[PATCH 3/3] PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__
Sebastian Huber
Tue Aug 6 14:11:31 UTC 2013
c/src/ada-tests/support/init.c | 1 -
c/src/lib/libbsp/i386/shared/irq/irq.c | 3 ---
cpukit/libcsupport/src/__gettod.c | 2 --
cpukit/libcsupport/src/error.c | 7 -------
cpukit/libcsupport/src/malloc_p.h | 1 -
cpukit/libcsupport/src/mallocfreespace.c | 1 -
cpukit/libcsupport/src/mallocgetheapptr.c | 1 -
cpukit/libcsupport/src/mallocsetheapptr.c | 1 -
cpukit/libcsupport/src/newlibc_reent.c | 1 -
cpukit/libcsupport/src/sync.c | 6 ------
cpukit/libfs/src/pipe/fifo.c | 6 ------
cpukit/libmisc/monitor/mon-config.c | 1 -
cpukit/libmisc/monitor/mon-driver.c | 2 --
cpukit/libmisc/monitor/mon-itask.c | 1 -
cpukit/libmisc/monitor/mon-mpci.c | 1 -
cpukit/libmisc/monitor/mon-object.c | 1 -
cpukit/libmisc/monitor/mon-symbols.c | 1 -
cpukit/libmisc/shell/main_wkspaceinfo.c | 1 -
cpukit/libnetworking/rtems/rtems_glue.c | 4 ----
cpukit/libnetworking/rtems/rtems_malloc_mbuf.c | 4 ----
testsuites/libtests/malloctest/init.c | 1 -
testsuites/psxtests/psxfatal_support/system.h | 1 -
testsuites/psxtests/psxsignal05/init.c | 2 --
testsuites/psxtests/psxstack01/init.c | 1 -
testsuites/psxtests/psxstack02/init.c | 1 -
testsuites/sptests/sp40/init.c | 2 --
testsuites/sptests/sp67/init.c | 6 ------
testsuites/sptests/sp75/init.c | 1 -
testsuites/sptests/spfatal_support/system.h | 1 -
testsuites/sptests/spintrcritical06/init.c | 1 -
testsuites/sptests/spintrcritical08/init.c | 1 -
testsuites/sptests/spintrcritical09/init.c | 1 -
testsuites/sptests/spintrcritical10/init.c | 1 -
testsuites/sptests/spintrcritical16/init.c | 1 -
testsuites/sptests/spobjgetnext/init.c | 1 -
35 files changed, 0 insertions(+), 68 deletions(-)
diff --git a/c/src/ada-tests/support/init.c b/c/src/ada-tests/support/init.c
index 983e51d..3321f60 100644
--- a/c/src/ada-tests/support/init.c
+++ b/c/src/ada-tests/support/init.c
@@ -3,7 +3,6 @@
* On-Line Applications Research Corporation (OAR).
-#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
#include <bsp.h>
diff --git a/c/src/lib/libbsp/i386/shared/irq/irq.c b/c/src/lib/libbsp/i386/shared/irq/irq.c
index ac8ee9a..6d304ad 100644
--- a/c/src/lib/libbsp/i386/shared/irq/irq.c
+++ b/c/src/lib/libbsp/i386/shared/irq/irq.c
@@ -10,9 +10,6 @@
* http://www.rtems.com/license/LICENSE.
-/* so we can see _API_extensions_Run_postswitch */
-#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__ 1
#include <bsp.h>
#include <bsp/irq.h>
#include <bsp/irq-generic.h>
diff --git a/cpukit/libcsupport/src/__gettod.c b/cpukit/libcsupport/src/__gettod.c
index 7de6a1c..a07497d 100644
--- a/cpukit/libcsupport/src/__gettod.c
+++ b/cpukit/libcsupport/src/__gettod.c
@@ -18,8 +18,6 @@
#include "config.h"
#endif
#if defined(RTEMS_NEWLIB)
#include <sys/time.h>
diff --git a/cpukit/libcsupport/src/error.c b/cpukit/libcsupport/src/error.c
index 9933e14..1a682c0 100644
--- a/cpukit/libcsupport/src/error.c
+++ b/cpukit/libcsupport/src/error.c
@@ -9,14 +9,7 @@
#include "config.h"
#endif
-/* This is always defined on RTEMS Scheduler Simulator and thus
- * we get a redefined warning if this is not present.
