[PATCH] Remove MIPS GCC 4.8 patch
Thu Apr 18 07:29:47 UTC 2013
This patch is superfluous.  The include order is
1. mips/elf.h
2. mips/rtems.h
as defined by gcc/config.gcc (mips*-*-rtems*).
Example pre-processor output:
	# 1 "/home/sh/archive/gcc-git/gcc/config/mips/elf.h" 1
	# 22 "/home/sh/archive/gcc-git/gcc/config/mips/elf.h"
	#undef SET_ASM_OP
	#define ASM_OUTPUT_DEF(FILE,LABEL1,LABEL2) do { fputc ('\t', FILE);
	assemble_name (FILE, LABEL1); fputs (" = ", FILE); assemble_name (FILE,
	LABEL2); fputc ('\n', FILE); } while (0)
	# 34 "/home/sh/archive/gcc-git/gcc/config/mips/elf.h"
	#undef ASM_DECLARE_OBJECT_NAME
	#define ASM_DECLARE_OBJECT_NAME mips_declare_object_name
	#undef ASM_FINISH_DECLARE_OBJECT
	#define ASM_FINISH_DECLARE_OBJECT mips_finish_declare_object
	#undef LIB_SPEC
	#define LIB_SPEC ""
	#undef STARTFILE_SPEC
	#define STARTFILE_SPEC "crti%O%s crtbegin%O%s"
	#undef ENDFILE_SPEC
	#define ENDFILE_SPEC "crtend%O%s crtn%O%s"
	#define NO_IMPLICIT_EXTERN_C 1
	# 21 "./tm.h" 2
	# 1 "/home/sh/archive/gcc-git/gcc/config/mips/rtems.h" 1
	# 23 "/home/sh/archive/gcc-git/gcc/config/mips/rtems.h"
	#define TARGET_OS_CPP_BUILTINS() do { builtin_define ("__rtems__");
	builtin_define ("__USE_INIT_FINI__"); builtin_assert ("system=rtems"); }
	while (0)
	# 33 "/home/sh/archive/gcc-git/gcc/config/mips/rtems.h"
	#undef MIPS_DEFAULT_GVALUE
	#define MIPS_DEFAULT_GVALUE 0
	# 22 "./tm.h" 2
	# 1 "/home/sh/archive/gcc-git/gcc/config/rtems.h" 1
	# 21 "/home/sh/archive/gcc-git/gcc/config/rtems.h"
	#undef NO_IMPLICIT_EXTERN_C
See also
http://www.rtems.com/ml/rtems-users/2008/april/msg00254.html
 patches/gcc-4.8.0-rtems4.11-20130326.diff |   14 --------------
 1 files changed, 0 insertions(+), 14 deletions(-)
diff --git a/patches/gcc-4.8.0-rtems4.11-20130326.diff b/patches/gcc-4.8.0-rtems4.11-20130326.diff
index 7054534..72b1534 100644
--- a/patches/gcc-4.8.0-rtems4.11-20130326.diff
+++ b/patches/gcc-4.8.0-rtems4.11-20130326.diff
@@ -39,11 +39,6 @@ diff -Naur gcc-4.8.0.orig/gcc/ChangeLog.rtems gcc-4.8.0/gcc/ChangeLog.rtems
 +	config/sparc/rtemself.h: Undef WCHAR_TYPE_SIZE, WCHAR_TYPE.
 +	(Resets WCHAR_TYPE's to defaults. Prevents broken GCC tm_files
 +	to interfere and cause wchar_t/wint_t incompatibilities).
-+		Ralf Corsépius <ralf.corsepius at rtems.org>
-+	* config/mips/elf.h: Remove NO_IMPLICIT_EXTERN_C.
 diff -Naur gcc-4.8.0.orig/gcc/config/h8300/h8300.h gcc-4.8.0/gcc/config/h8300/h8300.h
 --- gcc-4.8.0.orig/gcc/config/h8300/h8300.h	2013-01-10 21:38:27.000000000 +0100
 +++ gcc-4.8.0/gcc/config/h8300/h8300.h	2013-03-26 16:25:34.772043578 +0100
@@ -81,15 +76,6 @@ diff -Naur gcc-4.8.0.orig/gcc/config/m68k/rtemself.h gcc-4.8.0/gcc/config/m68k/r
 +#undef WCHAR_TYPE
 +#undef WCHAR_TYPE_SIZE
-diff -Naur gcc-4.8.0.orig/gcc/config/mips/elf.h gcc-4.8.0/gcc/config/mips/elf.h
---- gcc-4.8.0.orig/gcc/config/mips/elf.h	2013-01-10 21:38:27.000000000 +0100
-+++ gcc-4.8.0/gcc/config/mips/elf.h	2013-03-26 16:25:34.773043599 +0100
-@@ -46,5 +46,3 @@
- #undef  ENDFILE_SPEC
- #define ENDFILE_SPEC "crtend%O%s crtn%O%s"
--#define NO_IMPLICIT_EXTERN_C 1
 diff -Naur gcc-4.8.0.orig/gcc/config/rs6000/rtems.h gcc-4.8.0/gcc/config/rs6000/rtems.h
 --- gcc-4.8.0.orig/gcc/config/rs6000/rtems.h	2013-01-10 21:38:27.000000000 +0100
 +++ gcc-4.8.0/gcc/config/rs6000/rtems.h	2013-03-26 16:25:34.773043599 +0100
1.7.7
