[PATCH 2/2] Initial bsp for Tiny6410
Peng Fan
van.freenix at gmail.com
Wed Apr 17 08:58:57 UTC 2013
Hi Dhananjay,
2013/4/17 Dhananjay Balan <mb.dhananjay at gmail.com>
> Hi Peng,
> On 17 April 2013 11:35, Peng Fan <van.freenix at gmail.com> wrote:
>> If any questions, you may post on the mailing list not just me.
>> My Tiny6410 board is developed by Firendly ARM.
> What I have here is a Witech OK6410 [1] I see both hardware uses the same
> core modules, so Will it be possible for me to use this patch to run RTEMS
> over this SBC?
Yes, it is possible to run on your OK6410. I do not know the uboot
difference
between OK6410 and Tiny6410, so some paraments for configurating the timer
may be adjusted.
>> It's web is here: http://www.friendlyarm.net/products/tiny6410
>> The patch now is simple, only support timer and serial, with most of
>> the hardware configuration done in uboot.Now, I am also trying to
>> add nand support. It does run on my board. You may try.
> Can you document the steps to load the image into the board and also the
> u-boot tweaks you did somewhere in wiki?
I use the original uboot that released by Friendly ARM for this board and I
think you may not modify the uboot. Anyway I'll do some work to migrate the
hardware configuation from uboot to rtems. The patch that I have mailed u
include a README
file. It shows how to configure, download to board and run.
> Any problem, post it to the mailing list. Thanks.
>> Regards,
>> Peng.
>>> Hi,
>>> I have with me an Chineese ARM SBC built around Samsung 6410. It is
>>> manufactured by witech Inc. Does this mean I can run RTEMS on it?
>>> On Apr 17, 2013 11:01 AM, "Peng Fan" <van.freenix at gmail.com> wrote:
>>>> c/src/lib/libbsp/arm/Makefile.am | 1 +
>>>> c/src/lib/libbsp/arm/acinclude.m4 | 2 +
>>>> c/src/lib/libbsp/arm/preinstall.am | 4 +
>>>> c/src/lib/libbsp/arm/shared/startup/linkcmds.armv6 | 26 +++
>>>> c/src/lib/libbsp/arm/tiny6410/Makefile.am | 62 ++++++
>>>> c/src/lib/libbsp/arm/tiny6410/README | 23 ++
>>>> c/src/lib/libbsp/arm/tiny6410/bsp_specs | 13 ++
>>>> c/src/lib/libbsp/arm/tiny6410/configure.ac | 23 ++
>>>> c/src/lib/libbsp/arm/tiny6410/console/uart.c | 229
>>>> c/src/lib/libbsp/arm/tiny6410/debug/debug.c | 60 +++++
>>>> c/src/lib/libbsp/arm/tiny6410/include/bsp.h | 60 +++++
>>>> .../libbsp/arm/tiny6410/make/custom/tiny6410.cfg | 21 ++
>>>> c/src/lib/libbsp/arm/tiny6410/preinstall.am | 83 +++++++
>>>> c/src/lib/libbsp/arm/tiny6410/sh-hello | 13 ++
>>>> c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c | 25 +++
>>>> c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c | 37 ++++
>>>> c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c | 83 +++++++
>>>> .../libbsp/arm/tiny6410/startup/bspstarthooks.c | 146 +++++++++++++
>>>> c/src/lib/libbsp/arm/tiny6410/startup/linkcmds | 25 +++
>>>> c/src/lib/libbsp/arm/tiny6410/startup/memmap.c | 29 +++
>>>> c/src/lib/libcpu/arm/Makefile.am | 25 +++
>>>> c/src/lib/libcpu/arm/configure.ac | 2 +
>>>> c/src/lib/libcpu/arm/preinstall.am | 13 ++
>>>> c/src/lib/libcpu/arm/s3c64xx/clock/clockdrv.c | 141 ++++++++++++
>>>> c/src/lib/libcpu/arm/s3c64xx/clock/support.c | 51 +++++
>>>> c/src/lib/libcpu/arm/s3c64xx/include/s3c6410.h | 211
>>>> c/src/lib/libcpu/arm/s3c64xx/include/s3c64xx.h | 15 ++
>>>> c/src/lib/libcpu/arm/s3c64xx/irq/irq.c | 79 +++++++
>>>> c/src/lib/libcpu/arm/s3c64xx/irq/irq.h | 100 +++++++++
>>>> c/src/lib/libcpu/arm/shared/include/arm-cp15.h | 17 ++
>>>> 30 files changed, 1619 insertions(+)
>>>> create mode 100644 c/src/lib/libbsp/arm/shared/startup/linkcmds.armv6
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/Makefile.am
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/README
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/bsp_specs
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/configure.ac
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/console/uart.c
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/debug/debug.c
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/include/bsp.h
>>>> create mode 100644
>>>> c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/preinstall.am
>>>> create mode 100755 c/src/lib/libbsp/arm/tiny6410/sh-hello
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c
>>>> create mode 100644
>>>> c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/linkcmds
>>>> create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/memmap.c
>>>> create mode 100644 c/src/lib/libcpu/arm/s3c64xx/clock/clockdrv.c
>>>> create mode 100644 c/src/lib/libcpu/arm/s3c64xx/clock/support.c
>>>> create mode 100644 c/src/lib/libcpu/arm/s3c64xx/include/s3c6410.h
>>>> create mode 100644 c/src/lib/libcpu/arm/s3c64xx/include/s3c64xx.h
>>>> create mode 100644 c/src/lib/libcpu/arm/s3c64xx/irq/irq.c
>>>> create mode 100644 c/src/lib/libcpu/arm/s3c64xx/irq/irq.h
>>>> diff --git a/c/src/lib/libbsp/arm/Makefile.am
>>>> b/c/src/lib/libbsp/arm/Makefile.am
>>>> index 9783354..bd2ee0c 100644
>>>> --- a/c/src/lib/libbsp/arm/Makefile.am
>>>> +++ b/c/src/lib/libbsp/arm/Makefile.am
>>>> @@ -10,6 +10,7 @@ include_bsp_HEADERS = shared/include/linker-symbols.h
>>>> dist_project_lib_DATA = shared/startup/linkcmds.base
>>>> dist_project_lib_DATA += shared/startup/linkcmds.armv4
>>>> +dist_project_lib_DATA += shared/startup/linkcmds.armv6
>>>> dist_project_lib_DATA += shared/startup/linkcmds.armv7m
>>>> EXTRA_DIST =
>>>> diff --git a/c/src/lib/libbsp/arm/acinclude.m4
>>>> b/c/src/lib/libbsp/arm/acinclude.m4
>>>> index 9512b26..277c144 100644
>>>> --- a/c/src/lib/libbsp/arm/acinclude.m4
>>>> +++ b/c/src/lib/libbsp/arm/acinclude.m4
>>>> @@ -30,6 +30,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>> AC_CONFIG_SUBDIRS([smdk2410]);;
>>>> stm32f4 )
>>>> AC_CONFIG_SUBDIRS([stm32f4]);;
>>>> + tiny6410 )
>>>> + AC_CONFIG_SUBDIRS([tiny6410]);;
>>>> AC_MSG_ERROR([Invalid BSP]);;
>>>> esac
>>>> diff --git a/c/src/lib/libbsp/arm/preinstall.am b/c/src/lib/libbsp/arm/
>>>> preinstall.am
>>>> index 3e66ebe..75e8dfa 100644
>>>> --- a/c/src/lib/libbsp/arm/preinstall.am
>>>> +++ b/c/src/lib/libbsp/arm/preinstall.am
>>>> @@ -35,6 +35,10 @@ $(PROJECT_LIB)/linkcmds.armv4:
>>>> shared/startup/linkcmds.armv4 $(PROJECT_LIB)/$(di
>>>> $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.armv4
>>>> PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.armv4
>>>> +$(PROJECT_LIB)/linkcmds.armv6: shared/startup/linkcmds.armv6
>>>> $(PROJECT_LIB)/$(dirstamp)
>>>> + $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.armv6
>>>> +PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.armv6
>>>> $(PROJECT_LIB)/linkcmds.armv7m: shared/startup/linkcmds.armv7m
>>>> $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.armv7m
>>>> PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.armv7m
>>>> diff --git a/c/src/lib/libbsp/arm/shared/startup/linkcmds.armv6
>>>> b/c/src/lib/libbsp/arm/shared/startup/linkcmds.armv6
>>>> new file mode 100644
>>>> index 0000000..16fa3ef
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/shared/startup/linkcmds.armv6
>>>> @@ -0,0 +1,26 @@
>>>> + * @file
>>>> + * @ingroup bsp_linker
>>>> + * @brief Linker command file for ARMv6 architecture.
>>>> + * Copyright (c) 2010 embedded brains GmbH. All rights reserved.
>>>> + * embedded brains GmbH
>>>> + * Obere Lagerstr. 30
>>>> + * 82178 Puchheim
>>>> + * Germany
>>>> + * <rtems at embedded-brains.de>
>>>> + * The license and distribution terms for this file may be
>>>> + * found in the file LICENSE in this distribution or at
>>>> + * http://www.rtems.com/license/LICENSE.
