ticks for statistics was Re: change log for rtems (2011-05-26)
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Sep 28 22:23:58 UTC 2012
This works for me.
../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis \
__RTEMS_USE_TICKS_FOR_STATISTICS__=1 >c.log 2>&1 && \
make >b.log 2>&1
How did you configure and build?
On 09/26/2012 09:29 AM, Joel Sherrill wrote:
> On 9/26/2012 9:23 AM, Sebastian Huber wrote:
>> On 09/26/2012 03:51 PM, Joel Sherrill wrote:
>>> On 09/26/2012 08:48 AM, Sebastian Huber wrote:
>>>> On 09/26/2012 03:40 PM, Joel Sherrill wrote:
>>>>> On 09/26/2012 07:00 AM, Sebastian Huber wrote:
>>>>>> What has this change to do with SMP inter-process communications? Why do we
>>>>>> update _Thread_Time_of_last_context_switch in case
>>>>>> __RTEMS_USE_TICKS_FOR_STATISTICS__ is defined?
>>>>> At least I can explain this part of the change. There were technically
>>>>> two changes in that commit. They got merged into one and the comment
>>>>> doesn't reflect that.
>>>>> If you don't set the _Thread_Time_of_last_context_switch, then the
>>>>> statistics for rate monotonic periods are not completely right. You
>>>>> need to account for how long the current task has been running.
>>>> Ok, but then the rate-monotonic statistics do not honor the
>>>> __RTEMS_USE_TICKS_FOR_STATISTICS__. I currently don't have time to look at
>>>> this more detailed, but I think something is mixed up here.
>>> Where do they not honor that? I see it used in a number of
>>> rate monotonic files:
>>> ./include/rtems/rtems/ratemon.h
>>> ./src/ratemongetstatistics.c
>>> ./src/ratemongetstatus.c
>>> ./src/ratemonreportstatistics.c
>>> ./src/ratemonperiod.c
>> I think the purpose of the __RTEMS_USE_TICKS_FOR_STATISTICS__ is that we use
>> only ticks for the statistics.
>> The threaddispatch.c doesn't compile with __RTEMS_USE_TICKS_FOR_STATISTICS__
>> defined:
>> /home/sh/git-rtems/c/src/../../cpukit/score/src/threaddispatch.c: In function
>> '_Thread_Dispatch':
>> /home/sh/git-rtems/c/src/../../cpukit/score/src/threaddispatch.c:112:9:
>> warning: implicit declaration of function 'TOD_Get_uptime'
>> [-Wimplicit-function-declaration]
>> warning: nested extern declaration of 'TOD_Get_uptime' [-Wnested-externs]
>> /home/sh/git-rtems/c/src/../../cpukit/score/src/threaddispatch.c:112:26: error:
>> '_Thread_Time_of_last_context_switch' undeclared (first use in this function)
>> /home/sh/git-rtems/c/src/../../cpukit/score/src/threaddispatch.c:112:26: note:
>> each undeclared identifier is reported only once for each function it appears in
> OK. I will look into this if you don't fix it first. :)
Joel Sherrill, Ph.D. Director of Research& Development