-#ifndef __RTEMS_VIOLATE_KERNEL_VISIBILITY__
- #define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
-#endif
#include <rtems/error.h>
#include <rtems/assoc.h>
#include <rtems/score/sysstate.h>
diff --git a/cpukit/libcsupport/src/malloc_p.h b/cpukit/libcsupport/src/malloc_p.h
index 6bd9a49..e7780ec 100644
--- a/cpukit/libcsupport/src/malloc_p.h
+++ b/cpukit/libcsupport/src/malloc_p.h
@@ -9,7 +9,6 @@
#include <rtems/libcsupport.h>
#include <rtems/score/protectedheap.h>
diff --git a/cpukit/libcsupport/src/mallocfreespace.c b/cpukit/libcsupport/src/mallocfreespace.c
index 2b262ca..44fe7a9 100644
--- a/cpukit/libcsupport/src/mallocfreespace.c
+++ b/cpukit/libcsupport/src/mallocfreespace.c
@@ -18,7 +18,6 @@
#include "config.h"
#endif
diff --git a/cpukit/libcsupport/src/mallocgetheapptr.c b/cpukit/libcsupport/src/mallocgetheapptr.c
index 7392d67..c40bc75 100644
--- a/cpukit/libcsupport/src/mallocgetheapptr.c
+++ b/cpukit/libcsupport/src/mallocgetheapptr.c
@@ -18,7 +18,6 @@
#include "config.h"
#endif
#include "malloc_p.h"
diff --git a/cpukit/libcsupport/src/mallocsetheapptr.c b/cpukit/libcsupport/src/mallocsetheapptr.c
index 414918a..d5060b2 100644
--- a/cpukit/libcsupport/src/mallocsetheapptr.c
+++ b/cpukit/libcsupport/src/mallocsetheapptr.c
@@ -18,7 +18,6 @@
#include "config.h"
#endif
diff --git a/cpukit/libcsupport/src/newlibc_reent.c b/cpukit/libcsupport/src/newlibc_reent.c
index 50fd839..b7ac60a 100644
--- a/cpukit/libcsupport/src/newlibc_reent.c
+++ b/cpukit/libcsupport/src/newlibc_reent.c
@@ -18,7 +18,6 @@
#include "config.h"
#endif
diff --git a/cpukit/libcsupport/src/sync.c b/cpukit/libcsupport/src/sync.c
index 6cb6a28..ede594d 100644
--- a/cpukit/libcsupport/src/sync.c
+++ b/cpukit/libcsupport/src/sync.c
@@ -29,12 +29,6 @@ int fdatasync(int); /* still not always prototyped */
-#include <rtems/libio_.h>
-#include <rtems/seterr.h>
/* XXX check standards -- Linux version appears to be void */
void _fwalk(struct _reent *, void *);
diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
index e6308f5..e991ecf 100644
--- a/cpukit/libfs/src/pipe/fifo.c
+++ b/cpukit/libfs/src/pipe/fifo.c
@@ -18,10 +18,6 @@
#include "config.h"
#endif
-#ifdef RTEMS_POSIX_API
-#endif
@@ -69,8 +65,6 @@ static rtems_id pipe_semaphore = RTEMS_ID_NONE;
#include <rtems/rtems/barrier.h>
diff --git a/cpukit/libmisc/monitor/mon-config.c b/cpukit/libmisc/monitor/mon-config.c
index d10c14c..00eec9b 100644
--- a/cpukit/libmisc/monitor/mon-config.c
+++ b/cpukit/libmisc/monitor/mon-config.c
@@ -8,7 +8,6 @@
#include "config.h"
#endif
#include <rtems/monitor.h>
diff --git a/cpukit/libmisc/monitor/mon-driver.c b/cpukit/libmisc/monitor/mon-driver.c
index 7fc520f..70073c6 100644
--- a/cpukit/libmisc/monitor/mon-driver.c
+++ b/cpukit/libmisc/monitor/mon-driver.c
@@ -21,9 +21,7 @@
#include "config.h"
#endif
diff --git a/cpukit/libmisc/monitor/mon-itask.c b/cpukit/libmisc/monitor/mon-itask.c
index 8544761..a1cca30 100644
