rtems.git build broken(?) for --enable-rtemsbsp=psim with samples: multiple definition of `_POSIX_Once_Lock'
Sat Aug 17 16:42:16 UTC 2013
Hi
Haven't tested this beyond noting that the build continues.
Please let us know if this works.
$ git diff src/once.c
diff --git a/cpukit/posix/src/once.c b/cpukit/posix/src/once.c
index d77c3c1..40484d3 100644
--- a/cpukit/posix/src/once.c
+++ b/cpukit/posix/src/once.c
@@ -24,8 +24,6 @@
  #include <rtems/posix/onceimpl.h>
-pthread_mutex_t _POSIX_Once_Lock;
  void _POSIX_Once_Manager_initialization(void)
    pthread_mutexattr_t mattr;
On 8/16/2013 10:26 PM, Nick Withers wrote:
> Hullo all,
> It seems perhaps the rtems.git build is broken for the "psim" BSP, with
> samples enabled (at least "hello"): multiple definitions of "_POSIX_Once_Lock".
> It builds for the "mvme3100" BSP without error with or without samples
> Last little bit from the "make" ("gmake" on my FreeBSD 9.2-PRERELEASE,
> r254324, host) output:
> ____
> gmake[3]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/wrapup'
> Making all in testsuites
> gmake[3]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites'
> Making all in samples
> gmake[4]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
> gmake  all-recursive
> gmake[5]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
> Making all in hello
> gmake[6]: Entering directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples/hello'
> powerpc-rtems4.11-gcc -B../../../../../psim/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I. -I../../../../../../../../rtems/c/src/../../testsuites/samples/hello -I..     -meabi -mcpu=603e -msdata=sysv -fno-common -Dppc603e -O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c
> mv -f .deps/init.Tpo .deps/init.Po
> powerpc-rtems4.11-gcc -B../../../../../psim/lib/ -specs bsp_specs -qrtems -meabi -mcpu=603e -msdata=sysv -fno-common -Dppc603e -O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs    -meabi -mcpu=603e -msdata=sysv -fno-common -Dppc603e   -o hello.exe init.o
> ../../../../../psim/lib/librtemscpu.a(libposix_a-once.o): In function `_POSIX_Once_Manager_initialization':
> /home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/cpukit/posix/../../../../../../../rtems/c/src/../../cpukit/posix/src/once.c:30: multiple definition of `_POSIX_Once_Lock'
> ../../../../../psim/lib/librtemscpu.a(libsapi_a-posixapi.o):/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/cpukit/sapi/../../../../../../../rtems/c/src/../../cpukit/sapi/src/posixapi.c:50: first defined here
> collect2: error: ld returned 1 exit status
> gmake[6]: *** [hello.exe] Error 1
> gmake[6]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples/hello'
> gmake[5]: *** [all-recursive] Error 1
> gmake[5]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
> gmake[4]: *** [all] Error 2
> gmake[4]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites/samples'
> gmake[3]: *** [all-recursive] Error 1
> gmake[3]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim/testsuites'
> gmake[2]: *** [all-recursive] Error 1
> gmake[2]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c/psim'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory `/usr/home/nick/rtems/git/build/rtems/powerpc-rtems4.11/c'
> gmake: *** [all-recursive] Error 1
> ____
