[PATCH 2/2] smp: Generalize _Thread_Start_multitasking()
Sebastian Huber
Thu Aug 1 14:55:47 UTC 2013
Add context parameter to _Thread_Start_multitasking() and use this
function in rtems_smp_secondary_cpu_initialize(). This avoids
duplication of code.
Fix missing floating point context initialization in
rtems_smp_secondary_cpu_initialize(). Now performed via
_Thread_Start_multitasking().
cpukit/sapi/src/exinit.c | 6 ++-
cpukit/score/include/rtems/score/threadimpl.h | 2 +-
cpukit/score/src/smp.c | 27 +-------------
cpukit/score/src/threadstartmultitasking.c | 49 +++++++++++++++----------
4 files changed, 37 insertions(+), 47 deletions(-)
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 7dad241..bfcfa7c 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -219,11 +219,13 @@ void rtems_initialize_start_multitasking(void)
uint32_t status;
-#ifdef RTEMS_SMP
+ _System_state_Set( SYSTEM_STATE_UP );
+#if defined(RTEMS_SMP)
_SMP_Request_other_cores_to_perform_first_context_switch();
#endif
- _Thread_Start_multitasking();
+ _Thread_Start_multitasking( &_Thread_BSP_context );
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index fcd3f07..128820b 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -118,7 +118,7 @@ void _Thread_Create_idle(void);
* + ready chain
* + select heir
-void _Thread_Start_multitasking( void );
+void _Thread_Start_multitasking( Context_Control *context );
* @brief Allocate the requested stack space for the thread.
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 5b299b4..4f72290 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -19,8 +19,8 @@
#endif
#include <rtems/bspsmp.h>
-#include <rtems/score/thread.h>
+#include <rtems/score/threadimpl.h>
#include <rtems/score/smp.h>
#include <rtems/score/sysstate.h>
@@ -41,27 +41,7 @@ void rtems_smp_secondary_cpu_initialize( void )
_Per_CPU_Wait_for_state( self_cpu, PER_CPU_STATE_BEGIN_MULTITASKING );
- _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_UP );
- * The Scheduler will have selected the heir thread for each CPU core.
- * Now we have been requested to perform the first context switch. So
- * force a switch to the designated heir and make it executing on
- * THIS core.
- heir = self_cpu->heir;
- heir->is_executing = true;
- self_cpu->executing->is_executing = false;
- self_cpu->executing = heir;
- self_cpu->dispatch_necessary = false;
- * Threads begin execution in the _Thread_Handler() function. This function
- * will call _Thread_Enable_dispatch().
- _Thread_Disable_dispatch();
- _CPU_Context_switch_to_first_task_smp( &heir->Registers );
+ _Thread_Start_multitasking( NULL );
void rtems_smp_process_interrupt( void )
@@ -158,9 +138,6 @@ void _SMP_Request_other_cores_to_perform_first_context_switch( void )
if ( cpu != self ) {
_Per_CPU_Change_state( per_cpu, PER_CPU_STATE_BEGIN_MULTITASKING );
- } else {
- _Per_CPU_Change_state( per_cpu, PER_CPU_STATE_UP );
diff --git a/cpukit/score/src/threadstartmultitasking.c b/cpukit/score/src/threadstartmultitasking.c
index 459d0d6..b6ff073 100644
--- a/cpukit/score/src/threadstartmultitasking.c
+++ b/cpukit/score/src/threadstartmultitasking.c
@@ -19,26 +19,21 @@
#endif
-#include <rtems/score/sysstate.h>
- * The system is now multitasking and completely initialized.
- * This system thread now "hides" in a single processor until
- * the system is shut down.
+ Per_CPU_Control *self_cpu = _Per_CPU_Get();
+ Thread_Control *heir = self_cpu->heir;
- _System_state_Set( SYSTEM_STATE_UP );
+ _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_UP );
- _Thread_Dispatch_necessary = false;
- #if defined(RTEMS_SMP)
- _Thread_Executing->is_executing = false;
- _Thread_Heir->is_executing = true;
- #endif
+ self_cpu->executing->is_executing = false;
+ heir->is_executing = true;
+#endif
- _Thread_Executing = _Thread_Heir;
+ self_cpu->dispatch_necessary = false;
+ self_cpu->executing = heir;
* Get the init task(s) running.
@@ -58,13 +53,29 @@ void _Thread_Start_multitasking( void )
* don't need to worry about saving BSP's floating point state
- if ( _Thread_Heir->fp_context != NULL )
- _Context_Restore_fp( &_Thread_Heir->fp_context );
+ if ( heir->fp_context != NULL )
+ _Context_Restore_fp( &heir->fp_context );
+#endif
+ if ( context != NULL ) {
#endif
#if defined(_CPU_Start_multitasking)
- _CPU_Start_multitasking( &_Thread_BSP_context, &_Thread_Heir->Registers );
+ _CPU_Start_multitasking( context, &heir->Registers );
#else
- _Context_Switch( &_Thread_BSP_context, &_Thread_Heir->Registers );
+ _Context_Switch( context, &heir->Registers );
+#endif
+ } else {
+ * Threads begin execution in the _Thread_Handler() function. This function
+ * will call _Thread_Enable_dispatch().
+ _Thread_Disable_dispatch();
+ _CPU_Context_switch_to_first_task_smp( &heir->Registers );
#endif
1.7.7
