[PATCH 1/5] libmm score API
Mon Aug 26 18:21:05 UTC 2013
On Mon, Aug 26, 2013 at 2:15 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Mon, Aug 26, 2013 at 5:22 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 2013-08-26 02:14, Hesham AL-Matary wrote:
>>> + * @brief _Memory_management_Region Flags defs
>>> +#define RTEMS_MM_REGION_NO_PROTECTION           0x0
>>> +#define RTEMS_MM_REGION_PROTECTION_READ_ONLY    0x1
>>> +#define RTEMS_MM_REGION_PROTECTION_WRITE        0x2
>>> +#define RTEMS_MM_REGION_NO_ACCESS               0x3
>>> +//#define RTEMS_MM_REGION_PROTECTION_EXEC   0x4
>> I prefer to actually have flags here and not a single integer value.
>> So I would use this:
>> #define RTEMS_MM_REGION_BIT_READ 0
>> #define RTEMS_MM_REGION_BIT_WRITE 1
>> #define RTEMS_MM_REGION_BIT_EXECUTE 2
>> #define RTEMS_MM_REGION_BIT_CACHE 3
>> #define RTEMS_MM_REGION_BIT_DEVICE 4
>> #define RTEMS_MM_REGION_BIT_SHARED 5
> Some of these flags are not supported on some architectures like
> RTEMS_MM_REGION_BIT_SHARED, or targets that do not have
> Cache Unit. How should we handle some of these flags for such
> targets that do not support these features in hardware ?
I would think the BSP will have to handle / ignore the attributes that
do not make sense for it?
>> #define RTEMS_MM_REGION_READ (1U << RTEMS_MM_REGION_BIT_WRITE)
>> etc.
>> This can be used to get architecture specific values easily:
>> ((flags >> RTEMS_MM_REGION_BIT_READ) & 0x1U) << ARCH_READ_SHIFT
> That make sense.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
