Sparc specifications
Dhananjay Balan
mb.dhananjay at gmail.com
Sun Aug 25 07:50:59 UTC 2013
I cannot find any V7 referances, but got this :
http://www.sparc.org/standards/V8.pdf
Will this be enough?
On 25 August 2013 12:56, Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> The SPARC instruction set is a standard. You should be able to find the docs online. Mostly our BSPs are for v7 architectural revision. But may have extensions and parts of v8.
> Gaisler.com should have some manuals on the Leon on their website.
> --joel
> Dhananjay Balan <mb.dhananjay at gmail.com> wrote:
> Hi,
> Related to the gdb extensions I am building I needed to lookup some
> architecture details (Registers, PSR represenation etc.)
> Can you point me to the right specifications to use for sparc-rtems bsp?
> Regards,
> Dhananjay M Balan
Regards,
Dhananjay M Balan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130825/6089c501/attachment.html>
