[rtems commit] sptests/sp37: Add ISR set/get level tests
Sebastian Huber
Mon Aug 5 14:17:48 UTC 2013
On 2013-08-05 15:21, Joel Sherrill wrote:
> At one point I had a set of porting tests which did not require an entire RTEMS build environment. Something like this was part of it. I also had some bit field tests and a few others.
> Should tests that exercise CPU specific code be in a single collection?
I think that specific tests for all the low level CPU specific code would be a
great help for all porting RTEMS to a new architecture. Its so easy to get the
bit field stuff wrong. I would use one test for a specific area, e.g.
spbitfield01.
The sp37 seemed to be the right place for all the ISR related stuff.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