>>>> +bsp_stack_svc_size = DEFINED (bsp_stack_svc_size) ? bsp_stack_svc_size
>>>> : 4096;
>>>> +bsp_stack_svc_size = ALIGN (bsp_stack_svc_size, bsp_stack_align);
>>>> +INCLUDE linkcmds.base
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/Makefile.am
>>>> b/c/src/lib/libbsp/arm/tiny6410/Makefile.am
>>>> index 0000000..e49dc3a
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/Makefile.am
>>>> @@ -0,0 +1,62 @@
>>>> +ACLOCAL_AMFLAGS = -I ../../../../aclocal
>>>> +include $(top_srcdir)/../../../../automake/compile.am
>>>> +include_bspdir = $(includedir)/bsp
>>>> +dist_project_lib_DATA = bsp_specs
>>>> +include_HEADERS = include/bsp.h
>>>> +include_HEADERS += ../../shared/include/tm27.h
>>>> +include_bsp_HEADERS = ../shared/include/start.h
>>>> +include_bsp_HEADERS += ../shared/include/linker-symbols.h
>>>> +nodist_include_HEADERS = include/bspopts.h
>>>> +nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>>>> +DISTCLEANFILES = include/bspopts.h
>>>> +nodist_include_HEADERS += ../../shared/include/coverhd.h
>>>> +noinst_LIBRARIES = libbspstart.a
>>>> +libbspstart_a_SOURCES = ../shared/start/start.S
>>>> +#libbspstart_a_SOURCES = start/start.S
>>>> +project_lib_DATA = start.$(OBJEXT)
>>>> +dist_project_lib_DATA += startup/linkcmds
>>>> +noinst_LIBRARIES += libbsp.a
>>>> +libbsp_a_SOURCES =
>>>> +# startup
>>>> +libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
>>>> +libbsp_a_SOURCES += ../../shared/bsplibc.c ../../shared/bsppost.c \
>>>> + ../../shared/bsppredriverhook.c ../../shared/bspgetworkarea.c \
>>>> + ../../shared/bsppretaskinghook.c startup/bspstart.c
>>>> startup/bspidle.c \
>>>> + ../../shared/bspclean.c startup/bspreset.c \
>>>> + startup/memmap.c ../../shared/bootcard.c ../../shared/sbrk.c \
>>>> + ../../shared/gnatinstallhandler.c startup/bspstarthooks.c
>>>> +# low-level debug
>>>> +libbsp_a_SOURCES += debug/debug.c
>>>> +# console
>>>> +libbsp_a_SOURCES += console/uart.c ../../shared/console.c \
>>>> + ../../shared/console_select.c ../../shared/console_control.c \
>>>> + ../../shared/console_read.c ../../shared/console_write.c
>>>> +# IRQ
>>>> +include_bsp_HEADERS += ../../shared/include/irq-generic.h \
>>>> + ../../shared/include/irq-info.h
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-server.c
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-shell.c
>>>> +# abort
>>>> +libbsp_a_SOURCES += ../shared/abort/abort.c
>>>> +libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel \
>>>> + ../../../libcpu/@RTEMS_CPU@/s3c64xx/clock.rel \
>>>> + ../../../libcpu/@RTEMS_CPU@/s3c64xx/irq.rel
>>>> +include $(srcdir)/preinstall.am
>>>> +include $(top_srcdir)/../../../../automake/local.am
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/README
>>>> b/c/src/lib/libbsp/arm/tiny6410/README
>>>> index 0000000..ae936e5
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/README
>>>> @@ -0,0 +1,23 @@
>>>> +This is the BSP for FriendlyARM tiny6410 board, a single board
>>>> +computer using the Samsung S3C6410 SoC CPU.
>>>> +S3C6410 is an arm1176jzf-s processor. About the mmu related,
>>>> +still use the arm920 mmu management.This may be seperated,
>>>> +for there may some difference between 920 and 1176jzf-s.
>>>> +Most of the hardware configuration is done in uboot.This maybe
>>>> +migrated to rtems from uboot in future.
>>>> +Now only serial and timer is supported, other IP modules' driver
>>>> +will be added in future.
>>>> +hello.exe ticker.exe nsecs.exe runs. Others have not been tested.
>>>> +How to use this bsp
>>>> +1. When downloaded the source, first "bootstrap -c; bootstrap -p;
>>>> +bootstrap"
>>>> +2. Look at the sh-hello script to know how to configure for this bsp
>>>> +4. use dnw to download the bin file to 0xC0104000
>>>> + MINI6410 # dnw 0xc0104000
>>>> + When finished download, use go command to run the bin file
>>>> + MINI6410 # go 0xc0104000
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/bsp_specs
>>>> b/c/src/lib/libbsp/arm/tiny6410/bsp_specs
>>>> index 0000000..082653a
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/bsp_specs
>>>> @@ -0,0 +1,13 @@
>>>> +%rename endfile old_endfile
>>>> +%rename startfile old_startfile
>>>> +%rename link old_link
>>>> +*startfile:
>>>> +%{!qrtems: %(old_startfile)} \
>>>> +%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
>>>> +*link:
>>>> +%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
>>>> +*endfile:
>>>> +%{!qrtems: *(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/configure.acb/c/src/lib/libbsp/arm/tiny6410/
>>>> configure.ac
>>>> index 0000000..11966e0
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/configure.ac
>>>> @@ -0,0 +1,23 @@
>>>> +## Process this file with autoconf to produce a configure script.
>>>> +AC_PREREQ([2.69])
>>>> +AC_INIT([rtems-c-src-lib-libbsp-arm-tiny6410],[_RTEMS_VERSION],[
>>>> http://www.rtems.org/bugzilla])
>>>> +AC_CONFIG_SRCDIR([bsp_specs])
>>>> +RTEMS_TOP(../../../../../..)
>>>> +RTEMS_CANONICAL_TARGET_CPU
>>>> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
>>>> +RTEMS_BSP_CONFIGURE
>>>> +RTEMS_PROG_CC_FOR_TARGET
>>>> +RTEMS_CANONICALIZE_TOOLS
>>>> +RTEMS_PROG_CCAS
>>>> +RTEMS_CHECK_NETWORKING
>>>> +AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
>>>> +RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
>>>> +# Explicitly list all Makefiles here
>>>> +AC_CONFIG_FILES([Makefile])
>>>> +AC_OUTPUT
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/console/uart.c
>>>> b/c/src/lib/libbsp/arm/tiny6410/console/uart.c
>>>> index 0000000..46b5edb
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/console/uart.c
>>>> @@ -0,0 +1,229 @@
>>>> + * console driver for S3C2400 UARTs
>>>> + * This driver uses the shared console driver in
>>>> + * ...../libbsp/shared/console.c
>>>> + * If you want the driver to be interrupt driven, you
>>>> + * need to write the ISR, and in the ISR insert the
>>>> + * chars into termios's queue.
>>>> + * Copyright (c) 2004 Cogent Computer Systems
>>>> + * Written by Jay Monkman <jtm at lopingdog.com>
>>>> + * 1. Modified from S3C2400 Peng Fan van.freenix at gmail.com
>>>> +#include <bsp.h> /* Must be before libio.h */
>>>> +#include <rtems/libio.h>
>>>> +#include <termios.h>
>>>> +#include <rtems/bspIo.h>
>>>> +/* Put the CPU (or UART) specific header file #include here */
>>>> +#include <s3c64xx.h>
>>>> +#include <libchip/serial.h>
>>>> +#include <libchip/sersupp.h>
>>>> +/* How many serial ports? */
>>>> +#define NUM_DEVS 1
>>>> +int uart_poll_read(int minor);
>>>> +int dbg_dly;
>>>> +/* static function prototypes */
>>>> +static int uart_first_open(int major, int minor, void *arg);
>>>> +static int uart_last_close(int major, int minor, void *arg);
>>>> +static int uart_read(int minor);
>>>> +static ssize_t uart_write(int minor, const char *buf, size_t len);
>>>> +static void uart_init(int minor);
>>>> +static void uart_write_polled(int minor, char c);
>>>> +static int uart_set_attributes(int minor, const struct termios *t);
>>>> +/* These are used by code in console.c */
>>>> +unsigned long Console_Configuration_Count = NUM_DEVS;
>>>> +/* Pointers to functions for handling the UART. */
>>>> +const console_fns uart_fns =
>>>> + libchip_serial_default_probe,
>>>> + uart_first_open,
>>>> + uart_last_close,
>>>> + uart_read,
>>>> + uart_write,
>>>> + uart_init,
>>>> + uart_write_polled, /* not used in this driver */
>>>> + uart_set_attributes,
>>>> + FALSE /* TRUE if interrupt driven, FALSE if not. */
>>>> + * There's one item in array for each UART.
