[PATCH 8/8] libcsupport: Delete libc_wrapup()
Sebastian Huber
Thu Apr 25 09:20:01 UTC 2013
Add and use rtems_libio_exit_helper. Add rtems_libio_exit().
The fclose(stdin) etc. makes no sense during exit. This would use the
_REENT structure of the thread calling _exit().
cpukit/libcsupport/Makefile.am | 1 +
cpukit/libcsupport/include/rtems/libio.h | 4 +++
cpukit/libcsupport/src/libio_exit.c | 34 ++++++++++++++++++++++++++++++
cpukit/libcsupport/src/newlibc_exit.c | 27 +----------------------
cpukit/sapi/include/confdefs.h | 7 ++++++
5 files changed, 48 insertions(+), 25 deletions(-)
create mode 100644 cpukit/libcsupport/src/libio_exit.c
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index 42de63c..25e18c6 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -56,6 +56,7 @@ BASE_FS_C_FILES = src/base_fs.c src/mount.c src/unmount.c src/libio.c \
src/mount-mgr.c src/mount-mktgt.c src/libio_init.c \
src/privateenv.c \
src/libio_helper_null.c \
+ src/libio_exit.c \
src/open_dev_console.c src/__usrenv.c src/rtems_mkdir.c
TERMIOS_C_FILES = src/cfgetispeed.c src/cfgetospeed.c src/cfsetispeed.c \
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index ec2ced3..23853f9 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -1392,12 +1392,16 @@ extern const rtems_libio_helper rtems_libio_init_helper;
extern const rtems_libio_helper rtems_libio_post_driver_helper;
+extern const rtems_libio_helper rtems_libio_exit_helper;
extern const rtems_libio_helper rtems_fs_init_helper;
void rtems_libio_helper_null(void);
void rtems_libio_post_driver(void);
+void rtems_libio_exit(void);
* @brief Creates a directory and all its parent directories according to
* @a path.
diff --git a/cpukit/libcsupport/src/libio_exit.c b/cpukit/libcsupport/src/libio_exit.c
new file mode 100644
index 0000000..443e576
--- /dev/null
+++ b/cpukit/libcsupport/src/libio_exit.c
@@ -0,0 +1,34 @@
+ * @file
+ * @ingroup LibIO
+ * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <unistd.h>
+#include <rtems/libio.h>
+ (void)close(0);
+ (void)close(1);
+ (void)close(2);
diff --git a/cpukit/libcsupport/src/newlibc_exit.c b/cpukit/libcsupport/src/newlibc_exit.c
index 8dbbfce..f0c7b42 100644
--- a/cpukit/libcsupport/src/newlibc_exit.c
+++ b/cpukit/libcsupport/src/newlibc_exit.c
@@ -11,37 +11,14 @@
#include "config.h"
#endif
-#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
#if defined(RTEMS_NEWLIB)
-#include <rtems/libcsupport.h>
#include <unistd.h>
-static void libc_wrapup(void)
- * In case RTEMS is already down, don't do this. It could be
- * dangerous.
- if (!_System_state_Is_up(_System_state_Get()))
- return;
- * Try to drain output buffers.
- * Should this be changed to do *all* file streams?
- * _fwalk (_REENT, fclose);
- fclose (stdin);
- fclose (stdout);
- fclose (stderr);
/* FIXME: These defines are a blatant hack */
#if defined(__USE_INIT_FINI__)
@@ -66,7 +43,7 @@ void _exit(int status)
FINI_SYMBOL();
#endif
- libc_wrapup();
+ (*rtems_libio_exit_helper)();
rtems_shutdown_executive(status);
for (;;) ; /* to avoid warnings */
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 0d8c99b..c15c8a3 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -106,6 +106,13 @@ const rtems_libio_helper rtems_libio_post_driver_helper =
rtems_libio_post_driver;
#endif
+const rtems_libio_helper rtems_libio_exit_helper =
+ #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+ rtems_libio_helper_null;
+ #else
+ rtems_libio_exit;
+ #endif
const rtems_libio_helper rtems_fs_init_helper =
1.7.7
