[PATCH v2] FB driver for Cirrus GD5446 graphic hardware.
Pavel Pisa
ppisa4lists at pikron.com
Thu Sep 27 22:26:19 UTC 2012
From: Alexandru-Sever Horin <alex.sever.h at gmail.com>
Subject: FB driver for Cirrus GD5446 graphic hardware.
Implementation is tested to work on QEMU simulator only.
QEMU offers this hardware by default for PC platform but
it can be requested by "-vga cirrus" option for other PCI
aware systems in development/next QEMU releases as well.
Next sources have been used for driver implementation:
- RTEMS fb_vga.c - Rosimildo da Silva ( rdasilva at connecttel.com )
- Cirrus xf86 driver - used as VGA hardware setup documentation
- CL-GD5446 Technical Reference Manual, 1996, Second Edition
fb_vga.c has to be replaced by fb_cirrus.c in
rtems/c/src/lib/libbsp/i386/pc386/Makefile.am
to test the driver now. We expect to discus and include driver
section mechanism after driver testing.
Patch version 2:
- comments style updated according to Joel Sherrill review
- use static for variables and functions to compile without warnings
Signed-off-by: Alexandru-Sever Horin <alex.sever.h at gmail.com>
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c | 764 +++++++++++++++++++++++
1 file changed, 764 insertions(+)
create mode 100644 c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c b/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
new file mode 100644
index 0000000..40ea570
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
@@ -0,0 +1,764 @@
+ * FB driver for Cirrus GD5446 graphic hardware.
+ * Tested to be compatible with QEMU GD5446 emulation but not on real HW.
+ * Copyright (c) 2012 - Alexandru-Sever Horin (alex.sever.h at gmail.com).
+ * http://www.rtems.com/license/LICENSE.
+ * The code is based on next information sources:
+ * - CL-GD5446 Technical Reference Manual, 1996, Second Edition
+ * - RTEMS fb_vga.c - Rosimildo da Silva ( rdasilva at connecttel.com )
+ * - Cirrus xf86 driver - used as VGA hardware setup sequence documentation
+#include <stdlib.h>
+#include <stdio.h>
+#include <errno.h>
+#include <sys/types.h>
+#include <pthread.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <rtems/libio.h>
+#include <rtems/pci.h>
+#include <rtems/fb.h>
+#include <rtems/framebuffer.h>
+/* mutex to limit driver to protect against multiple opens */
+static pthread_mutex_t cirrus_mutex = PTHREAD_MUTEX_INITIALIZER;
+/* screen information for the VGA driver
+ * standard structures
+static struct fb_var_screeninfo fb_var;
+static struct fb_fix_screeninfo fb_fix;
+#define CIRRUS_VENDOR_ID 0x1013
+#define CIRRUS_GD5446_DEVICE_ID 0x00b8
+typedef struct _DisplayModeRec {
+ struct _DisplayModeRec *prev;
+ struct _DisplayModeRec *next;
+ char *name; /* identifier for the mode */
+ int type;
+ /* These are the values that the user sees/provides */
+ int Clock; /* pixel clock freq (kHz) */
+ int HDisplay; /* horizontal timing */
+ int HSyncStart;
+ int HSyncEnd;
+ int HTotal;
+ int HSkew;
+ int VDisplay; /* vertical timing */
+ int VSyncStart;
+ int VSyncEnd;
+ int VTotal;
+ int VScan;
+ int Flags;
+ /* These are the values the hardware uses */