>>>> + * Some of these fields are marked "NOT USED". They are not used
>>>> + * by console.c, but may be used by drivers in libchip
>>>> +console_tbl Console_Configuration_Ports[] = {
>>>> + "/dev/com0", /* sDeviceName */
>>>> + SERIAL_CUSTOM, /* deviceType */
>>>> + &uart_fns, /* pDeviceFns */
>>>> + NULL, /* deviceProbe */
>>>> + NULL, /* pDeviceFlow */
>>>> + 0, /* ulMargin - NOT USED */
>>>> + 0, /* ulHysteresis - NOT USED */
>>>> + NULL, /* pDeviceParams */
>>>> + 0, /* ulCtrlPort1 - NOT USED */
>>>> + 0, /* ulCtrlPort2 - NOT USED */
>>>> + 0, /* ulDataPort - NOT USED */
>>>> + NULL, /* getRegister - NOT USED */
>>>> + NULL, /* setRegister - NOT USED */
>>>> + NULL, /* getData - NOT USED */
>>>> + NULL, /* setData - NOT USED */
>>>> + 0, /* ulClock - NOT USED */
>>>> + 0 /* ulIntVector - NOT USED */
>>>> +/* Functions called via termios callbacks (i.e. the ones in uart_fns */
>>>> + * This is called the first time each device is opened. If the driver
>>>> + * is interrupt driven, you should enable interrupts here. Otherwise,
>>>> + * it's probably safe to do nothing.
>>>> + * Since micromonitor already set up the UART, we do nothing.
>>>> + return 0;
>>>> + * This is called the last time each device is closed. If the driver
>>>> + * is interrupt driven, you should disable interrupts here. Otherwise,
>>>> + return 0;
>>>> + * Read one character from UART.
>>>> + * Return -1 if there's no data, otherwise return
>>>> + * the character in lowest 8 bits of returned int.
>>>> + char c;
>>>> + if (minor == 0) {
>>>> + if (rUTRSTAT0 & 0x1) {
>>>> + c = rURXH0 & 0xff;
>>>> + return c;
>>>> + } else {
>>>> + return -1;
>>>> + } else {
>>>> + printk("Unknown console minor number: %d\n", minor);
>>>> + return -1;
>>>> + * Write buffer to UART
>>>> + * return 1 on success, -1 on error
>>>> + int i;
>>>> + if (minor == 0) {
>>>> + for (i = 0; i < len; i++) {
>>>> + /* Wait for fifo to have room */
>>>> + while(!(rUTRSTAT0 & 0x2)) {
>>>> + continue;
>>>> + rUTXH0 = (char) buf[i];
>>>> + } else {
>>>> + return -1;
>>>> + return 1;
>>>> +/* Set up the UART. */
>>>> + int i;
>>>> + unsigned int reg = 0;
>>>> + /* Migrate the configuration from uboot in future */
>>>> + Uart_SendString(__func__);
>>>> +/* I'm not sure this is needed for the shared console driver. */
>>>> + uart_write(minor, &c, 1);
>>>> +/* This is for setting baud rate, bits, etc. */
>>>> + return 0;
>>>> + * The following functions are not used by TERMIOS, but other RTEMS
>>>> + * functions use them instead.
>>>> + * Read from UART. This is used in the exit code, and can't
>>>> + * rely on interrupts.
>>>> + return uart_read(minor);
>>>> + * Write a character to the console. This is used by printk() and
>>>> + * maybe other low level functions. It should not use interrupts or any
>>>> + * RTEMS system calls. It needs to be very simple
>>>> +static void _BSP_put_char( char c ) {
>>>> + uart_write_polled(0, c);
>>>> + if (c == '\n') {
>>>> + uart_write_polled(0, '\r');
>>>> +BSP_output_char_function_type BSP_output_char = _BSP_put_char;
>>>> +static int _BSP_get_char(void)
>>>> + return uart_poll_read(0);
>>>> +BSP_polling_getchar_function_type BSP_poll_char = _BSP_get_char;
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/debug/debug.c
>>>> b/c/src/lib/libbsp/arm/tiny6410/debug/debug.c
>>>> index 0000000..139b21e
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/debug/debug.c
>>>> @@ -0,0 +1,60 @@
>>>> + * @file
>>>> + * @ingroup s3c64xx
>>>> + * @brief Low level Debug code.
>>>> +#include <bsp.h>
>>>> +void debug_led(uint32_t val)
>>>> + uint32_t *addr = (uint32_t *)0x7f008800;
>>>> + *addr = val;
>>>> +static void Delay(void)
>>>> + volatile int i;
>>>> + for(i=0 ; i < 1000 ; i++)
>>>> +void Uart_SendByte(int data)
>>>> + while(!(rUTRSTAT0 & 0x2)); //Wait until THR is empty.
>>>> + Delay();
>>>> + rUTXH0 = (unsigned char)data;
>>>> +void Uart_SendString(char *pt)
>>>> + while(*pt)
>>>> + Uart_SendByte(*pt++);
>>>> + Uart_SendByte('\r');
>>>> + Uart_SendByte('\n');
>>>> +void printhex(unsigned int data)
>>>> + int i = 0,a = 0;
>>>> + for (i = 0; i < 8; i++) {
>>>> + a = (data>>(32-(i+1)*4))&0xf;
>>>> + if (((a<=9)&&(a>=0)))
>>>> + Uart_SendByte(a + 0x30);
>>>> + else if ((a <= 0xf) && (a >= 0xa))
>>>> + Uart_SendByte(a-0xa+0x61);
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/include/bsp.h
>>>> b/c/src/lib/libbsp/arm/tiny6410/include/bsp.h
>>>> index 0000000..699fdab
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/include/bsp.h
>>>> @@ -0,0 +1,60 @@
>>>> + * @file
>>>> + * This include file contains definitions related to the GP32 BSP.
>>>> + * Copyright (c) 2013
>>>> + * ASIC Engineering Center
>>>> + * Nanjing, China
>>>> + * <van.freenix at gmail.com>
>>>> +#ifndef _BSP_H
>>>> +#define _BSP_H
>>>> +#ifdef __cplusplus
>>>> +extern "C" {
>>>> +#endif
>>>> +#include <bspopts.h>
>>>> +#include <bsp/default-initial-extension.h>
>>>> +#include <rtems.h>
>>>> +#include <rtems/iosupp.h>
>>>> +#include <rtems/console.h>
>>>> +#include <rtems/clockdrv.h>
>>>> +#define BSP_FEATURE_IRQ_EXTENSION
>>>> +/*functions to get the differents s3c2400 clks*/
>>>> +uint32_t get_FCLK(void);
>>>> +uint32_t get_HCLK(void);
>>>> +uint32_t get_PCLK(void);
>>>> +uint32_t get_UCLK(void);
>>>> + * This BSP provides its own IDLE thread to override the RTEMS one.
>>>> + * So we prototype it and define the constant confdefs.h expects
>>>> + * to configure a BSP specific one.
>>>> +void *bsp_idle_thread(uintptr_t ignored);
>>>> +#define BSP_IDLE_TASK_BODY bsp_idle_thread
>>>> +#ifdef __cplusplus
>>>> +#endif
>>>> +#endif /* _BSP_H */
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg
>>>> b/c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg
>>>> index 0000000..44b0ca6
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg
>>>> @@ -0,0 +1,21 @@
>>>> +# Config file for ARM S3C6410
>>>> +include $(RTEMS_ROOT)/make/custom/default.cfg
>>>> +RTEMS_CPU=arm
>>>> +RTEMS_CPU_MODEL=s3c6410
>>>> +# This contains the compiler options necessary to select the CPU model
>>>> +# and (hopefully) optimize for it.
>>>> +CPU_CFLAGS = -mstructure-size-boundary=32 -mcpu=arm1176jzf-s -mfpu=vfp
>>>> -mfloat-abi=soft -DCPU_S3C6410
>>>> +# optimize flag: typically -O2
>>>> +CFLAGS_OPTIMIZE_V = -O2 -g
>>>> +define bsp-post-link
>>>> + $(OBJCOPY) -O binary $(basename $@).exe $(basename $@)$(DOWNEXT)
>>>> + $(default-bsp-post-link)
>>>> +endef
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/preinstall.amb/c/src/lib/libbsp/arm/tiny6410/
>>>> preinstall.am
>>>> index 0000000..ca20008
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/preinstall.am
>>>> @@ -0,0 +1,83 @@
>>>> +## Automatically generated by ampolish3 - Do not edit
>>>> +if AMPOLISH3
>>>> +$(srcdir)/preinstall.am: Makefile.am
>>>> + $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>>>> +endif
>>>> +PREINSTALL_DIRS =
>>>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>> +all-local: $(TMPINSTALL_FILES)
>>>> +TMPINSTALL_FILES =
>>>> +CLEANFILES = $(TMPINSTALL_FILES)
>>>> +all-am: $(PREINSTALL_FILES)
>>>> +PREINSTALL_FILES =
>>>> +CLEANFILES += $(PREINSTALL_FILES)
>>>> +$(PROJECT_LIB)/$(dirstamp):
>>>> + @$(MKDIR_P) $(PROJECT_LIB)
>>>> + @: > $(PROJECT_LIB)/$(dirstamp)
>>>> +PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
>>>> +$(PROJECT_INCLUDE)/$(dirstamp):
>>>> + @$(MKDIR_P) $(PROJECT_INCLUDE)
>>>> + @: > $(PROJECT_INCLUDE)/$(dirstamp)
>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
>>>> +$(PROJECT_INCLUDE)/bsp/$(dirstamp):
>>>> + @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
>>>> + @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
>>>> + $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
>>>> +PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
>>>> +$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
>>>> +$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
>>>> +$(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
>>>> +$(PROJECT_INCLUDE)/bsp/linker-symbols.h:
>>>> ../shared/include/linker-symbols.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>>>> +$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
>>>> +$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>> +$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
>>>> +$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT)
>>>> + $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
>>>> +TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
>>>> +$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
>>>> +$(PROJECT_INCLUDE)/bsp/irq-generic.h:
>>>> ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>> +$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/sh-hello
>>>> b/c/src/lib/libbsp/arm/tiny6410/sh-hello
>>>> new file mode 100755
>>>> index 0000000..2ca81d6
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/sh-hello
>>>> @@ -0,0 +1,13 @@
>>>> +#!/bin/sh
>>>> +mkdir build
>>>> +cd build
>>>> +../rtems/configure --target=arm-rtemseabi4.11
>>>> --enable-rtemsbsp="tiny6410" --enable-test=samples --disable-posix
>>>> +rm `find . -name hello.exe`
>>>> +gmake all
>>>> +rm hello.*
>>>> +rm init.*
>>>> +cp -f `find . -name hello.exe` .
