change log for rtems (2011-08-22)
Wed Sep 26 12:21:20 UTC 2012
On 08/22/2011 09:10 PM, rtems-vc at rtems.org wrote:
> 2011-08-22	Jennifer Averett <Jennifer.Averett at OARcorp.com>
> 	PR 1876
> 	* score/Makefile.am, score/include/rtems/score/isr.h, score/src/isr.c,
> 	score/src/smp.c, score/src/smplock.c, score/src/threaddispatch.c,
> 	score/src/threaddispatchdisablelevel.c: Add smp isr support.
> 	* score/src/isrsmp.c: New file.
> diff -u rtems/cpukit/score/src/threaddispatch.c:1.25 rtems/cpukit/score/src/threaddispatch.c:1.26
> --- rtems/cpukit/score/src/threaddispatch.c:1.25	Thu May 26 13:07:07 2011
> +++ rtems/cpukit/score/src/threaddispatch.c	Mon Aug 22 13:26:08 2011
> @@ -169,9 +169,10 @@
>   post_switch:
> -  _Thread_Dispatch_set_disable_level( 0 );
>     _ISR_Enable( level );
> +  _Thread_Unnest_dispatch();
>     _API_extensions_Run_postswitch();
This change and previous changes in the file threaddispatch.c are very bad.  In
fact they destroy the real-time properties of RTEMS completely.
Consider the following scenario.  We have three tasks L (lowest priority), M
(middle priority), and H (highest priority).  Now let a thread dispatch from M
to L happen.  An interrupt occurs in _Thread_Dispatch() here:
void _Thread_Dispatch( void )
post_switch:
   <-- INTERRUPT
   <-- AFTER INTERRUPT
The interrupt event makes task H ready.  The interrupt code will see
_Thread_Dispatch_disable_level > 0 and thus doesn't perform a
_Thread_Dispatch().  Now we return to position "AFTER INTERRUPT".  This means
task L executes now although task H is ready!  Task H will execute once someone
calls _Thread_Dispatch().
We should restore the previous behaviour at least for non-SMP configurations.
I am not sure how to deal with SMP here, but the current solution turns RTEMS
into a non-real time system.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120926/e71e8cff/attachment.bin>