+ int ClockIndex;
+ int SynthClock; /* Actual clock freq to
+ * be programmed (kHz) */
+ int CrtcHDisplay;
+ int CrtcHBlankStart;
+ int CrtcHSyncStart;
+ int CrtcHSyncEnd;
+ int CrtcHBlankEnd;
+ int CrtcHTotal;
+ int CrtcHSkew;
+ int CrtcVDisplay;
+ int CrtcVBlankStart;
+ int CrtcVSyncStart;
+ int CrtcVSyncEnd;
+ int CrtcVBlankEnd;
+ int CrtcVTotal;
+ int CrtcHAdjusted;
+ int CrtcVAdjusted;
+ int PrivSize;
+ int32_t *Private;
+ int PrivFlags;
+ float HSync, VRefresh;
+} DisplayModeRec, *DisplayModePtr;
+static DisplayModeRec available_modes[] = {
+ .Clock = 31500 ,
+ .HDisplay = 640 ,
+ .HSyncStart = 664 ,
+ .HSyncEnd = 704 ,
+ .HTotal = 832 ,
+ .HSkew = 0 ,
+ .VDisplay = 480 , /* vertical timing */
+ .VSyncStart = 489 ,
+ .VSyncEnd = 491 ,
+ .VTotal = 520 ,
+ .VScan = 0,
+ .Flags = 0
+ .Clock = 40000 ,
+ .HDisplay = 800 ,
+ .HSyncStart = 840 ,
+ .HSyncEnd = 968 ,
+ .HTotal = 1056 ,
+ .HSkew = 0 ,
+ .VDisplay = 600 , /* vertical timing */
+ .VSyncStart = 601 ,
+ .VSyncEnd = 605 ,
+ .VTotal = 628 ,
+ .VScan = 0,
+ .Flags = 0
+static DisplayModePtr active_mode;
+/* The display mode used for the board hardcoded in the following define
+ * Index in above structure
+#define CIRRUS_DISPLAY_MODE 0
+/* The display bytes per pixel used for the board hardcoded in the following define
+#define CIRRUS_DEFAULT_BPP 24
+/* cirrus board information */
+struct cirrus_board_str{
+ int pci_bus;
+ int pci_device;
+ int pci_function;
+ void *reg_base;
+static struct cirrus_board_str cirrus_board_info;
+ * get information from the board
+static int
+cirrus_pci_read( struct cirrus_board_str *cirrus_board, uint32_t *mem_base, uint32_t *cirrus_register_base)
+ int r;
+ r = pci_read_config_dword(
+ cirrus_board->pci_bus, cirrus_board->pci_device, cirrus_board->pci_function,
+ PCI_BASE_ADDRESS_0, mem_base);
+ if( r != PCIB_ERR_SUCCESS)
+ return RTEMS_UNSATISFIED;
+ PCI_BASE_ADDRESS_1, cirrus_register_base);
+ *mem_base &= PCI_BASE_ADDRESS_MEM_MASK;
+ *cirrus_register_base &= PCI_BASE_ADDRESS_MEM_MASK;
+ return RTEMS_SUCCESSFUL;
+static inline int
+fb_cirrus_read_config_dword(
+ struct cirrus_board_str *fbst,
+ unsigned char where,
+ uint32_t *pval)
+ return pci_read_config_dword(
+ fbst->pci_bus, fbst->pci_device, fbst->pci_function,
+ where, pval);
+static inline int
+fb_cirrus_write_config_dword(
+ uint32_t val)
+ return pci_write_config_dword(
+ where, val);
+static inline void
+fb_cirrus_write_reg8 (
+ const struct cirrus_board_str *fbst,
+ unsigned int reg,
+ unsigned int val)
+ *(volatile uint8_t*)((char *)fbst->reg_base + reg) = val;
+static inline unsigned int
+fb_cirrus_read_reg8 (
+ unsigned int reg)
+ return *(volatile uint8_t*)((char *)fbst->reg_base + reg);
+#define SEQ_INDEX 0x04
+#define SEQ_DATA 0x05
+static inline void
+fb_cirrus_write_seq_reg (
+ unsigned int reg,
+ unsigned int val)
+ fb_cirrus_write_reg8(fbst, SEQ_INDEX, reg);
+ fb_cirrus_write_reg8(fbst, SEQ_DATA, val);
+fb_cirrus_read_seq_reg (
+ unsigned int reg)
+ return fb_cirrus_read_reg8(fbst, SEQ_DATA);
+#define CRT_INDEX 0x14
+#define CRT_DATA 0x15
+static inline void
