GSoC 2013
Rempel, Cynthia cynt6007 at vandals.uidaho.edu
Thu Apr 18 02:30:28 UTC 2013
Hi Jinyang Sia,
Wow, the CAN driver sounds really useful!
Could you send the hello, world screenshot as a .pdf, .bmp, or .tif?
I tried to change the file you sent as a .txt to a .png and it didn't work...
Once you do that could you please add yourself to the table at
http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode and tell us some more about your project?
-Cynthia Rempel
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of jinyang.sia [jinyang.sia at gmail.com]
Sent: Wednesday, April 17, 2013 7:48 AM
To: rtems-devel
Subject: GSoC 2013
Hi,
Sorry for the emails, some error occurs when I try to add attachments using the Foxmail. The screenshot still work if you change the extention to .png. And i try to send a email again use the google server, opps, some errors occur again. I do know what happens. sorry for the truobles.
I want to particiapte in the GSoC2013, and i want to add a CAN driver and CAN API including interface for low level interface.
CAN bus originally developed for automotive applications, but now it has widely used in other areas of industry, such as medical devices, agriculture vehicles, maritime, factory automation, process automation, etc. RTEMS, as a real-time embedded system, is also widely used in such areas. What i want to do is to develop a CAN driver for RTEMS, and also a whole CAN API, stack and low level driver interface.
Hope it works.
jinyang.sia
