Zynq BSP progress
Mon Apr 15 07:14:28 UTC 2013
On 04/12/2013 06:18 PM, Claus, Ric wrote:
> Thanks, Sebastian.  I did do exactly that initially, but as I tried to explain, the DMA engine uses the lower two address bits for other things.  I therefore can't put m->m_data on a 16 bit word boundary.  So then what?
Oh, this is bad.  Supports the DMA engine some padding?  I think the main
problem is in ip.h the struct ip { ... } aligned(4).  I would remove the
aligned(4) and try if that works.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