+fb_cirrus_write_crt_reg (
+ unsigned int reg,
+ unsigned int val)
+ fb_cirrus_write_reg8(fbst, CRT_INDEX, reg);
+ fb_cirrus_write_reg8(fbst, CRT_DATA, val);
+fb_cirrus_read_crt_reg (
+ unsigned int reg)
+ return fb_cirrus_read_reg8(fbst, CRT_DATA);
+#define GDC_INDEX 0x0E
+#define GDC_DATA 0x0F
+static inline void
+fb_cirrus_write_gdc_reg (
+ unsigned int reg,
+ unsigned int val)
+ fb_cirrus_write_reg8(fbst, GDC_INDEX, reg);
+ fb_cirrus_write_reg8(fbst, GDC_DATA, val);
+fb_cirrus_read_gdc_reg (
+ unsigned int reg)
+ return fb_cirrus_read_reg8(fbst, GDC_DATA);
+#define VGA_DAC_MASK 0x06
+static inline void
+fb_cirrus_write_hdr_reg (
+ unsigned int val)
+ volatile unsigned int dummy __attribute__((unused));
+ dummy = fb_cirrus_read_reg8(fbst, VGA_DAC_MASK);
+ fb_cirrus_write_reg8(fbst, VGA_DAC_MASK, val);
+/* Functionality to support multiple VGA frame buffers can be added easily,
+ * but is not supported at this moment because there is no need for two or
+ * more "classic" VGA adapters. Multiple frame buffer drivers may be
+ * implemented and If we had implement it they would be named as "/dev/fb0",
+ * "/dev/fb1", "/dev/fb2" and so on.
+ * fb_cirrus device driver INITIALIZE entry point.
+rtems_device_driver
+frame_buffer_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ rtems_status_code status;
+ int res;
+ printk( "FB_CIRRUS -- driver initializing..\n" );
+ res = pci_find_device(
+ CIRRUS_VENDOR_ID,
+ CIRRUS_GD5446_DEVICE_ID,
+ minor,
+ &cirrus_board_info.pci_bus,
+ &cirrus_board_info.pci_device,
+ &cirrus_board_info.pci_function
+ if ( res != PCIB_ERR_SUCCESS ) {
+ printk( "FB_CIRRUS initialize -- device not found\n" );
+ else{
+ * Register the device
+ status = rtems_io_register_name ("/dev/fb0", major, 0);
+ if (status != RTEMS_SUCCESSFUL) {
+ printk("Error registering /dev/fb0 FB_CIRRUS framebuffer device!\n");
+ rtems_fatal_error_occurred( status );
+ * This function is used to initialize the Start Address - the first
+ * displayed location in the video memory.
+ * Usually mandatory
+static void
+cirrus_adjust_frame( struct cirrus_board_str *board, int x, int y)
+ uint32_t Base;
+ uint8_t tmp;
+ Base = ((y * fb_var.xres + x) >> 3);
+ if (fb_var.bits_per_pixel != 1)
+ Base *= (fb_var.bits_per_pixel >> 2);
+ printk("FB_CIRRUS: cirrus_adjust_frame %d %d >>> %d %x\n", x, y, Base, Base);
+ if ((Base & ~0x000FFFFF) != 0) {
+ printk("FB_CIRRUS: Internal error: cirrus_adjust_frame: cannot handle overflow\n");
+ return;
+ fb_cirrus_write_crt_reg( board, 0x0C, (Base >> 8) & 0xff);
+ fb_cirrus_write_crt_reg( board, 0x0D, Base & 0xff);
+ tmp = fb_cirrus_read_crt_reg( board, 0x1B);
+ tmp &= 0xF2;
+ tmp |= (Base >> 16) & 0x01;
+ tmp |= (Base >> 15) & 0x0C;
+ fb_cirrus_write_crt_reg( board, 0x1B, tmp);
+ tmp = fb_cirrus_read_crt_reg( board, 0x1D);
+ tmp &= 0x7F;
+ tmp |= (Base >> 12) & 0x80;
+ fb_cirrus_write_crt_reg( board, 0x1D, tmp);
+static int
+cirrus_set_mode(DisplayModePtr mode)
+ int depthcode = fb_var.bits_per_pixel;;
+ int width;
+ int HDiv2 = 0, VDiv2 = 0;
+ const struct cirrus_board_str *cirrus_board_ptr = &cirrus_board_info;
+ int temp;