--- a/cpukit/libmisc/monitor/mon-itask.c
+++ b/cpukit/libmisc/monitor/mon-itask.c
@@ -6,7 +6,6 @@
#include "config.h"
#endif
diff --git a/cpukit/libmisc/monitor/mon-mpci.c b/cpukit/libmisc/monitor/mon-mpci.c
index 1ab5974..14e538d 100644
--- a/cpukit/libmisc/monitor/mon-mpci.c
+++ b/cpukit/libmisc/monitor/mon-mpci.c
@@ -8,7 +8,6 @@
#include "config.h"
#endif
diff --git a/cpukit/libmisc/monitor/mon-object.c b/cpukit/libmisc/monitor/mon-object.c
index bac8eee..1e54c22 100644
--- a/cpukit/libmisc/monitor/mon-object.c
+++ b/cpukit/libmisc/monitor/mon-object.c
@@ -17,7 +17,6 @@
#include "config.h"
#endif
#include <rtems/extensionimpl.h>
diff --git a/cpukit/libmisc/monitor/mon-symbols.c b/cpukit/libmisc/monitor/mon-symbols.c
index 0d1f1c9..b434b12 100644
--- a/cpukit/libmisc/monitor/mon-symbols.c
+++ b/cpukit/libmisc/monitor/mon-symbols.c
@@ -18,7 +18,6 @@
#include <strings.h>
#endif
diff --git a/cpukit/libmisc/shell/main_wkspaceinfo.c b/cpukit/libmisc/shell/main_wkspaceinfo.c
index 7a2f819..0bc0da7 100644
--- a/cpukit/libmisc/shell/main_wkspaceinfo.c
+++ b/cpukit/libmisc/shell/main_wkspaceinfo.c
@@ -9,7 +9,6 @@
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index e5163ac..8ed17d1 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -4,10 +4,6 @@
#define RTEMS_FAST_MUTEX
-#ifdef RTEMS_FAST_MUTEX
-#endif
#include <stdarg.h>
diff --git a/cpukit/libnetworking/rtems/rtems_malloc_mbuf.c b/cpukit/libnetworking/rtems/rtems_malloc_mbuf.c
index 7d89687..602876a 100644
--- a/cpukit/libnetworking/rtems/rtems_malloc_mbuf.c
+++ b/cpukit/libnetworking/rtems/rtems_malloc_mbuf.c
@@ -4,10 +4,6 @@
-#endif
#include <stdarg.h>
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index c8f380f..dea4c2b 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -25,7 +25,6 @@
#include "config.h"
#endif
#define CONFIGURE_INIT
#include "system.h"
diff --git a/testsuites/psxtests/psxfatal_support/system.h b/testsuites/psxtests/psxfatal_support/system.h
index e7ba4b1..cbfe3e7 100644
--- a/testsuites/psxtests/psxfatal_support/system.h
+++ b/testsuites/psxtests/psxfatal_support/system.h
@@ -17,7 +17,6 @@
* Some of the fatal error cases require the ability to peek inside RTEMS
#include <tmacros.h>
diff --git a/testsuites/psxtests/psxsignal05/init.c b/testsuites/psxtests/psxsignal05/init.c
index 3541bec..dbd812c 100644
--- a/testsuites/psxtests/psxsignal05/init.c
+++ b/testsuites/psxtests/psxsignal05/init.c
@@ -11,8 +11,6 @@
#include "config.h"
#endif
#define TEST_NAME "05"
#define TEST_STRING "User Signals"
#define SIGNAL_ONE SIGUSR1
diff --git a/testsuites/psxtests/psxstack01/init.c b/testsuites/psxtests/psxstack01/init.c
index 71590cf..bfd4d00 100644
--- a/testsuites/psxtests/psxstack01/init.c
+++ b/testsuites/psxtests/psxstack01/init.c
@@ -11,7 +11,6 @@
#include "config.h"
#endif
#include <pmacros.h>
#include <pthread.h>
diff --git a/testsuites/psxtests/psxstack02/init.c b/testsuites/psxtests/psxstack02/init.c
index 52cbc6a..d7ae876 100644
