GCC support for i386
Mon Aug 12 12:09:22 UTC 2013
The i386 is a bit special since x86 is the GCC main stream architecture.  I
asked this out of curiosity.  Is there really some working i386 hardware around
with RTEMS on it?
On 2013-08-12 13:52, Joel Sherrill wrote:
> I don't care about the i386 in particular but no on addressed my concern about setting a precedent for other architectures such as m68k which may not have desirable instructions in low models. Even SPARC V7 is questionable if you must have atomic instructions to stay in GCC.
> Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Hello,
> there was some lobbying against the deprecation of the i386 support of GCC:
> http://gcc.gnu.org/ml/gcc/2012-12/msg00132.html
> Is this really justified?  Why does the RTEMS project need the i386?  We should
> not make the life of GCC developers harder than necessary.
> rtems-devel mailing list
> rtems-devel at rtems.org
