[PATCH] LM3S3749 BSP
Eugeniy Meshcheryakov eugen at debian.org
Sun Apr 21 17:06:48 UTC 2013
Hi,
21 квітня 2013 о 18:50 +0200 emanuel stiebler написав(-ла):
> Hi Eugeniy,
> any chance you could write up, how you tested it on your hardware?
> (Did you put the tests into flash, or just downloaded it, what did
> you use as JTAG interface, etc.)
I tested everything using openOCD with OpenMoko debug board v3 as JTAG
interface (FT2232-based). The copy of config file is available here:
    https://github.com/eugmes/rtems-test/blob/master/openocd.conf
Programs were flashed onto MCU. Usual sequence is (via openOCD telnet
interface):
    flash write_image erase /path/to/image
    reset init
    resume
UART0 was used for serial console. At early stages of development
(before I've got UART working) openOCD's semihosting support was useful.
Regards,
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130421/64a9c5c7/attachment-0001.bin>
