GSoC 2013
jinyang.sia
jinyang.sia at gmail.com
Wed Apr 17 14:48:30 UTC 2013
Hi,
Sorry for the emails, some error occurs when I try to add attachments using the Foxmail. The screenshot still work if you change the extention to .png. And i try to send a email again use the google server, opps, some errors occur again. I do know what happens. sorry for the truobles.
I want to particiapte in the GSoC2013, and i want to add a CAN driver and CAN API including interface for low level interface.
CAN bus originally developed for automotive applications, but now it has widely used in other areas of industry, such as medical devices, agriculture vehicles, maritime, factory automation, process automation, etc. RTEMS, as a real-time embedded system, is also widely used in such areas. What i want to do is to develop a CAN driver for RTEMS, and also a whole CAN API, stack and low level driver interface.
Hope it works.
jinyang.sia
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130417/9d88a0af/attachment.html>
