[PATCH] FB driver for Cirrus GD5446 graphic hardware.
Alexandru-Sever Horin alex.sever.h at gmail.com
Thu Sep 13 23:12:49 UTC 2012
Hi,
I have been busy today with packing, and tomorrow I will be unpacking to my
university town.
Thanks to Joel for the review. I will make the modifications as soon as I
get my PC up and running.
Also, to ease testing, there is a patch to rtems-testing pc386 script which
runs qemu with cirrus emulation.
Mainly, I agree with ppisa.
Testing for cirrus driver could be done with a working graphics code.
Also, the toolkit should pe cloned for testing. The compressed patch is
about 15MB.
Regards,
Alex Horin
On Thu, Sep 13, 2012 at 8:04 PM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Hello Joel,
> thanks for review.
> I would check if Alex is available now.
> But to move things forward I would push the work if
> time allows me.
> On Thursday 13 September 2012 18:45:19 Joel Sherrill wrote:
> > Thanks for posting this so quickly. Here are some quick comments:
> > + No Makefile.am changes?
> Not for now. I think, that it should be separate patch.
> Discussion on IRC. For simple test next
> To test it, next change is enough
> --- a/c/src/lib/libbsp/i386/pc386/Makefile.am
> +++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
> @@ -83,3 +83,4 @@ include_HEADERS += ../../i386/shared/comm/i386_io.h
>  libbsp_a_SOURCES += console/defkeymap.c
> -libbsp_a_SOURCES += console/fb_vga.c
> +#libbsp_a_SOURCES += console/fb_vga.c
> +libbsp_a_SOURCES += console/fb_cirrus.c
>  libbsp_a_SOURCES += console/keyboard.c
> I incline to the next as interim solution
> +if ENABLE_VGA_CIRRUS
> +else !ENABLE_VGA_CIRRUS
> +endif !ENABLE_VGA_CIRRUS
> It should be replaced by infrastructure for runtime driver registration.
> > + C++ style comments need to be C
> > + Some one-line C comments do not have a space before the */
> > + Use single blank lines not multiple ones in a row
> OK
> > + No license terms at top of file
> What is the best template in the RTEMS sources?
> > I assume it works as as we get more into the graphics-addon patches
> > I will be able to duplicate your results.
> It should work with any/old version of the graphic code
> or other independent projects.
> The rtems-graphics-toolkit is huge amount of the code and
> subprojects and number of copyend and changed code is huge too.
> Alex's version can be cloned from
>   git clone https://github.com/alex-sever-h/rtems-graphics-toolkit.git
> I can help with some filterring and squashing changes
> to help maintain readable history but I do not think
> that changes load should flow through mailinglist.
> They should get in through pull after testing.
> Best wishes,
>              Pavel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120914/a39d1354/attachment-0001.html>
