[PATCH 2/2] Initial bsp for Tiny6410
Peng Fan
van.freenix at gmail.com
Wed Apr 17 07:41:38 UTC 2013
Hi Sebastian,
Thanks for your reviewing the patch.
I'll modify the code and add the copyright related header.
Because s3c6410 is based on armv6 architecture, I create the linkcmds. I'll
move the size stack setting to linkcmds.armv4.Thanks again.
Regards,
Peng.
2013/4/17 Sebastian Huber <sebastian.huber at embedded-brains.de>
> Hello Peng Fan,
> thanks for your new BSP. I have some comments.
> On 04/17/2013 07:27 AM, Peng Fan wrote:
>> diff --git a/c/src/lib/libbsp/arm/shared/**startup/linkcmds.armv6
>> b/c/src/lib/libbsp/arm/shared/**startup/linkcmds.armv6
>> new file mode 100644
>> index 0000000..16fa3ef
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/arm/shared/**startup/linkcmds.armv6
>> @@ -0,0 +1,26 @@
>> + * @file
>> + * @ingroup bsp_linker
>> + * @brief Linker command file for ARMv6 architecture.
>> + * Copyright (c) 2010 embedded brains GmbH. All rights reserved.
>> + * embedded brains GmbH
>> + * Obere Lagerstr. 30
>> + * 82178 Puchheim
>> + * Germany
>> + *<rtems at embedded-brains.de>
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + *http://www.rtems.com/license/**LICENSE<http://www.rtems.com/license/LICENSE>
>> +bsp_stack_svc_size = DEFINED (bsp_stack_svc_size) ? bsp_stack_svc_size :
>> 4096;
>> +bsp_stack_svc_size = ALIGN (bsp_stack_svc_size, bsp_stack_align);
>> +INCLUDE linkcmds.base
> I think this file is superfluous and you should use the linkcmds.armv4 in
> your BSP. If the SVC stack size is too small for your BSP, then change it
> in the BSP specific linker command file.
> Please make sure that all files have a copyright and license header.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130417/b531994d/attachment.html>
