of Research& Development
