SMP: ISR disable/enable vs. mutual exclustion
Sebastian Huber
Tue Aug 20 12:59:59 UTC 2013
Hello,
on single processor systems the ISR disable/enable was the big hammer which
ensured system-wide mutual exclusion. On SMP configurations this no longer
works since other processors don't care about disable interrupts on this
processor and continue to execute freely.
On SMP in addition to ISR disable/enable an SMP lock must be used. For
compatibility with single processor configurations I introduced the ISR locks.
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicINTRLocks.html
They are currently used for the TOD manager, Termios and the file system support.
We need a general review of the RTEMS code base and evaluate every usage of ISR
disable/enable. It helps to add proper _Assert() statements to catch the hot
spots (attached is an example).
This is a high priority issue, since correctness of the system depends on this.
This makes SMP and RTEMS currently like playing Russian roulette.
One big issue are the RTEMS chains:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicChains.html
To make them SMP ready we have two options.
1. Instead of ISR disable/enable use ISR locks. Advantage: not interface
change. Disadvantage: space overhead for user which only use the unprotected
routines.
2. Add a new chain API, e.g. new structure rtems_chain_with_lock which provides
a chain + ISR lock. Advantage: you get what you need. Disadvantage: API
duplication.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130820/0bb940fe/attachment.bin>
