GCC support for i386
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Aug 12 11:52:24 UTC 2013
I don't care about the i386 in particular but no on addressed my concern about setting a precedent for other architectures such as m68k which may not have desirable instructions in low models. Even SPARC V7 is questionable if you must have atomic instructions to stay in GCC.
Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
Hello,
there was some lobbying against the deprecation of the i386 support of GCC:
http://gcc.gnu.org/ml/gcc/2012-12/msg00132.html
Is this really justified?  Why does the RTEMS project need the i386?  We should
not make the life of GCC developers harder than necessary.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
