Sparc specifications
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sun Aug 25 07:26:06 UTC 2013
The SPARC instruction set is a standard. You should be able to find the docs online. Mostly our BSPs are for v7 architectural revision. But may have extensions and parts of v8.
Gaisler.com should have some manuals on the Leon on their website.
--joel
Dhananjay Balan <mb.dhananjay at gmail.com> wrote:
Hi,
Related to the gdb extensions I am building I needed to lookup some architecture details (Registers, PSR represenation etc.)
Can you point me to the right specifications to use for sparc-rtems bsp?
Regards,
Dhananjay M Balan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130825/4f699493/attachment.html>