>>>> +cp arm-rtemseabi4.11/c/tiny6410/testsuites/samples/hello/init.o .
>>>> +arm-rtemseabi4.11-objcopy -O binary -S hello.exe hello.bin
>>>> +arm-rtemseabi4.11-objdump -D hello.exe > hello.s
>>>> +arm-rtemseabi4.11-objdump -D init.o > init.s
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c
>>>> b/c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c
>>>> index 0000000..6bc8088
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c
>>>> @@ -0,0 +1,25 @@
>>>> + * BSP specific Idle thread
>>>> + * Copyright (c) 2000 Canon Research Centre France SA.
>>>> + * Emmanuel Raguet, mailto:raguet at crf.canon.fr
>>>> + * 1.Copied from gp32
>>>> +#include <bsp.h>
>>>> + while(1) {
>>>> + __asm__ volatile ("MCR p15,0,r0,c7,c0,4 \n");
>>>> + return NULL;
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c
>>>> b/c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c
>>>> index 0000000..0d52df7
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c
>>>> @@ -0,0 +1,37 @@
>>>> + * 1. Copied from gp32
>>>> +#include <bsp.h>
>>>> +void bsp_reset(void)
>>>> + rtems_interrupt_level level;
>>>> + rtems_interrupt_disable(level);
>>>> + /* disable mmu, invalide i-cache and call swi #4 */
>>>> + __asm__ volatile(""
>>>> + "mrc p15,0,r0,c1,c0,0 \n"
>>>> + "bic r0,r0,#1 \n"
>>>> + "mcr p15,0,r0,c1,c0,0 \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "mov r0,#0 \n"
>>>> + "MCR p15,0,r0,c7,c5,0 \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "nop \n"
>>>> + "swi #4 "
>>>> + : "r0"
>>>> + /* we should be back in bios now */
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c
>>>> b/c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c
>>>> index 0000000..09eded1
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c
>>>> @@ -0,0 +1,83 @@
>>>> + * This file contains the ARM BSP startup package. It includes
>>>> application,
>>>> + * board, and monitor specific initialization and configuration. The
>>>> generic CPU
>>>> + * dependent initialization has been performed before this routine is
>>>> invoked.
>>>> + * 1. Modified from gp32 Peng Fan van.freenix at gmail.com
>>>> +#include <bsp.h>
>>>> +#include <bsp/irq-generic.h>
>>>> + * External Prototypes
>>>> +extern void rtems_exception_init_mngt(void);
>>>> + * BSP Specific Initialization in C
>>>> +void bsp_start_default( void )
>>>> + uint32_t cr;
>>>> + uint32_t pend,last;
>>>> + uint32_t REFCNT;
>>>> + uint32_t i;
>>>> + /* stop RTC */
>>>> + rTICCNT = 0x0;
>>>> + /* stop watchdog,ADC and timers */
>>>> + rWTCON = 0x0;
>>>> + rTCON = 0x0;
>>>> + rADCCON = 0x0;
>>>> + /* disable interrupts */
>>>> + rVIC0_INTENCLEAR = 0x0;
>>>> + rVIC1_INTENCLEAR = 0x0;
>>>> + /* interrupt select, irq or fiq?*/
>>>> + rVIC0_INTSELECT = 0x0;
>>>> + rVIC1_INTSELECT = 0x0;
>>>> + /* clear external interrupt pending*/
>>>> + rEINT0PEND = ~0x0; /* write 1 to clear */
>>>> + /* clear pending interrupt */
>>>> + rVIC0_ADDRESS = 0x0;
>>>> + rVIC1_ADDRESS = 0x0;
>>>> +#if 0
>>>> + /* system clock may be migrated to here from uboot */
>>>> + /* setup clocks */
>>>> +#endif
>>>> + * Init rtems exceptions management
>>>> + rtems_exception_init_mngt();
>>>> + * Init rtems interrupt management
>>>> + bsp_interrupt_initialize();
>>>> + * By making this a weak alias for bsp_start_default, a brave soul
>>>> + * can override the actual bsp_start routine used.
>>>> +void bsp_start (void) __attribute__ ((weak,
>>>> alias("bsp_start_default")));
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c
>>>> b/c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c
>>>> index 0000000..31e359c
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c
>>>> @@ -0,0 +1,146 @@
>>>> + * @file
>>>> + * @brief Startup code.
>>>> + * Copyright (c) 2009-2011 embedded brains GmbH. All rights reserved.
>>>> + * 82178 Puchheim
>>>> + * Germany
>>>> + * 1. Modified from lpc32xx Peng Fan van.freenix at gmail.com
>>>> +#include <bsp.h>
>>>> +#include <bsp/start.h>
>>>> +#include <bsp/irq.h>
>>>> +#include <bsp/linker-symbols.h>
>>>> +#include <libcpu/arm-cp15.h>
>>>> +#include <libcpu/mmu.h>
>>>> +//#include <bsp/uart-output-char.h> //fanpeng
>>>> +extern void bsp_reset(void);
>>>> +void SWI_Handler(void)
>>>> + Uart_SendString("swi handler");
>>>> + while(1);
>>>> +static BSP_START_TEXT_SECTION void clear_bss(void)
>>>> + const int *end = (const int *) bsp_section_bss_end;
>>>> + int *out = (int *) bsp_section_bss_begin;
>>>> + /* Clear BSS */
>>>> + while (out != end) {
>>>> + *out = 0;
>>>> + ++out;
>>>> +extern mmu_sect_map_t mem_map[];
>>>> +static BSP_START_TEXT_SECTION void setup_mmu_and_cache(void)
>>>> + uint32_t ctrl = 0;
>>>> + /* Disable MMU and cache, basic settings */
>>>> + ctrl = arm_cp15_get_control();
>>>> + ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
>>>> + | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
>>>> + ctrl |= ARM_CP15_CTRL_A;
>>>> + arm_cp15_set_control(ctrl);
>>>> + arm_cp15_data_cache_clean_and_invalidate();
>>>> + arm_cp15_cache_invalidate(); //cache clean and invalidate ??
>>>> + arm_cp15_tlb_invalidate();
>>>> + #ifndef S3C64XX_DISABLE_MMU
>>>> + mmu_init(mem_map);
>>>> + #endif
>>>> +static BSP_START_TEXT_SECTION void setup_pll(void)
>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
>>>> + setup_pll();
>>>> + setup_mmu_and_cache();
>>>> +static BSP_START_TEXT_SECTION void stop_dma_activities(void)
>>>> +static BSP_START_TEXT_SECTION void setup_uarts(void)
>>>> +static BSP_START_TEXT_SECTION void setup_timer(void)
>>>> + /* May be removed */
>>>> +/* vector_begin will be copied to address 0 */
>>>> +uint32_t vector_begin[] = {
>>>> + 0xe59ff018, //ldr pc, [pc, #24]
>>>> + 0xe59ff018,
>>>> + 0xe59ff018,
>>>> + 0xe59ff018,
>>>> + 0xe59ff018,
>>>> + 0xe320f000, //nop
>>>> + 0xe59ff018,
>>>> + 0xe59ff018,
>>>> + bsp_reset,
>>>> + 0xe320f000, //nop
>>>> + 0xe320f000, //nop
>>>> + 0xe320f000, //nop
>>>> + 0xe320f000, //nop
>>>> + 0xe320f000, //nop
>>>> + 0xe320f000, //nop
>>>> + 0xe320f000, //nop
>>>> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>>>> + int i = 0;
>>>> + stop_dma_activities();
>>>> + setup_uarts();
>>>> + setup_timer();
>>>> + arm_cp15_cache_invalidate(); //??
>>>> + /* Copy vector table to address 0*/
>>>> + bsp_start_memcpy(
>>>> + (int *)0,
>>>> + (const int*)vector_begin,
>>>> + (size_t)64
>>>> + /* VIC is not enabled for this vector interrupt processor,
>>>> + * This may be done in the future to use vector interrupt.
