[PATCH] parallelize bootstrap
Rempel, Cynthia
cynt6007 at vandals.uidaho.edu
Fri Aug 2 06:49:40 UTC 2013
Hi,
Applying this patch changes the for loops using autoconf into parallel for loops calling autoconf.
It reduced the time to run bootstrap from ~9:30 to ~2:45
It's limited to 10 sub shells working in parallel though...
I only checked that hello.exe and ticker.exe ran on sparc-rtems4.11-gdb...
Thanks!
Cindy
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of Sebastian Huber [sebastian.huber at embedded-brains.de]
Sent: Thursday, August 01, 2013 11:38 PM
To: Ashi
Cc: rtems-devel at rtems.org
Subject: Re: [PATCH] posix: Reimplement POSIX Key manager to use a red-black tree.
On 2013-08-02 03:03, Ashi wrote:
> + /** This field points to parent freechain node */
> + POSIX_Keys_Freechain_node *fc_node_ptr;
> I don't think we need this fc_node_ptr.
> Do you mean use a 'Container' macro instead?
Not necessarily, see below.
> + /** This field is the POSIX key used as an rbtree key */
> + pthread_key_t key;
> + /** This field is the Thread id also used as an rbtree key */
> + Objects_Id thread_id;
> + /** This field points to the POSIX key value of specific thread */
> + void *value;
> +} POSIX_Keys_Rbtree_node;
> I would call this POSIX_Keys_Key_value_pair.
> + * @brief POSIX_Keys_Freechain is used in Freechain structure
> +typedef struct {
> + Freechain_Control super_fc;
> + size_t bump_count;
> +} POSIX_Keys_Freechain;
> + * @brief POSIX_Keys_Freechain_node is freechain node
> +struct POSIX_Keys_Freechain_node___struct {
> + Chain_Node ch_node;
> + POSIX_Keys_Rbtree_node rb_node;
> Why not use POSIX_Keys_Rbtree_node directly?
> Since every freechain node needs a Chain_Node in its first field. There is a
> Chain_Node in POSIX_Keys_Rbtree_node, but it is used in each thread's key
> value chain. So I add a Chain_Node to POSIX_Keys_Rbtree_node.
The key value pairs on the free chain are unused, thus not part of other data
structures. So basically you can cast an unused object to any type provided it
has enough storage.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
Type: text/x-patch
Desc: parallelize_bootstrap.patch
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130802/a55995c0/attachment.bin>
