SMP: ISR disable/enable vs. mutual exclustion
Gedare Bloom
gedare at rtems.org
Tue Aug 20 15:56:40 UTC 2013
How much space overhead is the ISR lock? I prefer the solution (1) if
the overhead is not that much.
On Tue, Aug 20, 2013 at 8:59 AM, Sebastian Huber
> Hello,
> on single processor systems the ISR disable/enable was the big hammer which
> ensured system-wide mutual exclusion. On SMP configurations this no longer
> works since other processors don't care about disable interrupts on this
> processor and continue to execute freely.
> On SMP in addition to ISR disable/enable an SMP lock must be used. For
> compatibility with single processor configurations I introduced the ISR
> locks.
> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicINTRLocks.html
> They are currently used for the TOD manager, Termios and the file system
> support.
> We need a general review of the RTEMS code base and evaluate every usage of
> ISR disable/enable. It helps to add proper _Assert() statements to catch
> the hot spots (attached is an example).
> This is a high priority issue, since correctness of the system depends on
> this. This makes SMP and RTEMS currently like playing Russian roulette.
> One big issue are the RTEMS chains:
> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicChains.html
> To make them SMP ready we have two options.
> 1. Instead of ISR disable/enable use ISR locks. Advantage: not interface
> change. Disadvantage: space overhead for user which only use the
> unprotected routines.
> 2. Add a new chain API, e.g. new structure rtems_chain_with_lock which
> provides a chain + ISR lock. Advantage: you get what you need.
> Disadvantage: API duplication.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-devel mailing list
> rtems-devel at rtems.org
