[rtems commit] sptests/sp37: Add ISR set/get level tests
Joel Sherrill
Joel.Sherrill at OARcorp.com
Mon Aug 5 13:21:56 UTC 2013
At one point I had a set of porting tests which did not require an entire RTEMS build environment. Something like this was part of it. I also had some bit field tests and a few others.
Should tests that exercise CPU specific code be in a single collection?
Sebastian Huber <sebh at rtems.org> wrote:
Module: rtems
Branch: master
Commit: da831d06fddb67a9bd6abce88f2bbee9e3122810
Changeset: http://git.rtems.org/rtems/commit/?id=da831d06fddb67a9bd6abce88f2bbee9e3122810
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date: Mon Aug 5 10:07:00 2013 +0200
testsuites/sptests/sp37/init.c | 31 +++++++++++++++++++++++++++++++
1 files changed, 31 insertions(+), 0 deletions(-)
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 4ffebbb..a12aa77 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -44,6 +44,36 @@ rtems_timer_service_routine test_isr_in_progress(
/* test bodies */
+static void test_isr_level( void )
+ ISR_Level mask = CPU_MODES_INTERRUPT_MASK;
+ ISR_Level normal = _ISR_Get_level();
+ ISR_Level current = 0;
+ _ISR_Set_level( current );
+ rtems_test_assert( _ISR_Get_level() == current );
+ for ( current = current + 1 ; current <= mask ; ++current ) {
+ ISR_Level actual;
+ actual = _ISR_Get_level();
+ rtems_test_assert( actual == current || actual == ( current - 1 ) );
+ if ( _ISR_Get_level() != current ) {
+ break;
+ _ISR_Set_level( normal );
static void test_isr_locks( void )
ISR_Level normal_interrupt_level = _ISR_Get_level();
@@ -253,6 +283,7 @@ rtems_task Init(
puts( "\n\n*** TEST 37 ***" );
+ test_isr_level();
test_isr_locks();
test_interrupt_locks();
rtems-vc mailing list
rtems-vc at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-vc