+ int hdr = -1;
+ printk("FB_CIRRUS: mode %d bpp, %d Hz %d %d %d %d %d %d %d %d\n",
+ fb_var.bits_per_pixel,
+ mode->Clock,
+ mode->HDisplay,
+ mode->HSyncStart,
+ mode->HSyncEnd,
+ mode->HTotal,
+ mode->VDisplay,
+ mode->VSyncStart,
+ mode->VSyncEnd,
+ mode->VTotal);
+ if ( mode->Clock > 85500 ) {
+ /* The actual DAC register value is set later. */
+ /* The CRTC is clocked at VCLK / 2, so we must half the */
+ /* horizontal timings. */
+ if (!mode->CrtcHAdjusted) {
+ mode->HDisplay >>= 1;
+ mode->HSyncStart >>= 1;
+ mode->HTotal >>= 1;
+ mode->HSyncEnd >>= 1;
+ mode->SynthClock >>= 1;
+ mode->CrtcHAdjusted = TRUE;
+ depthcode += 64;
+ HDiv2 = 1;
+ if (mode->VTotal >= 1024 ) {
+ /* For non-interlaced vertical timing >= 1024, the vertical timings */
+ /* are divided by 2 and VGA CRTC 0x17 bit 2 is set. */
+ if (!mode->CrtcVAdjusted) {
+ mode->VDisplay >>= 1;
+ mode->VSyncStart >>= 1;
+ mode->VSyncEnd >>= 1;
+ mode->VTotal >>= 1;
+ mode->CrtcVAdjusted = TRUE;
+ VDiv2 = 1;
+ * Sequential registers
+ fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x00, 0x00);
+ fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x01, 0x01);
+ fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x02, 0x0F);
+ fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x03, 0x00);
+ fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x04, 0x0E);
+ * CRTC Controller Registers
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x00, (mode->HTotal >> 3) - 5 );
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x01, (mode->HDisplay >> 3) - 1);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x02, (mode->HSyncStart >> 3) - 1);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x03, ((mode->HSyncEnd >> 3) & 0x1F) | 0x80);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x04, (mode->HSyncStart >> 3));
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x05,
+ (((mode->HSyncEnd >> 3) & 0x20 ) << 2 )
+ | (((mode->HSyncEnd >> 3)) & 0x1F));
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x06, (mode->VTotal - 2) & 0xFF);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x07,
+ (((mode->VTotal -2) & 0x100) >> 8 )
+ | (((mode->VDisplay -1) & 0x100) >> 7 )
+ | ((mode->VSyncStart & 0x100) >> 6 )
+ | (((mode->VSyncStart) & 0x100) >> 5 )
+ | 0x10
+ | (((mode->VTotal -2) & 0x200) >> 4 )
+ | (((mode->VDisplay -1) & 0x200) >> 3 )
+ | ((mode->VSyncStart & 0x200) >> 2 ));
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x08, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x09, ((mode->VSyncStart & 0x200) >>4) | 0x40);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0A, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0B, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0C, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0D, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0E, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0F, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x10, mode->VSyncStart & 0xFF);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x11, (mode->VSyncEnd & 0x0F) | 0x20);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x12, (mode->VDisplay -1) & 0xFF);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x13, 0x00); /* no interlace */