>>>> + /* Clear .bss section */
>>>> + clear_bss();
>>>> + /* At this point we can use objects outside the .start section */
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/linkcmds
>>>> b/c/src/lib/libbsp/arm/tiny6410/startup/linkcmds
>>>> index 0000000..dc48a57
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/linkcmds
>>>> @@ -0,0 +1,25 @@
>>>> +MEMORY {
>>>> + SDRAM_INTERRUPT : ORIGIN = 0x50000000, LENGTH = 4k
>>>> + SDRAM_MMU : ORIGIN = 0x50100000, LENGTH = 16k
>>>> + SDRAM : ORIGIN = 0x50104000, LENGTH = 128M - 1M - 16k
>>>> +REGION_ALIAS ("REGION_START", SDRAM);
>>>> +REGION_ALIAS ("REGION_VECTOR", SDRAM);
>>>> +REGION_ALIAS ("REGION_TEXT", SDRAM);
>>>> +REGION_ALIAS ("REGION_TEXT_LOAD", SDRAM);
>>>> +REGION_ALIAS ("REGION_RODATA", SDRAM);
>>>> +REGION_ALIAS ("REGION_RODATA_LOAD", SDRAM);
>>>> +REGION_ALIAS ("REGION_DATA", SDRAM);
>>>> +REGION_ALIAS ("REGION_DATA_LOAD", SDRAM);
>>>> +REGION_ALIAS ("REGION_FAST_TEXT", SDRAM);
>>>> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", SDRAM);
>>>> +REGION_ALIAS ("REGION_FAST_DATA", SDRAM);
>>>> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", SDRAM);
>>>> +REGION_ALIAS ("REGION_BSS", SDRAM);
>>>> +REGION_ALIAS ("REGION_WORK", SDRAM);
>>>> +REGION_ALIAS ("REGION_STACK", SDRAM);
>>>> +_ttbl_base = ORIGIN (SDRAM_MMU);
>>>> +INCLUDE linkcmds.armv6
>>>> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/memmap.c
>>>> b/c/src/lib/libbsp/arm/tiny6410/startup/memmap.c
>>>> index 0000000..aa0b7f9
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/memmap.c
>>>> @@ -0,0 +1,29 @@
>>>> + * s3c6410 Memory Map
>>>> + * Copyright (c) 2004 by Cogent Computer Systems
>>>> +#include <rtems.h>
>>>> +/*ARM1176jzf-s consider TLB related*/
>>>> +/*Here not implement 2-level page table considering tlb miss
>>>> + Maybe a tlb management structure should be implemented.
>>>> + To real time task, TLB entry is locked and should not incur
>>>> + TLB miss. But to non real time task, TLB miss is not cared
>>>> + Not sure about this. May have a try to do this in future
>>>> +mmu_sect_map_t mem_map[] = {
>>>> +/* <phys addr> <virt addr> <size> <flags> */
>>>> + {0x00000000, 0x00000000, 4096, MMU_CACHE_NONE},
>>>> + {0x50000000, 0x00000000, 1, MMU_CACHE_NONE},
>>>> + {0x50000000, 0x50000000, 128, MMU_CACHE_NONE},
>>>> + {0x00000000, 0x00000000, 0, 0} /* The end */
>>>> diff --git a/c/src/lib/libcpu/arm/Makefile.am
>>>> b/c/src/lib/libcpu/arm/Makefile.am
>>>> index e488c45..e978910 100644
>>>> --- a/c/src/lib/libcpu/arm/Makefile.am
>>>> +++ b/c/src/lib/libcpu/arm/Makefile.am
>>>> @@ -157,6 +157,31 @@ s3c24xx_irq_rel_CPPFLAGS = $(AM_CPPFLAGS)
>>>> s3c24xx_irq_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>> endif
>>>> +if s3c64xx
>>>> +include_HEADERS = s3c64xx/include/s3c64xx.h s3c64xx/include/s3c6410.h
>>>> +## s3c64xx/clock
>>>> +noinst_PROGRAMS += s3c64xx/clock.rel
>>>> +s3c64xx_clock_rel_SOURCES = s3c64xx/clock/clockdrv.c
>>>> +s3c64xx_clock_rel_CPPFLAGS = $(AM_CPPFLAGS)
>>>> +s3c64xx_clock_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>> +## s3c64xx/timer
>>>> +#noinst_PROGRAMS += s3c64xx/timer.rel
>>>> +#s3c64xx_timer_rel_SOURCES = s3c64xx/timer/timer.c
>>>> +#s3c64xx_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
>>>> +#s3c64xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>> +## s3c64xx/interrupt
>>>> +include_bsp_HEADERS += s3c64xx/irq/irq.h
>>>> +noinst_PROGRAMS += s3c64xx/irq.rel
>>>> +s3c64xx_irq_rel_SOURCES = s3c64xx/irq/irq.c \
>>>> + s3c64xx/irq/irq.h
>>>> +s3c64xx_irq_rel_CPPFLAGS = $(AM_CPPFLAGS)
>>>> +s3c64xx_irq_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>> +endif
>>>> if lpc22xx
>>>> include_HEADERS = lpc22xx/include/lpc22xx.h
>>>> diff --git a/c/src/lib/libcpu/arm/configure.ac b/c/src/lib/libcpu/arm/
>>>> configure.ac
>>>> index ae0967b..4f3ebea 100644
>>>> --- a/c/src/lib/libcpu/arm/configure.ac
>>>> +++ b/c/src/lib/libcpu/arm/configure.ac
>>>> @@ -23,6 +23,7 @@ AM_CONDITIONAL(shared, test "$RTEMS_CPU_MODEL" =
>>>> "at91rm9200" || \
>>>> test "$RTEMS_CPU_MODEL" = "mc9328mxl" || \
>>>> test "$RTEMS_CPU_MODEL" = "s3c2410" || \
>>>> test "$RTEMS_CPU_MODEL" = "s3c2400" || \
>>>> + test "$RTEMS_CPU_MODEL" = "s3c6410" || \
>>>> test "$RTEMS_CPU_MODEL" = "pxa255")
>>>> AM_CONDITIONAL(at91rm9200, test "$RTEMS_CPU_MODEL" = "at91rm9200")
>>>> @@ -31,6 +32,7 @@ AM_CONDITIONAL(lpc22xx, test "$RTEMS_CPU_MODEL" =
>>>> "lpc22xx")
>>>> AM_CONDITIONAL(pxa255, test "$RTEMS_CPU_MODEL" = "pxa255")
>>>> AM_CONDITIONAL(s3c24xx, test "$RTEMS_CPU_MODEL" = "s3c2400" ||\
>>>> test "$RTEMS_CPU_MODEL" = "s3c2410")
>>>> +AM_CONDITIONAL(s3c64xx, test "$RTEMS_CPU_MODEL" = "s3c6410")
>>>> RTEMS_AMPOLISH3
>>>> diff --git a/c/src/lib/libcpu/arm/preinstall.am b/c/src/lib/libcpu/arm/
>>>> preinstall.am
>>>> index 751a085..0a8109c 100644
>>>> --- a/c/src/lib/libcpu/arm/preinstall.am
>>>> +++ b/c/src/lib/libcpu/arm/preinstall.am
>>>> @@ -113,6 +113,19 @@ $(PROJECT_INCLUDE)/bsp/irq.h: s3c24xx/irq/irq.h
>>>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>>>> endif
>>>> +if s3c64xx
>>>> +$(PROJECT_INCLUDE)/s3c64xx.h: s3c64xx/include/s3c64xx.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/s3c64xx.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/s3c64xx.h
>>>> +$(PROJECT_INCLUDE)/s3c6410.h: s3c64xx/include/s3c6410.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/s3c6410.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/s3c6410.h
>>>> +$(PROJECT_INCLUDE)/bsp/irq.h: s3c64xx/irq/irq.h
>>>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>>>> +endif
>>>> if lpc22xx
>>>> $(PROJECT_INCLUDE)/lpc22xx.h: lpc22xx/include/lpc22xx.h
>>>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/lpc22xx.h
>>>> diff --git a/c/src/lib/libcpu/arm/s3c64xx/clock/clockdrv.c
>>>> b/c/src/lib/libcpu/arm/s3c64xx/clock/clockdrv.c
>>>> index 0000000..5893014
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libcpu/arm/s3c64xx/clock/clockdrv.c
>>>> @@ -0,0 +1,141 @@
>>>> + * S3C6410 clock specific using the System Timer
>>>> + * This is hardware specific part of the clock driver. At the end of
>>>> this
>>>> + * file, the generic part of the driver is #included.
