[PATCH] bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad board
Eugeniy Meshcheryakov
eugen at debian.org
Tue Aug 20 22:09:07 UTC 2013
Hi Karel,
I tried to flash a test program after patching RTEMS with your patches,
and the board does not boot anymore. Even worser, it probably does not
have any clock source, because I cannot flash any new firmware. I'll
try to recover it tomorrow and see what is wrong.
Regards,
20 серпня 2013 о 19:11 +0200 Karel Gardas написав(-ла):
> Hi Eugeniyi,
> could you be so kind and review this version of my patch? I've
> needed to leave SYSCONRCC_MOSCDIS as it is now since w/o it I'm not
> able to reach 80MHz on my board. Otherwise I've tried to use your
> advice to use only RCC2 whenever possible.
> Thanks!
> Karel
> On 08/20/13 06:51 PM, Karel Gardas wrote:
> > c/src/lib/libbsp/arm/lm3s69xx/configure.ac | 11 +++-
> > c/src/lib/libbsp/arm/lm3s69xx/include/lm3s69xx.h | 15 +++++-
> > c/src/lib/libbsp/arm/lm3s69xx/include/syscon.h | 1 +
> > .../libbsp/arm/lm3s69xx/make/custom/lm4f120.cfg | 5 ++
> > c/src/lib/libbsp/arm/lm3s69xx/ssi/ssi.c | 4 +-
> > c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c | 61 +++++++++++++++++--
> > c/src/lib/libbsp/arm/lm3s69xx/startup/syscon.c | 9 +++
> > 7 files changed, 95 insertions(+), 11 deletions(-)
> > create mode 100644 c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120.cfg
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130821/383671b3/attachment.bin>