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x14, 0x00);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x15, mode->VSyncStart & 0xFF);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x16, (mode->VSyncStart +1) & 0xFF);
+ temp = 0xAF;
+ if(VDiv2)
+ temp |= 0x04;
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x17, temp);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x18, 0xFF);
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x1A ,
+ (((mode->HTotal >> 3) & 0xC0 ) >> 2)
+ | (((mode->VTotal - 2) & 0x300 ) >> 2));
+ width = fb_fix.line_length >> 3;
+ if (fb_var.bits_per_pixel == 1)
+ width <<= 2;
+ if(width >= 0xFF)
+ printk("FB_CIRRUS: Warning line size over the limit ... reduce bpp or width resolution");
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x13, width);
+ /* Offset extension (see CR13) */
+ temp = fb_cirrus_read_crt_reg( cirrus_board_ptr, 0x1B);
+ temp &= 0xAF;
+ temp |= (width >> (3+4)) & 0x10;
+ temp |= (width >> (3+3)) & 0x40;
+ temp |= 0x22;
+ fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x1B, temp);
+ * Enable linear mode and high-res packed pixel mode
+ temp = fb_cirrus_read_seq_reg( cirrus_board_ptr, 0x07);
+ temp &= 0xe0;
+ switch (depthcode) {
+ case 1:
+ case 4:
+ temp |= 0x10;
+ break;
+ case 8:
+ temp |= 0x11;
+ break;
+ case 64+8:
+ temp |= 0x17;
+ break;
+ case 15:
+ temp |= 0x17;
+ hdr = 0xC0; /* 5:5:5 Sierra */
+ break;
+ case 16:
+ temp |= 0x17;
+ hdr = 0xC1; /* 5:6:5 XGA mode */
+ break;
+ case 24:
+ temp |= 0x15;
+ hdr = 0xC5; /* 8:8:8 16M colors */
+ break;
+ case 32:
+ temp |= 0x19;
+ break;
+ default:
+ printk("FB_CIRRUS: Cannot Initialize display to requested mode\n");
+ printk("FB_CIRRUS: returning RTEMS_UNSATISFIED on depthcode %d\n", depthcode);
+ fb_cirrus_write_seq_reg( cirrus_board_ptr, 0x07, temp);
+ /* this just set packed pixel mode with according bpp */
+ * HDR Register
+ if(hdr > 0)
+ fb_cirrus_write_hdr_reg( cirrus_board_ptr, hdr);
+ * Graphic Data Controller Registers
+ temp = fb_cirrus_read_gdc_reg( cirrus_board_ptr, 0x12);
+ if (HDiv2)
+ temp |= 0x20;
+ else
+ temp &= ~0x20;
+ fb_cirrus_write_gdc_reg( cirrus_board_ptr, 0x12, temp);
+ /* Enable high-color modes */
+ fb_cirrus_write_gdc_reg(cirrus_board_ptr, 0x05, 0x40);
+ /* VGA graphics mode */
+ fb_cirrus_write_gdc_reg(cirrus_board_ptr, 0x06, 0x01);
+ return TRUE;
+static void
+cirrus_prepare_mode( void )
+ active_mode = &available_modes[CIRRUS_DISPLAY_MODE];
+ fb_var.bits_per_pixel = CIRRUS_DEFAULT_BPP;
+ fb_var.xres = active_mode->HDisplay;
+ fb_var.yres = active_mode->VDisplay;
+ fb_fix.line_length = (fb_var.xres * fb_var.bits_per_pixel + 7) / 8;
+ fb_fix.type = FB_TYPE_PACKED_PIXELS;
+ fb_fix.visual = FB_VISUAL_TRUECOLOR;
+ * fb_cirrus device driver OPEN entry point
+frame_buffer_open(
+ void *arg
+ int r;
+ uint32_t smem_start, regs_start;
+ if (pthread_mutex_trylock(&cirrus_mutex)!= 0){
+ printk( "FB_CIRRUS could not lock cirrus_mutex\n" );
