Updating legacy code in arm nds
Vipul Nayyar
nayyar_vipul at yahoo.com
Tue Aug 6 17:34:53 UTC 2013
Hello,
As suggested, I studied the working of interrupt controller. So, I've made implementations of install & remove methods from libnds to change to Interrupt API. This is a small patch for arm nds. Just checking if going in the right direction.
Fair warning: the compilation of arm nds gives an error, but not due to my changes. The error given is :
../../../../cpukit/../../../nds/lib/include/rtems/score/percpu.h:25:34: fatal error: rtems/score/assert.h: No such file or directory
compilation terminated.
I'll be happy to fix this error, that's already present in the rtems tree. The path to assert.h seems to be fine. Need guidance.
Regards
Vipul Nayyar
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130807/c2ffa96e/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130807/c2ffa96e/attachment.obj>