>>>> + * 1. modified from S3C2440 Peng Fan van.freenix at gmail.com
>>>> +#include <rtems.h>
>>>> +#include <bsp.h>
>>>> +void Clock_isr(rtems_irq_hdl_param arg);
>>>> +static void clock_isr_on(const rtems_irq_connect_data *unused);
>>>> +static void clock_isr_off(const rtems_irq_connect_data *unused);
>>>> +static int clock_isr_is_on(const rtems_irq_connect_data *irq);
>>>> +rtems_irq_connect_data clock_isr_data = {
>>>> + .name = BSP_TIMER4,
>>>> + .hdl = Clock_isr,
>>>> + .handle = NULL,
>>>> + .on = clock_isr_on,
>>>> + .off = clock_isr_off,
>>>> + .isOn = clock_isr_is_on,
>>>> + * Return the nanoseconds since last tick
>>>> +uint32_t clock_driver_get_nanoseconds_since_last_tick(void)
>>>> + return 0;
>>>> +#define Clock_driver_nanoseconds_since_last_tick \
>>>> + clock_driver_get_nanoseconds_since_last_tick
>>>> + * When we get the clock interrupt
>>>> + * - clear the interrupt bit?
>>>> + * - restart the timer?
>>>> + Clear BIT_TIMER4 interrupt; \
>>>> +#define Clock_driver_support_at_tick() \
>>>> + do { \
>>>> + rTINT_CSTAT |= 1 << 9;\
>>>> + } while(0)
>>>> + * Installs the clock ISR. You shouldn't need to change this.
>>>> +extern uint32_t *VIC0_VECTADDR;
>>>> +extern uint32_t *VIC1_VECTADDR;
>>>> +#define Clock_driver_support_install_isr( _new, _old ) \
>>>> + do { \
>>>> + _old = NULL; \
>>>> + VIC0_VECTADDR[BSP_TIMER4] = _new; \
>>>> + rtems_interrupt_handler_install(clock_isr_data.name,\
>>>> + "TICK TIMER",\
>>>> + RTEMS_INTERRUPT_UNIQUE,\
>>>> + clock_isr_data.hdl,\
>>>> + clock_isr_data.handle);\
>>>> + } while(0)
>>>> + * Initialize the hardware for the clock
>>>> + * - Set the frequency
>>>> + * - enable it
>>>> + * - clear any pending interrupts
>>>> + * Since you may want the clock always running, you can
>>>> + * enable interrupts here. If you do so, the clock_isr_on(),
>>>> + * clock_isr_off(), and clock_isr_is_on() functions can be
>>>> + * NOPs.
>>>> + * The bit and constant number should be redifined using macros
>>>> +#define Clock_driver_support_initialize_hardware() \
>>>> + do { \
>>>> + rTCON = 0x0;\
>>>> + rTINT_CSTAT |= 1 << 4;\
>>>> + bsp_interrupt_vector_enable(BSP_TIMER4);\
>>>> + rTCFG0 = 0x0101;\
>>>> + rTCFG1 = (rTCFG1 & 0xf0000) | 0x40000;\
>>>> + rTCNTB4 = 0x512d;\
>>>> + rTCON = (rTCON & ~0x00700000) | (1<<22) | (1<<21);\
>>>> + rTCON = (rTCON & ~0x00700000) | (1<<22) | (1<<20);\
>>>> + /* auto load, start Timer 4 */\
>>>> + } while (0)
>>>> + * Do whatever you need to shut the clock down and remove the
>>>> + * interrupt handler. Since this normally only gets called on
>>>> + * RTEMS shutdown, you may not need to do anything other than
>>>> + * remove the ISR.
>>>> +#define Clock_driver_support_shutdown_hardware()
>>>> + do {
>>>> + /* Disable timer */ \
>>>> + BSP_remove_rtems_irq_handler(&clock_isr_data);
>>>> + } while (0)
>>>> + * Enables clock interrupt.
>>>> + * If the interrupt is always on, this can be a NOP.
>>>> + * Disables clock interrupts
>>>> + return;
>>>> + * Tests to see if clock interrupt is enabled, and returns 1 if so.
>>>> + * If interrupt is not enabled, returns 0.
>>>> + * If the interrupt is always on, this always returns 1.
>>>> +/* Make sure to include this, and only at the end of the file */
>>>> +#include "../../../../libbsp/shared/clockdrv_shell.h"
>>>> diff --git a/c/src/lib/libcpu/arm/s3c64xx/clock/support.c
>>>> b/c/src/lib/libcpu/arm/s3c64xx/clock/support.c
>>>> index 0000000..f4a853c
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libcpu/arm/s3c64xx/clock/support.c
>>>> @@ -0,0 +1,51 @@
>>>> + * 1. Modified from S3C2440 Peng Fan van.freenix at gmail.com
>>>> + * Note: Now the clock related setting is done in uboot.
>>>> + * This will be fixed in future
>>>> +#include <rtems.h>
>>>> +#include <bsp.h>
>>>> +/* NOTE: This describes the proper use of this file.
>>>> + * BSP_OSC_FREQ should be defined as the input frequency of the PLL.
>>>> + * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock
>>>> of
>>>> + * the specified bus in HZ.
>>>> +uint32_t *VIC0_VECTADDR = (uint32_t *)VIC0_VECTADDR_BASE;
>>>> +uint32_t *VIC1_VECTADDR = (uint32_t *)VIC1_VECTADDR_BASE;
>>>> +/* return FCLK frequency */
>>>> + /* not implemented */
>>>> + return 0;
>>>> +/* return UCLK frequency */
>>>> + return 0;
>>>> +/* return HCLK frequency */
>>>> + return 0;
>>>> +/* return PCLK frequency */
>>>> + /* Just return uboot configured freq.
>>>> + * Fix this in future
>>>> + return 66000000;
>>>> diff --git a/c/src/lib/libcpu/arm/s3c64xx/include/s3c6410.h
>>>> b/c/src/lib/libcpu/arm/s3c64xx/include/s3c6410.h
>>>> index 0000000..56b1dcd
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libcpu/arm/s3c64xx/include/s3c6410.h
>>>> @@ -0,0 +1,211 @@
>>>> + * NAME : s3c6410.h
>>>> + * Version : 4.07.2013
>>>> + * for the Samsung Development Board
>>>> +#ifndef __S3C6410_H__
>>>> +#define __S3C6410_H__
>>>> +#define __reg(addr) (*(volatile unsigned *)(addr))
>>>> +/* UART */
>>>> +#define UART_BASE (0x7F005000)
>>>> +#define UART0_BASE (UART_BASE + 0x0)
>>>> +#define UART1_BASE (UART_BASE + 0x400)
>>>> +#define UART2_BASE (UART_BASE + 0x800)
>>>> +#define UART2_BASE (UART_BASE + 0xC00)
>>>> +#define rULCON0 __reg(UART0_BASE + 0x00)
>>>> +#define rUCON0 __reg(UART0_BASE + 0x04)
>>>> +#define rUFCON0 __reg(UART0_BASE + 0x08)
>>>> +#define rUMCON0 __reg(UART0_BASE + 0x0C)
>>>> +#define rUTRSTAT0 __reg(UART0_BASE + 0x10)
>>>> +#define rUERSTAT0 __reg(UART0_BASE + 0x14)
>>>> +#define rUFSTAT0 __reg(UART0_BASE + 0x18)
>>>> +#define rUMSTAT0 __reg(UART0_BASE + 0x1C)
>>>> +#define rUTXH0 __reg(UART0_BASE + 0x20)
>>>> +#define rURXH0 __reg(UART0_BASE + 0x24)
>>>> +#define rUBRDIV0 __reg(UART0_BASE + 0x28)
>>>> +#define rUDIVSLOT0 __reg(UART0_BASE + 0x2C)
>>>> +#define rUINTP0 __reg(UART0_BASE + 0x30)
>>>> +#define rUINTSP0 __reg(UART0_BASE + 0x34)
>>>> +#define rUINTM0 __reg(UART0_BASE + 0x38)
>>>> +#define rULCON1 __reg(UART1_BASE + 0x00)
>>>> +#define rUCON1 __reg(UART1_BASE + 0x04)
>>>> +#define rUFCON1 __reg(UART1_BASE + 0x08)
>>>> +#define rUMCON1 __reg(UART1_BASE + 0x0C)
>>>> +#define rUTRSTAT1 __reg(UART1_BASE + 0x10)
>>>> +#define rUERSTAT1 __reg(UART1_BASE + 0x14)
>>>> +#define rUFSTAT1 __reg(UART1_BASE + 0x18)
>>>> +#define rUMSTAT1 __reg(UART1_BASE + 0x1C)
>>>> +#define rUTXH1 __reg(UART1_BASE + 0x20)
>>>> +#define rURXH1 __reg(UART1_BASE + 0x24)
>>>> +#define rUBRDIV1 __reg(UART1_BASE + 0x28)
>>>> +#define rUDIVSLOT1 __reg(UART1_BASE + 0x2C)
>>>> +#define rUINTP1 __reg(UART1_BASE + 0x30)
>>>> +#define rUINTSP1 __reg(UART1_BASE + 0x34)
>>>> +#define rUINTM1 __reg(UART1_BASE + 0x38)
>>>> +/* GPIO */
>>>> +#define GPIO_BASE (0x7F008000)
>>>> +#define GPIOA_BASE GPIO_BASE
>>>> +#define rGPKCON0 __reg(0x7F008800)