+ r = cirrus_pci_read(&cirrus_board_info, &smem_start, ®s_start);
+ if ( r == RTEMS_UNSATISFIED )
+ fb_fix.smem_start = (volatile char *)smem_start;
+ fb_fix.smem_len = 0x1000000;
+ cirrus_board_info.reg_base = (void *)regs_start;
+ cirrus_prepare_mode();
+ cirrus_set_mode( active_mode );
+ cirrus_adjust_frame( &cirrus_board_info, 0, 0);
+ if (1) {
+ uint32_t pixmask;
+ int x, y;
+ if(fb_var.bits_per_pixel == 32)
+ pixmask = 0xffffff;
+ else
+ pixmask = (1 << fb_var.bits_per_pixel) - 1;
+ printk("FB_CIRRUS: mode set, test patter output\n");
+ for(y = 0; y < fb_var.yres; y++) {
+ for(x = 0; x < fb_var.xres; x++) {
+ uint32_t color;
+ char *addr = (char *)fb_fix.smem_start;
+ addr += y * fb_fix.line_length;
+ addr += x * fb_var.bits_per_pixel / 8;
+ color = x & 1 ? 0 : y & 1 ? pixmask & 0x000ff00f : pixmask;
+ if(y == fb_var.yres - 1) {
+ if((x > 0) && (x < fb_var.xres-1))
+ color = pixmask & 0x00555555;
+ switch (fb_var.bits_per_pixel) {
+ case 8: *(volatile uint8_t*) addr = color;
+ break;
+ case 16: *(volatile uint16_t*) addr = color;
+ break;
+ case 24: *(volatile uint32_t*) addr =
+ (*(volatile uint32_t*) addr & 0xff000000) | color;
+ break;
+ case 32: *(volatile uint32_t*) addr = color;
+ break;
+ * fb_cirrus device driver CLOSE entry point
+frame_buffer_close(
+ void *arg
+ if (pthread_mutex_unlock(&cirrus_mutex) == 0){
+ /* restore previous state. for VGA this means return to text mode.
+ * leave out if graphics hardware has been initialized in
+ * frame_buffer_initialize() */
+ /* VGA text mode */
+ fb_cirrus_write_gdc_reg(&cirrus_board_info, 0x06, 0x00);
+ printk( "FB_CIRRUS: close called.\n" );
+ * fb_cirrus device driver READ entry point.
+frame_buffer_read(
+ void *arg
+ rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *)arg;
+ rw_args->bytes_moved = ((rw_args->offset + rw_args->count) > fb_fix.smem_len ) ? (fb_fix.smem_len - rw_args->offset) : rw_args->count;
+ memcpy(rw_args->buffer, (const void *) (fb_fix.smem_start + rw_args->offset), rw_args->bytes_moved);
+ * frame_buffer device driver WRITE entry point.
+frame_buffer_write(
+ void *arg
+ memcpy( (void *) (fb_fix.smem_start + rw_args->offset), rw_args->buffer, rw_args->bytes_moved);
+static int
+get_fix_screen_info( struct fb_fix_screeninfo *info )
+ *info = fb_fix;
+ return 0;
+static int
+get_var_screen_info( struct fb_var_screeninfo *info )
+ *info = fb_var;
+ return 0;
+ * IOCTL entry point -- This method is called to carry
+ * all services of this interface.
+frame_buffer_control(
+ void *arg
+ rtems_libio_ioctl_args_t *args = arg;
+ printk( "FB_CIRRUS ioctl called, cmd=%x\n", args->command );
+ switch( args->command ) {
+ case FBIOGET_FSCREENINFO:
+ args->ioctl_return = get_fix_screen_info( ( struct fb_fix_screeninfo * ) args->buffer );
+ break;
+ case FBIOGET_VSCREENINFO:
+ args->ioctl_return = get_var_screen_info( ( struct fb_var_screeninfo * ) args->buffer );
+ break;
+ case FBIOPUT_VSCREENINFO:
+ /* not implemented yet */
+ args->ioctl_return = -1;
+ case FBIOGETCMAP:
+ /* no palette - truecolor mode */
+ case FBIOPUTCMAP:
+ default:
+ args->ioctl_return = 0;
+ break;
1.7.10.4