--- a/testsuites/psxtests/psxstack02/init.c
+++ b/testsuites/psxtests/psxstack02/init.c
@@ -11,7 +11,6 @@
#include "config.h"
#endif
#include "test_support.h"
diff --git a/testsuites/sptests/sp40/init.c b/testsuites/sptests/sp40/init.c
index c16fd58..bc897c5 100644
--- a/testsuites/sptests/sp40/init.c
+++ b/testsuites/sptests/sp40/init.c
@@ -11,8 +11,6 @@
#include "config.h"
#endif
diff --git a/testsuites/sptests/sp67/init.c b/testsuites/sptests/sp67/init.c
index 4b78bba..beccb51 100644
--- a/testsuites/sptests/sp67/init.c
+++ b/testsuites/sptests/sp67/init.c
@@ -25,12 +25,6 @@ rtems_timer_service_routine TIMER_service_routine(
void *user_data
- * We have to extern this rather than use __RTEMS_VIOLATE_KERNEL_VISIBILITY__
- * because this variable isn't actually in any .h.
-extern Watchdog_Interval _Timer_Server_ticks_last_time;
volatile bool _timer_passage_1 = FALSE;
volatile bool _timer_passage_2 = FALSE;
diff --git a/testsuites/sptests/sp75/init.c b/testsuites/sptests/sp75/init.c
index 95ba2e0..cfd6c59 100644
--- a/testsuites/sptests/sp75/init.c
+++ b/testsuites/sptests/sp75/init.c
@@ -11,7 +11,6 @@
#include "config.h"
#endif
diff --git a/testsuites/sptests/spfatal_support/system.h b/testsuites/sptests/spfatal_support/system.h
index 69f917f..ce736cc 100644
--- a/testsuites/sptests/spfatal_support/system.h
+++ b/testsuites/sptests/spfatal_support/system.h
@@ -14,7 +14,6 @@
diff --git a/testsuites/sptests/spintrcritical06/init.c b/testsuites/sptests/spintrcritical06/init.c
index d1cbe4d..c073833 100644
--- a/testsuites/sptests/spintrcritical06/init.c
+++ b/testsuites/sptests/spintrcritical06/init.c
@@ -11,7 +11,6 @@
#include "config.h"
#endif
#include <intrcritical.h>
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index acb10de..db770ed 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -11,7 +11,6 @@
#include "config.h"
#endif
#include <rtems/rtems/ratemonimpl.h>
diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
index 81f0076..02b7f2b 100644
--- a/testsuites/sptests/spintrcritical09/init.c
+++ b/testsuites/sptests/spintrcritical09/init.c
@@ -11,7 +11,6 @@
#include "config.h"
#endif
diff --git a/testsuites/sptests/spintrcritical10/init.c b/testsuites/sptests/spintrcritical10/init.c
index 28fb755..d03f8a4 100644
--- a/testsuites/sptests/spintrcritical10/init.c
+++ b/testsuites/sptests/spintrcritical10/init.c
@@ -13,7 +13,6 @@
#include "config.h"
#endif
diff --git a/testsuites/sptests/spintrcritical16/init.c b/testsuites/sptests/spintrcritical16/init.c
index cdd862f..dda7cf8 100644
--- a/testsuites/sptests/spintrcritical16/init.c
+++ b/testsuites/sptests/spintrcritical16/init.c
@@ -11,7 +11,6 @@
#include "config.h"
#endif
diff --git a/testsuites/sptests/spobjgetnext/init.c b/testsuites/sptests/spobjgetnext/init.c
index c6da26d..52f3371 100644
--- a/testsuites/sptests/spobjgetnext/init.c
+++ b/testsuites/sptests/spobjgetnext/init.c
@@ -14,7 +14,6 @@
#endif
#include "system.h"
1.7.7