>>>> +#define rGPKCON1 __reg(0x7F008804)
>>>> +#define rGPKDAT __reg(0x7F008808)
>>>> +#define rGPKPUD __reg(0x7F00880C)
>>>> +#define rEINT0PEND __reg(0x7F008924)
>>>> +/* TIMER */
>>>> +#define TIMER_BASE (0x7F006000)
>>>> +#define rTCFG0 __reg(TIMER_BASE + 0x0)
>>>> +#define rTCFG1 __reg(TIMER_BASE + 0x4)
>>>> +#define rTCON __reg(TIMER_BASE + 0x8)
>>>> +#define rTCNTB0 __reg(TIMER_BASE + 0xC)
>>>> +#define rTCMPB0 __reg(TIMER_BASE + 0x10)
>>>> +#define rTCNTO0 __reg(TIMER_BASE + 0x14)
>>>> +#define rTCNTB1 __reg(TIMER_BASE + 0x18)
>>>> +#define rTCMPB1 __reg(TIMER_BASE + 0x1C)
>>>> +#define rTCNTO1 __reg(TIMER_BASE + 0x20)
>>>> +#define rTCNTB2 __reg(TIMER_BASE + 0x24)
>>>> +#define rTCNTO2 __reg(TIMER_BASE + 0x2C)
>>>> +#define rTCNTB3 __reg(TIMER_BASE + 0x30)
>>>> +#define rTCNTO3 __reg(TIMER_BASE + 0x38)
>>>> +#define rTCNTB4 __reg(TIMER_BASE + 0x3C)
>>>> +#define rTCNTO4 __reg(TIMER_BASE + 0x40)
>>>> +#define rTINT_CSTAT __reg(TIMER_BASE + 0x44)
>>>> + * Interrupt
>>>> +/* VIC */
>>>> +#define VIC0_BASE_ADDR (0x71200000)
>>>> +#define VIC1_BASE_ADDR (0x71300000)
>>>> +#define rVIC0_IRQSTATUS __reg(VIC0_BASE_ADDR +
>>>> 0x0)
>>>> +#define rVIC0_FIQSTATUS __reg(VIC0_BASE_ADDR +
>>>> 0x4)
>>>> +#define rVIC0_RAWINTR __reg(VIC0_BASE_ADDR +
>>>> 0x8)
>>>> +#define rVIC0_INTSELECT __reg(VIC0_BASE_ADDR +
>>>> 0xC)
>>>> +#define rVIC0_INTENABLE __reg(VIC0_BASE_ADDR +
>>>> 0x10)
>>>> +#define rVIC0_INTENCLEAR __reg(VIC0_BASE_ADDR + 0x14)
>>>> +#define rVIC0_SOFTINT __reg(VIC0_BASE_ADDR +
>>>> 0x18)
>>>> +#define rVIC0_SOFTINTCLEAR __reg(VIC0_BASE_ADDR + 0x1C)
>>>> +#define rVIC0_PROTECTION __reg(VIC0_BASE_ADDR + 0x20)
>>>> +#define rVIC0_SWPPIORITYMASK __reg(VIC0_BASE_ADDR + 0x24)
>>>> +#define rVIC0_PRIORITYDAISY __reg(VIC0_BASE_ADDR + 0x28)
>>>> +#define VIC0_VECTADDR_BASE (VIC0_BASE_ADDR + 0x100)
>>>> +#define rVIC0_ADDRESS __reg(VIC0_BASE_ADDR +
>>>> 0xF00)
>>>> +#define rVIC1_IRQSTATUS __reg(VIC1_BASE_ADDR +
>>>> 0x0)
>>>> +#define rVIC1_FIQSTATUS __reg(VIC1_BASE_ADDR +
>>>> 0x4)
>>>> +#define rVIC1_RAWINTR __reg(VIC1_BASE_ADDR +
>>>> 0x8)
>>>> +#define rVIC1_INTSELECT __reg(VIC1_BASE_ADDR +
>>>> 0xC)
>>>> +#define rVIC1_INTENABLE __reg(VIC1_BASE_ADDR +
>>>> 0x10)
>>>> +#define rVIC1_INTENCLEAR __reg(VIC1_BASE_ADDR + 0x14)
>>>> +#define rVIC1_SOFTINT __reg(VIC1_BASE_ADDR +
>>>> 0x18)
>>>> +#define rVIC1_SOFTINTCLEAR __reg(VIC1_BASE_ADDR + 0x1C)
>>>> +#define rVIC1_PROTECTION __reg(VIC1_BASE_ADDR + 0x20)
>>>> +#define rVIC1_SWPPIORITYMASK __reg(VIC1_BASE_ADDR + 0x24)
>>>> +#define rVIC1_PRIORITYDAISY __reg(VIC1_BASE_ADDR + 0x28)
>>>> +#define VIC1_VECTADDR_BASE (VIC1_BASE_ADDR + 0x100)
>>>> +#define rVIC1_ADDRESS __reg(VIC1_BASE_ADDR +
>>>> 0xF00)
>>>> +/* ADC */
>>>> +#define rADCCON
>>>> __reg(0x7E00B000)
>>>> +#define rADCTSC
>>>> __reg(0x7E00B004)
>>>> +#define rADCDLY
>>>> __reg(0x7E00B008)
>>>> +#define rADCDAT0
>>>> __reg(0x7E00B00C)
>>>> +#define rADCDAT1
>>>> __reg(0x7E00B010)
>>>> +#define rADCUPDN
>>>> __reg(0x7E00B014)
>>>> +#define rADCCLRINT
>>>> __reg(0x7E00B018)
>>>> +#define rADCCLRINTPNDNUP __reg(0x7E00B020)
>>>> +/* WATCH DOG */
>>>> +#define rWTCON
>>>> __reg(0x7E004000)
>>>> +#define rWTDAT
>>>> __reg(0x7E004004)
>>>> +#define rWTCNT
>>>> __reg(0x7E004008)
>>>> +#define rWTCLRINT
>>>> __reg(0x7E00400C)
>>>> +/* RTC */
>>>> +#define rINTP
>>>> __reg(0x7E005030)
>>>> +#define rTICCNT
>>>> __reg(0x7E005044)
>>>> +/* NAND */
>>>> +#define NAND_BASE 0x70200000
>>>> +#define rNFCONF
>>>> __reg(NAND_BASE + 0x0)
>>>> +#define rNFCONT
>>>> __reg(NAND_BASE + 0x4)
>>>> +#define rNFCNND
>>>> __reg(NAND_BASE + 0x8)
>>>> +#define rNFADDR
>>>> __reg(NAND_BASE + 0xC)
>>>> +#define rNFDATA
>>>> __reg(NAND_BASE + 0x10)
>>>> +#define rNFMECCD0 __reg(NAND_BASE
>>>> + 0x14)
>>>> +#define rNFMECCD1 __reg(NAND_BASE
>>>> + 0x18)
>>>> +#define rNFSECCD __reg(NAND_BASE
>>>> + 0x1C)
>>>> +#define rNFSBLK
>>>> __reg(NAND_BASE + 0x20)
>>>> +#define rNFEBLK
>>>> __reg(NAND_BASE + 0x24)
>>>> +#define rNFSTAT
>>>> __reg(NAND_BASE + 0x28)
>>>> +#define rNFECCERR0 __reg(NAND_BASE + 0x2C)
>>>> +#define rNFECCERR1 __reg(NAND_BASE + 0x30)
>>>> +#define rNFMECC0 __reg(NAND_BASE
>>>> + 0x34)
>>>> +#define rNFMECC1 __reg(NAND_BASE
>>>> + 0x38)
>>>> +#define rNFSECC
>>>> __reg(NAND_BASE + 0x3C)
>>>> +#define rNFMLCBITPT __reg(NAND_BASE + 0x40)
>>>> +#define rNF8ECCERR0 __reg(NAND_BASE + 0x44)
>>>> +#define rNF8ECCERR1 __reg(NAND_BASE + 0x48)
>>>> +#define rNF8ECCERR2 __reg(NAND_BASE + 0x4C)
>>>> +#define rNFM8ECC0 __reg(NAND_BASE
>>>> + 0x50)
>>>> +#define rNFM8ECC1 __reg(NAND_BASE
>>>> + 0x54)
>>>> +#define rNFM8ECC2 __reg(NAND_BASE
>>>> + 0x58)
>>>> +#define rNFM8ECC3 __reg(NAND_BASE
>>>> + 0x5C)
>>>> +#define rNFMLC8BITPT0 __reg(NAND_BASE + 0x60)
>>>> +#define rNFMLC8BITPT1 __reg(NAND_BASE + 0x64)
>>>> +#define BIT0 0x00000001
>>>> +#define BIT1 0x00000002
>>>> +#define BIT2 0x00000004
>>>> +#define BIT3 0x00000008
>>>> +#define BIT4 0x00000010
>>>> +#define BIT5 0x00000020
>>>> +#define BIT6 0x00000040
>>>> +#define BIT7 0x00000080
>>>> +#define BIT8 0x00000100
>>>> +#define BIT9 0x00000200
>>>> +#define BIT10 0x00000400
>>>> +#define BIT11 0x00000800
>>>> +#define BIT12 0x00001000
>>>> +#define BIT13 0x00002000
>>>> +#define BIT14 0x00004000
>>>> +#define BIT15 0x00008000
>>>> +#define BIT16 0x00010000
>>>> +#define BIT17 0x00020000
>>>> +#define BIT18 0x00040000
>>>> +#define BIT19 0x00080000
>>>> +#define BIT20 0x00100000
>>>> +#define BIT21 0x00200000
>>>> +#define BIT22 0x00400000
>>>> +#define BIT23 0x00800000
>>>> +#define BIT24 0x01000000
>>>> +#define BIT25 0x02000000
>>>> +#define BIT26 0x04000000
>>>> +#define BIT27 0x08000000
>>>> +#define BIT28 0x10000000
>>>> +#define BIT29 0x20000000
>>>> +#define BIT30 0x40000000
>>>> +#define BIT31 0x80000000
>>>> +#endif /*__S3C6410_H__*/
>>>> diff --git a/c/src/lib/libcpu/arm/s3c64xx/include/s3c64xx.h
>>>> b/c/src/lib/libcpu/arm/s3c64xx/include/s3c64xx.h
>>>> index 0000000..6396629
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libcpu/arm/s3c64xx/include/s3c64xx.h
>>>> @@ -0,0 +1,15 @@
>>>> + * NAME : s3c64xx.h
>>>> + * share code for different Samsung CPU
>>>> +#ifndef S3C64XX_H_
>>>> +#define S3C64XX_H_
>>>> +#ifdef CPU_S3C6410
>>>> +#include <s3c6410.h>
>>>> +#endif
>>>> +#endif /*S3C64XX_H_*/
>>>> diff --git a/c/src/lib/libcpu/arm/s3c64xx/irq/irq.c
>>>> b/c/src/lib/libcpu/arm/s3c64xx/irq/irq.c
>>>> index 0000000..e0cb6d2
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libcpu/arm/s3c64xx/irq/irq.c
>>>> @@ -0,0 +1,79 @@
>>>> +/* irq.c
>>>> + * This file contains the implementation of the function described in
>>>> irq.h
>>>> + * CopyRight (C) 2000 Canon Research France SA.
