[PATCH] LM3S3749 BSP - unified with LM3S6965
Eugeniy Meshcheryakov
eugen at debian.org
Thu Apr 25 22:33:12 UTC 2013
Hello,
Here is the second attempt on LM3S3749 support. This time unified with
'6965 support, including QEMU. Everything is now contained under
arm/lm3s69xx directory. The following BSPs are implemented:
lm3s6965 - bare lm3s6965 MCU, not tested on real hw, can be run
with unmodified qemu, memory map like in real MCU.
lm3s6965_qemu - lm3s6965 with a lot of memory, can be used only
with patched qemu (like old lm3s6965 BSP).
lm3s3749 - bare lm3s3749, tested on real hardware.
Regards,
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130426/3684e3a8/attachment.bin>
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130426/3684e3a8/attachment-0001.bin>
