RFC: ARM GCC changes
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Sep 25 10:04:05 UTC 2012
On 09/25/2012 10:54 AM, Sebastian Huber wrote:
> This is an updated patch for the GCC 4.8. It renames the target
> "arm-rtemseabi" to "arm-rtems" to bring the ARM tool chain back to the
> standard RTEMS target pattern "$ARCH-rtems".
As I tried to tell you several times before, I consider this step
a) to be silly, because it raises abiguities to the "arm-rtems*" target
tuple and breaks the clear distingtion between "arm-rtems" and
"arm-rtemseabi*" we currently have.
b) contradicts upstream GCC conventions to name all arm-*eabi targets
'*eabi".
> GCC test suite results for arm-rtems4.11:
> http://gcc.gnu.org/ml/gcc-testresults/2012-09/msg02507.html
> If nobody objects, then I will post this patch to the GCC patches
> mailing list next week.
Formal objection - I feel you are shooting yourselfs into your own foot
and consider this proposal to be harmful.
Ralf