>>>> +#include <rtems/score/armv4.h>
>>>> +#include <bsp.h>
>>>> +typedef void (*vicfunc)(void);
>>>> +void bsp_interrupt_dispatch(void)
>>>> + uint32_t vector_addr0 = rVIC0_ADDRESS;
>>>> + uint32_t vector_addr1 = rVIC1_ADDRESS;
>>>> + if (vector_addr0 != 0){
>>>> + void (*vicfunc)(void) = (void(*)(void))rVIC0_ADDRESS;
>>>> + vicfunc();
>>>> + if (vector_addr1 != 0){
>>>> + void (*vicfunc)(void) = (void(*)(void))rVIC1_ADDRESS;
>>>> + vicfunc();
>>>> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number
>>>> vector)
>>>> + if (vector < 32)
>>>> + rVIC0_INTENABLE |= 1 << vector;
>>>> + else if (vector < 64)
>>>> + rVIC1_INTENABLE |= 1 << (vector - 32);
>>>> + else
>>>> + printk("%s failed\n", __func__);
>>>> + return RTEMS_SUCCESSFUL;
>>>> +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number
>>>> vector)
>>>> + if (vector < 32)
>>>> + rVIC0_INTENCLEAR |= 1 << vector;
>>>> + rVIC1_INTENCLEAR |= 1 << (vector - 32);
>>>> + else
>>>> +rtems_status_code bsp_interrupt_facility_initialize(void)
>>>> + _CPU_ISR_install_vector(ARM_EXCEPTION_IRQ,
>>>> _ARMV4_Exception_interrupt, NULL);
>>>> diff --git a/c/src/lib/libcpu/arm/s3c64xx/irq/irq.h
>>>> b/c/src/lib/libcpu/arm/s3c64xx/irq/irq.h
>>>> index 0000000..2f3ca6a
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libcpu/arm/s3c64xx/irq/irq.h
>>>> @@ -0,0 +1,100 @@
>>>> +/* irq.h
>>>> + * Common file, merged from s3c2400/irq/irq.h and s3c2410/irq/irq.h
>>>> + * 1. Modified from s3c2400 Peng Fan van.freenix at gmail.com
>>>> +#ifndef _IRQ_H_
>>>> +#define _IRQ_H_
>>>> +#ifndef ASM
>>>> +#include <rtems.h>
>>>> +#include <rtems/irq.h>
>>>> +#include <rtems/irq-extension.h>
>>>> +#ifdef CPU_S3C6410
>>>> + /* possible interrupt sources */
>>>> +#define BSP_EINT0 0
>>>> +#define BSP_EINT1 1
>>>> +#define BSP_RTC_TIC 2
>>>> +#define BSP_CAMIF_C 3
>>>> +#define BSP_CAMIF_P 4
>>>> +#define BSP_I2C1 5
>>>> +#define BSP_I2S0_1_V40 6
>>>> +/* 7 is reserved */
>>>> +#define BSP_3D 8
>>>> +#define BSP_POST0 9
>>>> +#define BSP_RPTATOR 10
>>>> +#define BSP_2D 11
>>>> +#define BSP_TVENC 12
>>>> +#define BSP_SCALER 13
>>>> +#define BSP_BATF 14
>>>> +#define BSP_JPEG 15
>>>> +#define BSP_MFC 16
>>>> +#define BSP_SDMA0 17
>>>> +#define BSP_SDMA1 18
>>>> +#define BSP_ARM_DMAERR 19
>>>> +#define BSP_ARM_DMA 20
>>>> +#define BSP_ARM_DMAS 21
>>>> +#define BSP_KEYPAD 22
>>>> +#define BSP_TIMER0 23
>>>> +#define BSP_TIMER1 24
>>>> +#define BSP_TIMER2 25
>>>> +#define BSP_WDT 26
>>>> +#define BSP_TIMER3 27
>>>> +#define BSP_TIMER4 28
>>>> +#define BSP_LCD0 29
>>>> +#define BSP_LCD1 30
>>>> +#define BSP_LCD2 31
>>>> +#define BSP_EINT2 32
>>>> +#define BSP_EINT3 33
>>>> +#define BSP_PCM0 34
>>>> +#define BSP_PCM1 35
>>>> +#define BSP_AC97 36
>>>> +#define BSP_UART0 37
>>>> +#define BSP_UART1 38
>>>> +#define BSP_UART2 39
>>>> +#define BSP_UART3 40
>>>> +#define BSP_DMA0 41
>>>> +#define BSP_DMA1 42
>>>> +#define BSP_ONENAND0 43
>>>> +#define BSP_ONENAND1 44
>>>> +#define BSP_NFC 45
>>>> +#define BSP_CFC 46
>>>> +#define BSP_UHOST 47
>>>> +#define BSP_SPI0 48
>>>> +#define BSP_SPI1 49
>>>> +#define BSP_HSMMC2 49
>>>> +#define BSP_I2C0 50
>>>> +#define BSP_HSItx 51
>>>> +#define BSP_HSIrx 52
>>>> +#define BSP_EINT4 53
>>>> +#define BSP_MSM 54
>>>> +#define BSP_HOSTIF 55
>>>> +#define BSP_HSMMC0 56
>>>> +#define BSP_HSMMC1 57
>>>> +#define BSP_OTG 58
>>>> +#define BSP_IrDA 59
>>>> +#define BSP_RTC_ALARM 60
>>>> +#define BSP_SEC 61
>>>> +#define BSP_PENDNUP 62
>>>> +#define BSP_ADC 63
>>>> +#define BSP_MAX_INT 64
>>>> +#endif
>>>> +#define BSP_INTERRUPT_VECTOR_MIN 0
>>>> +#define BSP_INTERRUPT_VECTOR_MAX (BSP_MAX_INT - 1)
>>>> +#endif /* ASM */
>>>> +#endif /* _IRQ_H_ */
>>>> +/* end of include file */
>>>> diff --git a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
>>>> b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
>>>> index 3edc83f..45af5dd 100644
>>>> --- a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
>>>> +++ b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
>>>> @@ -609,6 +609,23 @@ static inline void
>>>> arm_cp15_data_cache_test_and_clean(void)
>>>> +static inline void arm_cp15_data_cache_clean_and_invalidate(void)
>>>> + ARM_SWITCH_REGISTERS;
>>>> + uint32_t sbz = 0;
>>>> + ARM_SWITCH_TO_ARM
>>>> + "mcr p15, 0, %[sbz], c7, c14, 0\n"
>>>> + ARM_SWITCH_BACK
>>>> + : ARM_SWITCH_OUTPUT
>>>> + : [sbz] "r" (sbz)
>>>> + : "memory"
>>>> static inline void arm_cp15_data_cache_clean_and_invalidate_line(const
>>>> void *mva)
>>>> 1.7.10.4
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Regards,
> Dhananjay M Balan,
> Department Of Computer Science,
> College Of Engineering, Trivandrum.
> http://cet.ac.in
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130417/bda3a014/attachment-0001.html>
