[PATCH] LM3S3749 BSP
emanuel stiebler emu at e-bbes.com
Sun Apr 21 16:50:49 UTC 2013
On 2013-04-21 17:42, Eugeniy Meshcheryakov wrote:> Hello,
 > I tested this code on a self-made board, but it should be useful for
 > any board with this MCU that uses an external oscillator as system clock
 > source. The following test programs worked fine: base_sp, hello, nsecs,
 > ticker, unlimited (only 4 tasks). There was no output from capture and
 > fileio samples, paranoia sample complained about lack of memory. I also
 > used my own programs to test SPI and interrupts.
Hi Eugeniy,
any chance you could write up, how you tested it on your hardware?
(Did you put the tests into flash, or just downloaded it, what did you
use as JTAG interface, etc.)
Thanks in advance ...
